Question about Roland Mv-8000 Sampling/Record Production Studio System
I am trying to connect my micro korg via midi to my MV 8800 and record sounds from my synth to my sequencer.
4 Suggested Answers
  • 4 Answers
SOURCE: reason as a sound module with the 8800
I have a boss 1600 and ive used it in the way that sounds similar to you situation.It sounds like you have overdubbed track 1 to next track.If you dont want to hear track 1 while rec. track 2 turn fader down, unless you have already recorded or overdubbed 1 to 2.You should be able to hear track 1 unless you turn fader down or cancel tracksound for the time being.track 1 swhould be heard but it wont be re-recorded youll only hear it unless you turn fader down.Thats how mine works anyway.It lets you hear it if you want but wont record until you song save or during bounce nd mixdown.Then you select the tracks and or the virtual track you want to use.Id try to undo or stat again and read about the overdubb in manual.Im sure youll figure it out.I cant hardly imagine what all that 8800 has and is capable of doing.But ive seen one and i think the midi devices work alot alike.Hope you get it.Praisehim316.
Posted on Oct 16, 2008
SOURCE: Roland MV 8800 No inputs, phono
Hi, post on mvnation.com, they will be able to help.
Posted on Feb 07, 2009
djlaplaya
  • 74 Answers
SOURCE: roland mv 8800 every time i try to load a cd its reads disk not
you could try a cd lens cleaner to clean the lens in the unit.
Posted on May 06, 2010
How do i connect my keyboard and my laptop?
Download USB MIDI driver for yamaha from yamaha website,and install to laptop.
Next:
Make sure the POWER switch on the instrument is set to OFF,then use an AB type USB cable to connect the instrument to the laptop.
After making the connections, turn on the power of the instrument.
Laptop will immediately notify that new hardwares is connecting and automatically install the drivers. Wait until the process is finish.
Thats all. In Ableton,the setting MIDI input must be set to USB MIDI.
Aug 19, 2015 | Yamaha PSRE413 Keyboard
Do not get MIDI signal via EDIROL UA25
Midi is data only, there is no actual sound to the midi tracks themselves. They need to be assigned to either a software synth or an external synth to actually make the sounds you want to hear.
For instance if you load a demo of a midi sequance you will need to add a software synth such as the TTS-1 or Roland sound canvas which are general midi compatable and will play the instruments sounds assigned to the demo's midi channels. Use the Synth Rack feature in Sonar to open one of them. Then you will need to assign the output of each of the midi tracks to that particular synth and you will get sound. Make sure to assing the synth's audio track to you UA-25 as its audio output.
I would suggest reading in the manual and following the tutorials included in the manual to get yourself familier with how this is all done. spacer.gif
May 25, 2008 | Edirol UA-25 External Sound System
I want to record from my Korg M50 to Cubase LE4 on my laptop.
Hello, To record into a lap top you will need a USB mixer, your audio output from the SYNTH will go into the mixer, you use the midi USB cable from the mixer to the lap top. this will help pre amplify your synth to normal audio levels. hope this helps.
Feb 17, 2014 | Korg M50 61-Key Music Workstation Keyboard...
Can a Korg CX3 Organ 61 keys be compatible with the RolandFantom XR module?
Hi, from what I can tell you cound plug your CX3 into the synth module with a 1/4 inch patch cable and run the audio through it, however I think you will be quite limited in what you can do to modify your sound.
Where the synth really works well is when you feed it digital input data. For you to be able to do that your CX3 would need midi outputs and while I don't have one, I looked it up and can see that the CX3 is too old and does not have midi capability.
Midi (musical instrument digital interface) is a common language that allows musical devices such as your fantom to communicate with other devices. A keyboard with midi running into a synth is in essence just a control surface, a way for you to input data into your synth module, it is making no sound itself, but rather outputting digital data into your synth which in turn generates the sounds you want it to. There are allot of keyboards out there that are only for this purpose and are simply controllers. For example, M-Audio Oxygen 61 - 61-Key USB MIDI Controller. I'm afraid your CX3 is just too old to be able to do this, however, I imagine some of the sounds that thing makes are very vintage and good, and modern synthesizers often times just cant reproduce that (though they are getting batter all the time). Hope that helps :)
Dec 20, 2013 | Music
While using korg m50 editor using usb data cable there is no sound from my lap.the sound is only from my head phone connected to my keyboard directly?
Are you connecting to the laptop and using it as a midi controller? You can record midi notes from the keyboard and send them to your laptop via USB using any midi sequencer program (reason, logic, etc). Create a midi track, select the input of that track as your keyboard, then hit record to play some midi notes. To hear what you record, you have to set the output of the midi track to whatever midi sounds or instrunents you have installed on your laptop.
If you are trying to record the actual audio sound the keyboard makes, use an audio program such as cubase, sonar, audacity, pro-tools, and either mic the keyboard, or connect one of the other audio outputs (1/4" TRS) to an audio input on your DAW, and record an audio track that way (as opposed to a midi track).
Apr 13, 2012 | Korg M50 61-Key Music Workstation Keyboard...
I have the yamaha dtexpress and a midifase conect but cant get anny sound to the computer??????????????
try a midi loopback device or a viruual midi cable such as sonys virtual midi cable: http://www.johnrofrano.com/tutorials/virtualmidirouter.htm
i dont know if this one will work, you could also search for loopb1 and hubi's midi loopback device, one of these should work.
what you have to do is use one of these programs, or something similar, to connect your midi input to the soundcard's midi wavetable or to your midi/synth/sequencing software's midi input.
also, the drum machine should be set to output to midi channel 10. make sure that your software is set to recieve on midi channel 10, if applicable.
Nov 29, 2010 | Yamaha Dtxpress Iv Special Electronic Drum...
Still dont get it
Hi Mark.
Siorry, but because of a fault with the system I am not able to reach you on the other thread.
Normalizing tracks means leveling volume settings for a group of tracks or samples to mix or combine them together without troubles like the ones you got.
to normalise tracks you can use the function built in on the Korg studio, see normalize in the software help.
When operating on MIDIs also remember that MIDIs are recorded on different channel (example drums, guitar bass guitar).eg:bTd Aerosmith MIDI archive
When you use them on a sequencer, and you operate on the volume, ensure
Mar 29, 2009 | Korg Legacy Collection
Korg 05r/w not receiving midi
Time to try a Factory Reset. If that does not work, your MIDI-driver chip inside is probably gone. Time for a Techie...
Peace-
Jun 12, 2017 | Electronics - Others
Record, playback problem
Hi Nick,
The fuzz/white noise is a little confusing and it seems to be saying that you are recording something vs trying to record incorrectly and getting nothing at all. Anyway, despite that, I would try going over your recording steps first.
First off make sure your Hi-Z input is not set to the Hi-Z or guitar setting. It is possible your that MicroKorg is overloading the input and distorting. You should however have heard that in the headphones too, so I'm not so sure that's the problem. The next thing to check is to make sure your input is assigned to the track you expect to be recording on. (Press the input's button to check this. The select/record button over the track should flash).
Next make sure your track is armed for recording before you press 'play+record' (Record button above the track should light steady when recording).
Hope this helps.
bd.
Nov 21, 2008 | Tascam DP01 All-In-One Recording Package...
Electronic drum kit, with USB out, problem
Sounds to me like you have the midi tracks outputting to the microsoft midi mapper or wavetable synth, which is built into the sound chip in your pc, and that this is conflicting with the mobilepre sound card - midi is just data, no audio, needs to drive some kind of synth. what you want to do is disable your internal sound card thru device manager, then just use the m-audio mobile pre as the input/output sound card in ASIO mode - you'll need to monitor via the headphone jack on the mobile pre or plug speakers into the line outs on the interface.
Then do tutorial 8 (in help files) on using soft synths - INSERT>SOFTSYNTHs creates a midi track and an audio track in a track folder.
Good luck.
The dude.
Aug 07, 2008 | Yamaha Dtxpress Iv Special Electronic Drum...
Roland Mv-8000 Sampling/Record Production Studio System Logo
52 people viewed this question
Top Roland Audio Players & Recorders Experts
Electric Dime
Electric Dime
Vito Vacirca Jr.
Greg Cann
Greg Cann
Are you a Roland Audio Player and Recorder Expert? Answer questions, earn points and help others
