Question about Toshiba Tecra M7 Tablet PC
I have a Toshiba Tecra M7 bought with XP and upgrade with Vista an later on with Windows 7. The only problem is that sometime when I turn the screen it becomes blank. I have to shut it down and to do a restart and it's ok. It seems to happen ramdonly, but as usual it happens when I'm need for power point presentation !!! The driver is NVIDIA Quadro NVS:110M The pilot version is 6.1.7600 16385
  • 10 more comments
  • m_provencher Aug 22, 2010
    Before, I've posted this question, I've checked the disk extensively and there is no problem there.
    Pilot version is 7.15.11.7948 (2009-01-30) instead.
    This seems to be a probleme with the screen driver, not the hard disk. This was checked before this post.
    I've tried to update the pilot, but Microsoft update report an error for the new version, so it's not installed.
    Please note that I'm using Windows 7 instead of Vista as written.
    This is not the Vista version, but the Windows 7 one.
    I didn't have this problem with Vista - but a lot others !
  • m_provencher Aug 23, 2010
    I've tried to add services gradually and I still have the problem of occasionnal blank screen.
    Is there a new pilot somewhere Tecra M7 NVidia for Windows 7 ?
    Your friend expert "nonontech" told me the same and he gave me the link for the driver. As told to him I'll try it.
    I could give you a feed back also.
    Regards
  • m_provencher Aug 24, 2010
    I received the error message when I've tried to install it :
    [Error] BIOS update is not supported OS. Unsupported OS or service pack is installed.
    The actuel version of the BIOS is 3.20 2007-04-27, as seen in the information sstem.
    Do you have a suggestion ?
    I still have the problem with the new version of the driver.
  • Toshiba Master
  • 3,247 Answers
Not sure if the problem you have is directly linked to the upgrade to windows 7 or just an intermittent hardware fault.
It is best to check if your model is tested as Windows 7 compatible by verifying the serial no. at this site.
Happy to help further if you can check compatibility with window 7.
Posted on Aug 25, 2010
    Guru:
  • 731 Answers
You need ACPI Flash BIOS version 3.50 for Tecra M7 nVidia.
CLICK HERE to download the file.
WinRAR 32-bit self-extracting ZIP file includes both Windows-based and diskette based BIOS update installation options. See the included documentation for details.
Regards
Riztech
Posted on Aug 24, 2010
  • 857 Answers
This seems to be a problem with the video card, try to download the latest driver for windows 7 from the website,
the 2nd thing to notice is you got the system with windows xp but now you have windows 7, did you checked the microsoft compatibility check before you upgraded to win 7 from windows vista.
This may be the problem with the operating system or the application which you are using try to reinstall it.
This should help.
Check your Memory it should be atleast 2 gb or more.
Posted on Aug 23, 2010
  • Toshiba Master
  • 4,737 Answers
Try this, once you restart it successfully, type in "mscnfig" in the run box (press windows key + R to open run) and press enter, now click "Startup" and click "disable all", then "Ok", restart your computer and see if it helps or not. I am sure that if there's hardware and drivers issues, this will definitely help you find out the culprit.
You can enable the start up program one after another, checking at every restart. Don't enable them all at one go, you'll not be able to narrow down the culprit.
If you need further help, let me know.
Good luck.
Thanks for using FixYa.
Posted on Aug 22, 2010
  • 7 more comments
  • Lebanon Raingam
    Lebanon Raingam Aug 23, 2010
    It seems there are several Experts involved with this problem, if possible, please add comments on the specific experts solution. I am confused which reply is mine and which isn't mine. Thanks
    Sorry for the confusion, I'm new with this system.
    But, I've tried your suggestion and added services gradually and I still have the problem.
    So, do you beleive that's the driver itself could be the problem with Windows 7.
    I've not yet found a new driver for NVidia for my Tecra M7 whcich could comply with Windows 7.
    Marc
  • Lebanon Raingam
    Ok, let me help you find the drivers.
  • Lebanon Raingam
    Here it is. (click here). This is the latest version available for Nvidia Quadro NVS 110M drivers for windows 7 from Nvidia Official Website. Open the link and click the green "Download" button. The size is approximately 122 mb.
    Good luck.
    Thank you for this link. It looks like I've looked at the right place.
    I'll try it and I'll be back yo you.
    Thanks
  • Lebanon Raingam
    No problem. All the best.
    I installed it and I still have the problem.
    An other expert told to replace the BIOS with the version 3.50 (it has 3.20), but I can installed it because I receive an error "BIOS is not supported OS.
  • Lebanon Raingam
    Lebanon Raingam Aug 24, 2010
    I am sorry, I can't assist along with the Bios, and you must understand that Dealing with Bios is not simple and it's risky. You may loose everything. Since it's related to graphics, we need to find out the root of the issue, means what is causing this problem? I am afraid if it's with Bios, honestly I'll opt out. If you want to try with the bios, you have to backup all the files, in most cases, bios update is not successful.
    I also doubt that updating with that version is not possible with your machine. Downgrade may be possible, but I can't guarantee.
    If there's no means, the only solution is downgrading the system's O.S. to previous version. There must be drivers conflict or must be drivers incompatible issues. You can install additional O.S. like windows vista or windows xp and check whether the problem persists or not.
    If you still want to give a try, uninstall everything (like softwares, antivirus, drivers, etc.. ) which will not affect the system's boot process or running processes. Keep only the basic applications which is compulsory to run the system. Also uninstall the graphics drivers and try again. You can reinstall it later.
    It's upto you, but I can only suggest you this... for now.
    Good luck.
    Thank you for your support. So, you're right, to change the version of the BIOS is risky.
    I've print out the 6 pages instructions, to discover that the version 3.50 is not vfor Vista neither to Windows 7, but only XP - even if it's rwritten for Vista and Wista on the Toshiba.
    I really don't know where to go up to now.
    But, thanks for great support.
    Genius:
  • 1,456 Answers
What you should do is to update the driver.
To do this connect your system to the internet and click on the start menu>control panel>device manager scroll to the driver and right click on it and select update driver software.
This will update the driver and automatically install it,you will then have to restart your system.
Also to avoid further recurrence it is best advised that you get a higher version of microsoft office that is compatible with windows vista.
  • 10,319 Answers
You may have a bad sector which will notify you very soon. It is a common problem with Windows Vista & Windows 7
If the ballon shows up you have a bad sector itwill state to replace the hard drive. Most of the time these hard drives will run a few hundred hours before they plainly quit. Back up all material you like to save just incase
I have a Toshiba Tecra M7 that won't boot and up until this morning nothing worked. This is what I've done so far this morning WHEN it does decide to boot. 1. Power up computer from off with ESC...
Your hard drive may have gone south. Remove it and check with diagnostic software. Bad sectors in critical areas of operating system data will do this.
Apr 01, 2017 | Toshiba Tecra M7 Tablet PC
I installed windows xp on my toshiba tecra m4. How stylus pen works?
Toshiba Tecra M4-S435 is Tablet PC. Windows XP (Profession) has no option of touch screen.
In order to use the feature, you need to install Windows XP Tablet PC Edition or you may install Windows 7, which supports this feature and you would definately be able to use stylus and touch screen, as I have installed Windows 7 and its working fine with all the drivers etc.
Hope it helps! Good Luck!
CreativeTECH
Apr 23, 2011 | Toshiba Tecra M4-S435 Tablet PC
We have lost our power connector to the toshia tecra m7
go to toshiba online or best buy or circet city or raidio shack sale universal chargers
Nov 20, 2009 | Toshiba Tecra M7 Tablet PC
Installation of windows xp to toshiba satellite 1695CDT
10gb of RAM is not enough for Windows XP. You need to upgrade your HDD to about atleast 40 GB HDD Minimal... I'd recommend a new PC if you can get that to work out, but I understand the tuff economical times.. If you need any mroe help ..throw me an email at joey@joeysitservices.com I'll give you some bootable tools that may help!
Apr 16, 2009 | Toshiba (K000680310) for Satellite...
Clean dust from tablet pc screen
You have to remove the screw covers (the black squares around the screen), remove the screws and gentley pry the cover open with yor finger nails or a flat head screw driver, but be careful not to dent the sides with the screw driver. You can then take a can of air and blow the dust out. I would not touch the sensetive screen under neath. You could take a anti static, micro fiber cloth to wipe off the tough stuff.
Jan 26, 2009 | Toshiba Tecra M7 Tablet PC
Tecra m7 doesn´t boot up
mine does the samething have you found out what the problems is yet?
Dec 23, 2008 | Toshiba Tecra M7 Tablet PC
Drivers lost for Toshiba Tecra M7 Tablet PC
download win xp sp3 and install .... ur laptop should work and then download and run the "registered" version of Driver Detective ... it should find drivers specifically for YOUR laptop ... that might work ...
May 26, 2008 | Toshiba Tecra M7 Tablet PC
Restore disk
I have M7 restore disks made off of my M7 hard drive. I'll mail them to you if you pay for shipping and the 4 DVDs....say $15? Then you can restore and the restore tools will be restored to your computer as part of the restore.
Mar 26, 2008 | Toshiba Tecra M7 Tablet PC
Toshiba Tecra M7 Tablet PC Logo
532 people viewed this question
Top Toshiba Tablets & eReaders Experts
k24674
Alun Cox
micky dee
Are you a Toshiba Tablet and eReader Expert? Answer questions, earn points and help others
