Question about LG Heating & Cooling
Airconditioner going off randomly.Stabilizer showing normal indications.
  • 139 Answers
Must be set on energy saver setting the unit will turn off an on when the temp is reached
Posted on Aug 22, 2010
My Echo makes a squealing noise randomly when driving & airconditioner is turned off?
Your serpentine belts tension is loose or the belt is going hard. Check the tension on the tensioner pulley and condition of belt.
The belt is slipping on your accessory pulleys when a load is placed on them such as power steering, alternator and clutch fan.
Jun 15, 2015 | 2004 Toyota ECHO
I have a ductless window LG airconditioner that keeps show P2; I have lost the owners manual so I can't remember what this means.
P2 indicates a circuit protection shut down. Turn the Unit Off & Unplug it for 15 minutes. Then plug the unit back in, and turn it ON. During that time out, the electronics should have reset and the unit will go back to your original settings. If this continues to happen contact LG Customer Support 1 (800) 243-0000.
Hope this helps you and thanks for choosing FixYa.
Jul 29, 2011 | Heating & Cooling
I am in Iraq and I have a model KS-H2665E42,at least that is what it says. Anyway the problem is we are on gen power and when the poweer goes off the unit will not automatically come back on when power is...
I doubt it is a capacitor problem or any problem for that matter. Usually there is a 3 to 5 minute power off & restored delay for any airconditioner. The reson for this is that the compressor has built up high pressure just as a matter of normal function. It is not possible for it to restrt until the coolant pressures stabilize. So they use a time start delay in the event of a power loss. As a result of that function you have i n i t i a l l y to turn on your airconditioner after power has been lost and then restored.
Thanks for choosing FixYa.
Kelly
Sep 07, 2010 | LG LS180HE Split System Air Conditioner
Camera stabilizer is not avalilable
The stabilizer is set according to the zoom level. At a set point within the camera, the image stabilizer stops working. This is normal and common in almost every brand.
Dec 26, 2009 | Casio Exilim EX-Z750 Digital Camera
02 4Runner 3.0 showing service code 300. Replaced
Replace all your plugs, po300 code is random misfire which could absolutely be caused by bad gas causing detonation. Try an octane booster and gas stabilizer when parked for long periods.
Sep 12, 2009 | 2002 Toyota 4Runner
Mitsubishi outlander 2003 air conditioner- works great then go's hot for a while then I see airconditioner button flashing. Just had it checked for freon and everything check out ok. Seems to happen...
check air conditioner compressor fuse or relay.if all is good.you have a open compressor clutch coil or a bad compressor.also check compressor clutch wire.
Jun 26, 2009 | 2003 Mitsubishi Outlander
Symptoms of automotive stabilizer bars going out
Not very often a stabilizer bar goes out unless it breaks but that is rare. Thumping under vehicle on bumps etc., could indicate worn bushings, or the strut rods/ links at wheel "A" frames could be shot or worn. One of the most obvious signs would be excessive lean/roll on turns.
Jan 21, 2009 | 1999 Chevrolet Silverado 1500
Random RH blinker issues, sometimes normal, sometimes really fast
If a dual element bulb develops a condition where both filaments touch together even momentarily will produce a fast flash too. Replace the offending bulb.
Jul 28, 2017 | 1997 Toyota Camry
Heating & Cooling Logo
70 people viewed this question
Top LG Heating & Cooling Experts
Donni Steen
Tim Whalen
Dan Webster
Dan Webster
Are you a LG Heating and Cooling Expert? Answer questions, earn points and help others
