Question about Sanyo DP42746 42 in. Plasma Television
I just purchased a sanyo model dp42740 42 in plasma tv 1hr ago. When i turn it on, the front green light comes on and about 3 seconds later the tv shuts off.it wont stay on.
SOURCE: HDTV 42 inch Plasma Sanyo model DP 42746
the picture is very dark
Posted on Jan 24, 2008
SOURCE: Sanyo plasma 42 TV Turn off for no reason
Product of Japan is good
but made in Japan sucks
Posted on Jul 25, 2008
  • 133 Answers
SOURCE: LG 42 plasma power problem
needs power supply Part number 6709900023A
it is a 171 dollar part, you should be able to order through LG,
Posted on Jan 10, 2009
  • 304 Answers
SOURCE: I purchased a Plasma Samsung 42
What a you are seeing is called "Diffusion Error". It means that the Panel has gone bad.
Sometimes it can be adjusted out but IT WILL come back even worse and contiue to grow worse. It is caused by a defective Panel. The only way to eliminate the problem is to replace the panel. Have a trained Samsung tech replace the Panel and make sure he adjust the Power Supply voltages to the Panel voltages that are listed on a sticker on the new Panel.
Posted on Jul 17, 2009
  • 135 Answers
SOURCE: screen went black on my 42" sanyo model dp42647 lcd
Hi there! The panel may be in protection mode. The Inverter board is the most logical area to start after checking power supply Voltages.(5,6,24 and 13Volts). There may be coils on the Inverter Board which have bad soldering or faulty. Other than this it may be main board which controls switch on or off. If all else fails, refer to a repairer. Beware of High Current!!! Best Wishes and Good Luck, Jus004
Posted on Aug 23, 2009
Got a Samsung dnie model code spp4251x/data tv when powering up the front light comes on but no picture or anything anyone got some good info??
tv seems to turn on but no picture? - Forums - CNET
www.cnet.com > Forums > Samsung
CNETJun 11, 2015 - ... Samsung Dlp TV (HLR-5067W) it seems like the TV turns on butthere is no picture. ... the lamp is, light is visible from where the lamp is located but no picture. DLP Twon't turn on, blinking green lamp light then shuts dow ...
Jun 11, 2015
Samsung Plasma TV - Won't turn on
Jun 11, 2015
The timer, lamp, and standby/temp. light are flashing?!
Jun 11, 2015
Samsung TV Keeps Shutting Down
Jun 11, 2015
More results from www.cnet.com
TV with Black Blank Screen Repair How to Troubleshoot ...
? 3:16
https://www.youtube.com/watch?v=kFdVi2ejfzA
May 8, 2014 - Uploaded by ShopJimmy.com
TV Repair Help for a TV With a Black No Image on the Screen ...I Have A Sanyo TV I Can Hear But Black Screen Im 14 And Dont Know What To Do ! .... power button the power light goes from red to green, the screen flashes on then goes black ....Troubleshooting LCD Backlight Failure Samsung LNT-4066 ...
Samsung plasma tv repair blinking light no picture ...
Jan 09, 2016 | Samsung Televison & Video
Sanyo dp50747
sounds like a mainboard problem
Jan 31, 2013 | Sanyo DP50747 50 in. Plasma TV
Mitshubishi plasma tv ws65869 wont start green led on in a sec off
Not a Plasma by the model number listed.
When green power light comes on and goes off a few seconds later:
Press and hold on the front of the set both the Menu and Input (source) buttons at same time for at least five seconds and let both go.
Power light will blink a two digit error code like: 2 blinks, 2 blinks and a pause and repeat it several times.
If set has been unplugged it clears the errors and you must turn on and when power light goes out repeat.
Let me know error code found and I will help
Mar 11, 2012 | Mitsubishi Televison & Video
I have a 42" Maxent plasma tv. When turned on,
one or your tv mainboard was crashed, change it with new one
Jan 18, 2011 | Maxent MX-42HPM20 42 in. Plasma HDTV
Sanyo DP50747 Replaced Power Supply still not working
I have same problem. Walmart is selling Sanyo junk You are not alone lots of web chatter about these lasting 2 years or less, Mine lased 19 months, Trash it & buy a different brand. I originally was going to buy a Samsung & now I will.
Sep 22, 2009 | Sanyo DP50747 50 in. Plasma TV
Daewoo DSP4210GM 42 in. EDTV Ready Plasma TV
what way did you set the tv in the transport vehicle. something has been knocked loose inside or the videomask has been damaged?
May 14, 2008 | Daewoo DSP4210GM 42 in. Plasma Television
Ok Fellas I found the Problem!
The Problem is the V4 Y-Main Board. This board is located on the left side of the case looking upright from the back. I spoke with may suppliers, and Sanyo all confirming this. Apparently it has been an issue for some time. Sanyo has replaced the V4 Y Main board with a W1 Y main board in newer models. The W1 Board is NOT compatible for us tho. Just to be sure... If your T.V is taken apart (like mine) Disconnect the peripheral cable from the V4 Y Main, and turn on the set. I bet it will power up with audio and channel function just NO picture. When you plug the board back in... POOF set shuts down. Replacement boards are VERY hard to come by. So Happy Hunting!
42' HD V4 Y-MAIN
PCB: LJ41-02760A LJ41-02761A LG92-01200A BN96-03352A
Oh yeah.. just FYI, Sanyo, Phillips, and Samsung all use the same parts. Hopefully that will help your searching.
Aug 26, 2007 | Sanyo DP42746 42 in. Plasma Television
Sanyo DP42746 42 in. Plasma Television Logo
339 people viewed this question
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
Jerry Greenberg
Jerry Greenberg
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
