Question about Whirlpool Duet 4.0 Cu. Ft. Steam Washer
My steam duet is showing the F35 sign and I am wondering if there is something I can do before call a repair man
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. Error F 35 means ANALOG PRESSURE SENSOR FAILURE- If this failure is displayed then there is any malfunction of the component detected by the Steamer Electronic Board.
1. Check if pressure hose is fixed correctly.
2. Check if the air trap is not blocked.
3. Check if the hose is not blocked
If it still not works then it is a problem with the water level pressure switch operation. There could be a blockage in the air dome or pressure switch hose. The air dome is located on the back of the tub on the left hand side. If the pressure switch hose and the air dome are clear of any blockages, then there is an issue with the water level pressure switch.
Please do rate the solution if the issue is resolved or else post a comment for further assistance.
Thanks
Rylee
Posted on Aug 23, 2010
Whirlpool duet steam WFW9600TW00 code F35
Hello & Welcome to FixYa
F35 error means that there is some sort of issue with the steamer electronic board and analog pressure sensor has gone bad. Check that the hose is firmly attached with the washer and is not blocked. You can also check the water level pressure switch operation. Please get back to me if you have any other questions.
Kevin
Oct 02, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Suds then f35 Whirlpool Duet 4.0 Cu. Ft. 14-Cycle Steam Washer - White
F35 is a water level error.
The water level switch (pressure switch) has malfunctioned.
If you remove the top panel, three screws in the back, you will have access to the pressure switch.
With the tub empty, remove the vinyl hose from the switch and blow backwards through the hose to clear any restrictions.
If the fault codes return after doing this, you will likely need to replace the pressure switch.
Also - please be sure to use He soap.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Sep 29, 2010 | Whirlpool Duet 4.0 Cu. Ft. Steam Washer
Please i need repair manual for whirlpool duet steam washer whice keeps giving me the f35 code and suds
Go to servicematters.com for the tech sheet or look in the bottom for it.
Sep 23, 2010 | Washing Machines
Error code washing is delayed wil wash half the clothes
Mar 06, 2010 | Whirlpool GHW9300 Duet Washer
Whirlpool Duet -Sud displays and washer stops
I;ve had the same problem (SUD on first fill) and found this most helpful for my WFW9600TW01 Duet washer
http://www.tellingmachine.com/post/Fixing-Sud-and-F35-errors-on-my-Whirlpool-WFW9600TW01-Washer.aspx
I duplicated his actions and it cleared up my SUD/F35 error. I think running the diagnostic test multiple times flushes the sensors/sensing lines to eliminate the problem.
Jan 30, 2010 | Whirlpool Duet GHW9150P Front Load Washer
F35
pressure switch
Jan 12, 2010 | Washing Machines
I start the machine the suds flashes then it goes away and the F35 flashes and nothing happends I tried to use the clean washer cycle and it still comes up F35 then when I try to push the cancel button the...
If this is a steam unit you have a bad analog pressure switch,has been a common issue in those units,Gives an F35 core and sometimes a SUD code.
Sep 20, 2009 | Washing Machines
F35 flashing
if it is less than one year old call for service it should be covered. if not take the kick panel off and locate the tech sheet it is either in the kick panel or in the cabinet to the right. it will give you a list of error codes find out what it means and let me know thanks
Jun 25, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Washing clothes all day have an F35 flashing
F35
If this failure is displayed, there is any malfunction of the steamer
Possible Causes/Procedure
2. Check if the airtrap is not blocked.
3. Check if the hose is not blocked.
Check these problems.
Plesae leave a solved rating before you leave the site
Jan 30, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet 4.0 Cu. Ft. Steam Washer Logo
91 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
