Question about LG Goldstar GWHD5000 wall/window Air Conditioner
The power-on toggle switch seems to be broken. It flops back and forth and cannot engage for power 0n.
  • John Freeman Aug 22, 2010
    hey Roniecon,
    No knob... just a mini toggle switch. So I'm thinking replacement of entire switch.
  • 6,826 Answers
It may just be the knob itself,pull the knob off and see if the stem sticking out can be turned with some pliers,if the stem is in the same shape,then you will have to replace the switch.
Posted on Aug 22, 2010
  • Ronny Bennett Sr.
    Ronny Bennett Sr. Aug 22, 2010
    Yes,I would just get a universal one somewhere,and it will work just as well,look at the legs on the switch to make sure you get a similar switch.
How to fix a PTO (blade engager) lever on craftsman riding mower 2000LT
cable is broken down by the deck... most likely
or it is broken by the handle... also most likely
belt engagement arm is stuck... also likely
Aug 29, 2014 | Garden
On/off switch/toggle is broken
move the switch back and forth
until it turns on mine did that
Nov 06, 2013 | Apple iPod Nano 6th Generation MP3 Player
Gear shift feels like a pin fell out. Seems to be flopping around. Won't engage in any gear.
Look at the tube the shifter goes into, is there a pin in a hole there? If not find it and reinstall the pin that retains the shift arm to the steering column barrel.
Oct 09, 2012 | Cars & Trucks
My Dell D830 wireless switch seems to be broken. It just flops back & forth. Unfortunately it's broken in the off position. Is there another way to turn on the wireless?
If you are not willing to risk your laptop, do not continue. If you are, be sure to take all possible grounding and electrocution protection measures.
If you look at the service manual for the D830, you can access/see the inside switch to the left, below and to the left of the red arrow, in the first diagram here: http://support.dell.com/support/edocs/systems/latd830/en/SM_EN/sysboard.htm#wp1084976
The pins that push the slider on/off have probably broken on your case, but you can probably manually flip the switch to the ON position. The switch may still be broken, but you can at least use your wireless!
Note the series of instructions on that linked page are to REMOVE the system board - you will not need to do EVERYTHING, but it gives all the steps to open up the case which will let you access the switch. Taking out the keyboard is not enough.
Feb 11, 2012 | Dell Latitude D830 Notebook
How do i fix my broken driver seat? the back flops back and forth freely. 2004 mustang v6
I WOULD CHECK WITH A SALVAGE YARD, TO FIND ANOTHER SEAT THAT MATCHES, AND REPLACE IT! THAT IS THE CHEAPEST WAY!
Feb 27, 2011 | 2004 Ford Mustang
E-brake
it depends...if you plan on watching dvd's in while parked with your E-brake engaged only then it goes to your E-brake
OR
if you want to watch them while in motion:
and If you have the old firmware then all you need to do is ground the parking brake wire
or if you have the new firmware(just bought the system) a toggle switch is involved:
1 - connect e-brake wire from dvd unit to the switch
2 - connect a ground wire from switch to the unit chassis(any good metal grounding surface will do)
3 - pop in a dvd, toggle the switch back and forth 2 or 3 times depending on what wire you placed where...and voilaa!! your dvd system should work in motion!!
Jun 28, 2009 | Pioneer AVH-P5700DVD Car DVD Player
Green toggle lights
When the lights blink it generally means that the xbox controller is losing power. try charging it or replacing the batteries
Mar 02, 2009 | Microsoft Xbox 360 Console
Furreal pony, Butterscotch, Head floppy/leans left
There is a smaller "u" shaped spring in the middle of the neck mechanism that I found one side was snapped off. Looks normal, but it's broken. I made one out of a coat hanger for temporary purposes and it works like new! I will order one from Hasbro. Hope this helps!
Dec 09, 2008 | Hasbro Fur Real Friends Smores Pony
LG Goldstar GWHD5000 wall/window Air Conditioner Logo
41 people viewed this question
Top LG Heating & Cooling Experts
Donni Steen
Tim Whalen
Dan Webster
Dan Webster
Are you a LG Heating and Cooling Expert? Answer questions, earn points and help others
