Question about Kenmore Dishwashers
HOW LONG SHOULD MY KENMORE DISHWASHER RUN ON NORMAL CYCLE
Amigaman
  • 248 Answers
SOURCE: 665.17019401 - Kenmore diswasher
It indicates a water temp problem. If water temp doesn't rise at a certain rate, by the heater, it goes into this error. Probably a problem with heater or wires to it.
Posted on Nov 22, 2007
  • 4 Answers
SOURCE: Kenmore Dishwasher model # 665
replace control board
Posted on Feb 16, 2008
SOURCE: kenmore dishwasher
Mine eventually "fixed itself". I think some debris got caught and eventually (5 cycles or so) got ground up and sent through the drain. The noise changed each time it got closer "flushing out"
Posted on Apr 24, 2008
wheelshot
  • 102 Answers
SOURCE: dishwasher runs, water doesn't drain out
sounds to me that you may have some suds residue in the dishwasher that keeps it from draining completely. Get you some dishwasher cleaner which you can purchase at wal-mart or wherever you buy your detergent, and clean out your dishwasher. It is a inexpensive test. Alot less expensive than having a tech come to your house. Make sure that your drain hose is mounted higher that where it goes into the drain. This is also a common problem that I encounter in the field. Hope this helps. Let me know if I can help you futher.
Posted on Apr 04, 2009
SOURCE: My Kitchen Aid dishwasher runs for about 2 hours. Is this normal
Kitchen Aid KUDI02FRSS2 - I have the same problem and called Kitchen Aid (Whirlpool). They originally told me the control panel needed to self-program and that I needed to let it run through one complete cycle before it would lock in the program. When this didn't work they told me the unit has water temperature sensors in it that controls the length of wash depending on the incoming water temperature. When I told them the house water temperature was borderline scalding they said they could send a repair tech out for $75 just to come to the house. I told them to forget it and could buy the control panel for $80 bucks and install it myself for free. I had a previous K/A dishwasher that ran for 30 years without a problem. This one was a problem from day one. Never again - Whirlpool or K/A
Posted on Aug 27, 2009
Kenmore elite dishwasher model 630 Smart Wash light is flashing
You may want to try:
Press a series of four buttons in quick succession. Press "Heated Dry," "Normal Wash," "Heated Dry" and "Normal Wash" to instruct your Kenmore dishwasher to run a short diagnostic test.
Wait for two minutes while your Kenmore dishwasher runs its diagnostic test.
Press the "Cancel/Drain" button once your dishwasher has completed its diagnostic test. This should reset your dishwasher control panel.
Check to make sure that there's no standing water in the bottom of your dishwasher. Standing water in your dishwasher may indicate that your dishwasher has stopped mid-cycle. You will need to press the "Cancel/Drain" button before you can reset your dishwasher control panel.
Dec 18, 2013 | Dishwashers
Error 1 on kenwood dishwasher
Hello.
Manufactured by Whirlpool, Kenmore dishwashers have an electronic control panel that must be unlocked in order to set or make changes to your dishwashing cycle. If an error light is blinking on your dishwasher's control panel, the panel must be reset before you can gain access. Blinking lights on your dishwasher control panel may signal a mechanical problem that needs to be repaired. If the lights continue to blink after you've reset the control panel, contact Sears to service your Kenmore dishwasher or consider troubleshooting the appliance yourself.
1Press and hold the "Heated Dry" button on your Kenmore dishwasher for four seconds to unlock the dishwasher control panel.
2 Press the "Heated Dry," "Normal Wash," "Heated Dry" and "Normal Wash" buttons one after the other, in fairly quick succession.
3 Wait for the dishwasher to run a short diagnostic test.
4 Press the "Cancel/Drain" button at the end of the diagnostic test cycle. This should reset the control panel on your Kenmore dishwasher.
Thanks.
Nov 05, 2011 | Kenwood KDW243A Builtin Dishwasher
My quiet partner 111 whirlpool dishwasher is flashing clean
Hello.
Thanks.
Nov 04, 2011 | Whirlpool GU2400XTP Built-in Dishwasher
I have a Kenmore elite dishwasher M#665.13419k701, when you run the cycle it shuts off after about 10 seconds and the normal wash light blinks. what can i check??? Thanks. Israel
Hello, welcome to FixYa.
I understand by reading your post which indicates it is a Kenmore dishwasher you appear to have a concern with the cycle interuopting and the "normal" light flashing.
I'd suggest you first try entering a diagnostic/test...to do so is as follows. Press the following buttons in this sequence...
HEATED DRY - NORMAL, HEATED DRY - NORMAL, HEATED DRY - NORMAL
This diagnostic may take approx. 15-20 minutes to complete. Let it proceed through to completion and let me know what happens and we can go from there.
Regards,
Macmarkus :)
Aug 19, 2011 | Kenmore Dishwashers
Green light flashes on clean. Will not run wash cycles. Will drain, Is there a reset button somewhere?
To reset your dishwasher, press the buttons [heated dry] [normal] [heated dry] [normal] to initiate the diagnostic cycle. This should clear the error message from the system and allow it to run again. If the problem persists, check the causes found here : http://bit.ly/gitWix
Mar 05, 2011 | Kenmore 24 in. 17039 Built-in Dishwasher
Dishwasher during normal cycle gets hung up and does not advance
HI. this is just a control fault. you can try to reset the core program by unplugging this unit for 5 minutes. this will drain all power and reset the core on the timer/control.
If you experience the same situation after this reset, simply replace the control/timer module.
Jun 02, 2009 | Kenmore Dishwashers
Kenmore dishwasher
Apr 01, 2008 | Kenmore 24 in. 17482 / 17484 / 17489...
Kenmore Ultra Wash Dishwasher LIghts are blinking....
I just read this for the same problem: push sanitize, then heat and dry, sanitize, heat and dry, sanitize, heat and dry, cancel, then open and close the door. It worked. The dishwasher is running correctly even as I type this.
Feb 11, 2008 | Kenmore 24 in. 17262 Built-in Dishwasher
Dishwashers Logo
580 people viewed this question
Top Kenmore Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
Fred Sops
vince
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
