Question about Evenflo Generations
Need to adjust strap up - Evenflo Generations
  • 70 Answers
Are you talking about moving it from the lower slots to the upper one for baby/toddler size? If so, have the car seat out, the back facing you. Carefully unlace the straps from the metal toggles, if you have a problem remembering, grab your digital camera and shoot a few photos as you go, this is such a life saver in so many experiences (hubby used this when rebuilding a car engine--smooth).
Anyway, undo 1 side at a time to pull out to the seat side, move it up, then do the other side.
You know to adjust for the length when fitting little person in to use the toggle at the front bottom to pull. There is a little lever, may be red, just between the feet of child that allows you to loosen or tighten straps from that point.
If you are really in a predicament, call your local public health office, they may have a print out of a generic seat that this is done for.
Please call a ParentLink Representative at 1-800-233-5921, Monday - Friday from 8 am to 5 pm.
Hope this helps, GrandmaJ.
Posted on Nov 13, 2008
How do you adjust straps on a baby car seat?
Graco SnugRide 35 : Adjusting Harness Straps - YouTube
? 6:41
https://www.youtube.com/watch?v=vl_JSaEuu0U
Jun 23, 2012 - Uploaded by Baby Car Seat Installers
This video shows how to adjust harness straps for the Graco ...Graco SnugRide 35 : Adjusting Harness Straps. Baby Car SeatInstallers.
Britax B-Safe: Adjust Car Seat Harness Straps - YouTube
? 3:12
https://www.youtube.com/watch?v=XGHnSLXRqq8
Mar 2, 2014 - Uploaded by Baby Car Seat Installers
We teach you step by step on how to move the harness strapshigher as your child grows. This video is for ...
Nov 17, 2015 | Cosco Baby Gear
I can't adjust the straps
Hi Selina - Instructions are in your user manual on how to adjust the harness height. When the harness is correctly adjusted for your daughter the harness pads should sit comfortably. If you need to download a replacement user manual select the carseat you have then click "Service" at www.maxi-cosi.com
Nov 29, 2011 | Maxi-Cosi Axiss Reflection Booster Car...
I am having trouble adjusting shoulder straps
Funny, I was just putting this seat back together after taking it apart to wash it. It is a very difficult process, simply because you have to remember which order to loop the buckles through the stap.
First, I assume you want to switch from the lower holes for the shoulder, to the upper. (If not, then there is no adjustment needed. Unless the strap is caught in the back which will make the straps uneven when you go to tighten them. This has happened to me).
So, first you need to remove the straps. Once the seat is removed from the car, look at the back of the seat and you will see a metal bracket that is holding three straps. The bottom strap is not removable from that bracket. The top two strap are attached to the bracket with loops. Remove the straps by sliding them out (edge of the strap has to come out the hole first, then the rest will slide out very easily), Once out, from the front of the seat, pull the strap through the holes
At this point you must decide whether you simply want to adjust the seat, or wash it too. I highly suggest washing it if you haven't done so recently. If you gone this far, go all the way. But since you only asked to adjust it, and the method for removing the cover is much more complicated, we''ll move on to adjusting
Now that you have the straps pulled through, be sure that the straps are not twisted, and simply push them through the desired holes - upper or lower - and reconnect to the loops brace (remember, edge in first).
If you are having problems with the straps not being even when tightened (one side tight on shoulder, other side loose), remove the seat and look to see if the strap is caught on something.
I'm retiring my seat today after six years and two kids. I could use it up to 80lbs, but it makes it difficult to get to the third row of seats in my car. So now we have two no-back boosters.
Oct 13, 2009 | Eddie Bauer Deluxe High Back Booster...
How to adjust a Rubber strap
well all i did was cut the strap
Aug 30, 2009 | Watches
How can pull adjustment belt
The shoulder straps feedthrough a loop in the adjustment belt so when you pull on the belt it tightens the straps. When you say it came out, if it has come out completely then you will need to remove the car seat and locate where it connects to the shoulder straps before feeding it back through the hole again
Aug 15, 2009 | Maxi-Cosi Baby Gear
Adjusting the shoulder straps on the Maclaren volo stroller
What year is your Volo. Different years adjust differently. The newer ones have 3 height adjustment slots and a slider that adjusts the strap itself. They do not adjust way down though and even with teh straps as tight as they will go, they are still a little loose on my 15 month old granddaughter. I have found that buy tightening the waist straps it does keep her a little more secure.
Mar 15, 2009 | Maclaren Volo Umbrella Stroller
Car Seat Belt keeps getting stuck
check the adjustable strap then check the spring of the strap .
Feb 02, 2009 | Graco Quattro Tour Travel System
Help
need to adjust straps
Feb 12, 2008 | Evenflo Cozy Carry 5
Strap Adjustments
Yes, Im sure you can find it in a department store or online store. Try target.com probably, they are called extension strap like this http://www.babyonthemove.co.nz/shop/Car+Seats/Carseat+Accessories/600mm+Extension+Strap.html?id=akv7atuH
Jan 22, 2008 | Cosco Summit 22260 - Bouncing Sheep
Missing Instruction Manual
https://plweb.evenflo.com/faq_detail.aspx?faqid=4407 the above link is for the manual but here are the instructions. If you have two plastic harness adjusters located on the back of your seat please follow the following steps: On the very bottom of your car seat locate two metal anchors one on each side of the seat, pull the metal anchors out of position and turn them sideways and feed them through to the front of the seat. Release the buckle tongues and chest clip and pull the harness straps to the back of the seat while pushing the chest clips, buckle tongues and harness anchors through to the back of the car seat. NOTE: You may find it easier by pulling down the seat pad when feeding the straps through. All pieces will fit through the harness slots. Choose the appropriate slots for the new harness position. Push the harness anchors, harness straps, buckle tongues and chest clips back through to the front of the seat. Once the straps are completely pulled back through to the front of the seat, make sure the straps are not twisted by clipping the chest clip together and buckling the buckle tongues, then feed the metal anchors through to the bottom of the seat and clip anchors back into place. ********************************************************************* If you have an adjustment strap that is located in between the child?s foot area that allows you to loosen and tighten the straps please follow the following steps: Loosen the harness straps by pressing the harness release button that is located between the child?s legs near the feet area; while pulling on the harness straps from the front of the car seat near the shoulder area. Turn the car seat around and from the back side of the seat follow the straps down to the metal splitter plate, remove the ends of both straps from the metal splitter plate. Once the straps are removed, pull both harness straps completely through to the front of the seat. Choose the appropriate slots for the new harness position and feed both straps through from the front of the seat to the back of the seat. Making sure straps are not twisted; hook each end of the straps back onto the metal splitter plate. Tighten the harness straps by pulling the adjustment strap located on the front the car seat between the child?s legs. NOTE: Final adjustment of If you have an adjustment strap that is located in between the child?s foot area that allows you to loosen and tighten the straps please follow the following steps: Loosen the harness straps by pressing the harness release button that is located between the child?s legs near the feet area; while pulling on the harness straps from the front of the car seat near the shoulder area. Turn the car seat around and from the back side of the seat follow the straps down to the metal splitter plate, remove the ends of both straps from the metal splitter plate. Once the straps are removed, pull both harness straps completely through to the front of the seat. Choose the appropriate slots for the new harness position and feed both straps through from the front of the seat to the back of the seat. Making sure straps are not twisted; hook each end of the straps back onto the metal splitter plate. Tighten the harness straps by pulling the adjustment strap located on the front the car seat between the child?s legs. NOTE: Final adjustment of the harness straps must be completed with the baby in the child restraint.
Aug 02, 2007 | Evenflo Embrace
Evenflo Generations Logo
51 people viewed this question
Top Evenflo Baby Gear Experts
Joyce Nokleby
Shehu Pro
Shehu Pro
Rick Moore
Rick Moore
Are you an Evenflo Baby Gear Expert? Answer questions, earn points and help others
