Question about Craftsman Garden
I have a craftsman 2 I/C GOLD 12.5 hp 42in deck 6 speed. 1 blade turns and the other is free spinning. When i ingage the blades it is grinding. I think my son hit a rock. what do i do. this is my first riding mower.
  • Mike Bitner Aug 22, 2010
    can i see this by taking the blade off
  • 2,926 Answers
The jackshaft is damaged and the keyway snapped, causing the shaft to turn but not the blade. If you have a model number or serial number you can use it to veiw a parts breakdown on the sears website. Please rate this solution for me when you get a chance.
Posted on Aug 23, 2010
  • GetMeOttaHere Aug 31, 2010
  • 10,319 Answers
By hitting a rock the ARBOR's shaft that holds the blade on may have a sheared pin that mounts to the blade to keep it locked in place
Posted on Aug 22, 2010
Why does a craftsman 42in lawn tractor leave a uncut streak in middle
Is the uncut portion roughly 10-12" wide? Burning rubber smell? Screaching?
Chances are the middle blade isn't spinning.
Shut everything down. Key out.
Check for obstructions. Above and below. Blade and pulley.
If none, you're going to need to break it free. A piece of large bore PVC can be fit over the blade for leverage and safety.
Clear and grass or debris from the pulley shaft. You know, all the normal stuff.
Then try it again
Best regards
Aug 14, 2010 | Craftsman Garden
Blades wont ingage on my craftsman lawn tractor #917.274811?
After hitting a tree root, blades will not cut when I press to engage
Aug 05, 2010 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
Blades will not disengage
the brakes on the deck belt not working belt to tight or deck not fully disengaging
Jun 22, 2010 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Blades turn when not ingaged to turn
This will be due to belt drag. There is a blade brake fitted that is supposed to push brake pads onto the pulleys when the blade clutch is 'out'. If either the pads are worn, or the spring is missing/broken/dosconnected, that will be the problem.
May 12, 2010 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
I started my craftsman 21hp 42in deck today it had a rough idle with backfire and when engade mower it seemed to not have enough power
Backfiring is a sign of too rich on gas and not enough air. Not enough gas will cause the mower to bog down when blades are engaged as it isn't powerful enough to run the motor AND turn the blades. Check your carb and see if you need to clean it and replace diaphgram. Sounds a lot like a carb problem.
Jun 21, 2009 | Craftsman 20 Hp 42" Deck Lawn Tractor
Garden Logo
261 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
