Question about Euro-Pro Shark Steam Mop - Gray/ Purple Vacuum
I got one and it wouldn't steam, took it back and got another one and it steams for 5 min. then stops. If I unplug and cool down it will steam again for 5 min. and stop. very frustrating. I hear very good things from friends and theirs works fine.
  • Euro-Pro Master
  • 43,501 Answers
Yeah some work great and other are a POS...
Here is a tip that I wrote about the Euro-Pro Shark Steam Mop and why it maynot be getting steam to the head...
Euro-Pro Shark Steam Mop Problem
Here also is a link to get any of the Shark Manuals that you need.
heatman101
Posted on Sep 26, 2010
Red devil steam mop no steam coming out
Add CLR to water tank. Let it sit for an hr to overnight unplugged. Plug back in, turn on steam to medium setting and wait about 20 minutes. Mine started to steam and I let it steam for 5 min or so. Empty out CLR, add only "DISTILLED WATER" and clean away. Good luck.
Oct 24, 2013 | Euro-Pro Shark Steam Mop - Gray/ Purple...
I was using my shark steam pocket mop without any trouble for about 5 minutes & all of a sudden it stopped steaming. i tried unplugging it & starting over but when i did this the water chamber...
heatman101
[]0-0-
Jun 17, 2011 | Euro-Pro Shark Steam Mop - Gray/ Purple...
My steam mop stopped steaming after 3 mins of use what can i do about it
Here is a tip that I wrote about the Euro-Pro Shark Steam Mop and why it may not be getting steam to the head...
heatman101
Sep 08, 2010 | Euro-Pro Shark Steam Mop - Gray/ Purple...
I have the steamtek steam cleaner for 5 months and it will no longer steam!
We had the same problem. I took the unit completely apart and it seems it doesn't like our hard water. I took off the head (one screw at the base and it slips off) and I put a tooth pick into the steamer hole to clean any clogs. Then I ran a cup of CLR through it with equal parts water and it runs fine but not as good as it did new. We are going to only run distilled water through it from now on. Hope this helps!
May 19, 2010 | Vacuums
Shark stopped steaming how to fix this
It may be mineral deposits. Empty reservoir of water, add 1/2 cup of CLR. Let sit 1 hour. Take mop outside with a mop head on but not the cloth padding. Plug it in and start pumping the handle to prime it. I used cardboard to do this on to cushion the mop and soak up moisture. Keep pumping handle until the mineral deposits clear and full steam is coming out. When I was done, I unplugged the mop, dumped out remaining CLR, and rinsed out mop reservoir with water. Please add fresh water, plug in and steam out rest of CLR out of tube leading to mop head. Otherwise your mop will still issue out CLR steam. As always, be careful to unplug and let the unit cool down before adding or removing CLR, water or mop head. Steam can cause serious burns.
Nov 21, 2009 | Euro-Pro Shark Steam Mop - Gray/ Purple...
Shark Steam Canister S3325 will not turn on when switch pressed
I had a similar problem; disassembed switch and clamped electrical bayonets tighter with a pair of pliers; works good now.
Mar 21, 2009 | Euro-Pro Ultra Steam SharkTM II Hard...
Steam mop stopped steaming
heatman101
jlk
Jan 24, 2009 | Euro-Pro Shark Steam Mop - Gray/ Purple...
Steam won't shut off
I have portable steam sharrk, had same problem. I filled it with water and now works fine, water level might be to low
Jan 07, 2009 | Kenmore Euro-Pro Ultra Steam Shark II Hard...
Euro-Pro Shark Steam Mop - Gray/ Purple Vacuum Logo
76 people viewed this question
Top Euro-Pro Vacuums Experts
Dennis Key
Dennis Key
Are you an Euro-Pro Vacuum Expert? Answer questions, earn points and help others
