Question about Whirlpool 1.6 Cu. Ft. Over-the-Range Microwave
Model No. MH7130XEQ-2 Keypad does not work. Screen shows "F-2"
  • Whirlpool Master
  • 9,047 Answers
F2 on MH7130XEQ2 model means you have a failed membrane keypad.
This is a simple do it yourself job.
You can order part number 4359477 the control panel frame assembly here, which comes with a new keypad already mounted on it.
You simply move your circuit board into the new frame.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
Next, disconnect the strip as shown in the photo below, then remove the screws that hold your circuit board in the old frame.
Then carefully (since the display is made of glass) move your circuit board to the new frame, and reassembly is the reverse of disassembly.
Posted on Aug 23, 2010
MY GE MODEL NO. JVM1540DN1WW MICROWAVE OVEN NOT WORKING.on the screen of control panel there is a picture of a micro wave and 'press start' showing.But it wont start. I unplugged the plug for a minute and...
You probably have a shorted membrane keypad.
The problem can be intermittent, going away and coming back, but sooner or later it will be permanent.
On this model, the membrane keypad is not available as a separate part, so you would have to order the control panel frame assembly which comes with a new keypad. attached
In this case, you simply move your circuit board into the new frame. That is a simple do-it-yourself job.
It is part number WB56X10824 and you can order it from the Pros here for $135.33 (subject to change).
You can find helpful exploded view diagrams and other order parts by entering your full model number (JVM1540DN1WW) at that link, too.
You can find a video here showing how to remove a typical over the range control panel assembly in under 5 minutes.
Then you unplug the keypad (as per the photo below) and move your circuit board into the new frame. Be careful - the display is made of glass.
Some connectors may have a lock.
Aug 13, 2013 | Microwave Ovens
Buttons make numbers appear on screen
The keypad control board must be replaced in order to address the issue, but keep in mind the part alone is expensive.
Apr 18, 2012 | Microwave Ovens
My keypad is nonresponsive. I unplugged the unit once, and was able to reset it and it worked for one heating. 2 hours later the keypad is now unresponsive again. Upon unplugging/replugging it again shows...
The membrane keypad has failed.
On some models, you can replace the membrane keypad. I have uploaded a handy guide with pictures showing you what's typically involved.
On other models, the keypad is only available as part of the whole control panel frame. It's easier, but a little more expensive.
You may choose to do either yourself, or have it done for you.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
Let us know here if you need further free help.
Mar 13, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
I've got a model: JES1036PWH02.....when I plugged the unit in the internal light came on, the screen showed all eights and then in a few seconds shows a "PF" and NONE of the buttons work? How...
The keypad controller is defective, behind it there is the microprocessor ic mounted on a board with several other parts. The whole keypad and circuit board must be replaced, and the cost just for the part will run more than a new microwave.
Feb 06, 2011 | GE Microwave Ovens
I have samsung microwave model number ME 1240SC. my front panel touch screen is not working properly, when i press the keys it is not working. so i think i need to replace the touch screen. so please...
That model does not user a touch screen, it actually uses a standard membrane keypad.
The first thing I would suggest is a hard reset. Unplug the unit for a minute or so. Then plug it back in, set the clock and try again.
If that doesn't work, leave it unplugged for about 5 minutes. Then try it again.
If it's still not responding, I would suspect your membrane keypad has failed.
Is it possible that some spray cleaner accidentally got into the controls?
Direct spraying of cleaners on the keypad and steam from the cooktop can damage the controls.
I always recommend that you spray non-ammonia cleaner on a soft cloth (not a paper towel which can scratch) and gently wipe the keypad.
And I always recommend that you use the vent fan whenever you're cooking on the stove top to keep heat, steam, and grease out of the controls and door panels.
If it does not dry out over time, it may need to be manually dried or blown out.
The keypad may be damaged or worn out, or control unit may be damaged.
If you (or someone you know) might want to replace it yourself, I have uploaded a handy guide with pictures showing you what's typically involved.
If you wanted to order a new membrane switch / keypad, the part number is DE34-00145F and you can order it from the Pros here. They're our favorite supplier.
Otherwise, this is a pretty standard 1200W microwave, and you may find it better to simply replace it instead of repairing it.
Dec 03, 2010 | Samsung Microwave Ovens
Need mounting hardware for MH7130XEQ Where to get
You can find helpful exploded view diagrams and order parts here.
You can download Whirlpool owner's manuals and installation instructions here.
Nov 23, 2009 | Whirlpool MH7140XF Microwave Oven
My micro wave stop working f-2 is on screen
Possibly a keypad short or motherboard fault if it is a KitchenAid microwave. Beware if you have a KHMS155LSS model, a Keypad short can and will cause the microwave oven to start on its own. A real stunning defect.
Sep 06, 2009 | KitchenAid KHMS155LSS 1000 Watts Microwave...
Microwave Keypad not working
This model does have a child lock. If it's on, the display will say "LOCKED". It is turned on and off by holding dfown the "0" key for 4-5 seconds. You may also have a bad keypad, which in many cases can be replaced. A bad keypad may be worn out due to age, damaged, or it may have gotten wet or otherwise contaminated. Moisture and contamination can be caused by spraying of cleaners, by storing the microwave in an unheated garage or shed, or infestation. I warn my customers to never spray cleaner directly onto the microwave keypad, since the liquid can get inside and "lock up" or even ruin the keypad or controller. Apply an alcohol-based cleaner (such as the purple kind) to a cloth (paper towels can scratch) and gently wipe it off. I suggest to my customers that they NEVER use any ammonia-based cleaner (like the blue stuff) on a microwave, since the ammonia will crack and distort polycarbonate plastics. Repost if you need more help.
Nov 04, 2006 | LG LMVM1935 Convection/Microwave Oven
Whirlpool 1.6 Cu. Ft. Over-the-Range Microwave Logo
126 people viewed this question
Top Whirlpool Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Jaime Hernandez
Are you a Whirlpool Microwave Oven Expert? Answer questions, earn points and help others
