Question about Lexmark X6150 All-In-One InkJet Printer
Network Printing Issues
We have the 6100 as a network printer in our office. one computer sees it fine and wil print to it, the other will install the drivers and recognise the printer as online, yet no program will print anything. nothing happens. when a test page is printed it works fine. i've tried installing as both a network printer and a local printer, the same happens for both. the laptops are identical, and the first suffered this problem also until suddenly it worke. the second was set up in the same way, but will not work. thanks need to download a disk
  • Simon Vann
    Simon Vann May 11, 2010
    Can you clarify which versoin of operating system you are using.
Have one too, this happened with an x73 when i upgraded from win98 to winXP, It happened with the X6150 when i upgraded to vista. to correct this problem, Get an HP printer and be done with it. I like lexmark because the ink costs less, but if they do not work, they are of no help, Lexmark needs to invest in engineers to write drivers, they will not do so unless we stop buying their good printes controlled by flawed software. Unfortunately, after having installed the latest driver, from their site, on a computer that had never had a printer installed before and was out of the box with all the windows update, it is a LEXMARK problem. Everything else works fine. LEXMARKS problems continue to be an issue. This is my last LEXMARK.
Posted on Jul 10, 2008
Tristan
try saving document to desktop then print it. Sometimes there is info in pdf you don't see. I have had customers that have this type problem and after they save it prints just fine.
Apr 23, 2017 | Ricoh Aficio Office Equipment & Supplies
Tip
How to use a printer?
Install a New Printer DIY installation of your new printer in Windows. You may have a new printer with an installation disc, or maybe a second hand one with no disc. Either way you will find out how to install your printer onto your computer.
Add Network Printer If you have two or more computers in your house or office you will only need one printer installed on one computer for both to have printing privileges. This article shows you how to add a network printer to Windows Vista.
Add Network Printer Applies to Windows XP. Even though the instructions are similar to installing a network printer on Windows Vista, there are a few extra tips that might be interesting.
Enable Printer and File sharing How to enable in Windows XP And Vista. If you want to share a printer on your network you must enable printer sharing. It is not hard to do but it will not work if it is not enabled.
Path to your network printer How to find the path \\server\printer. If Windows does not find your network printer automatically then you will need to know the path to your network printer.
Set Network printer permissions Set who can change printer settings in Windows XP and Vista. I personally like to let everyone on the network just print and not be able to change too many settings to do with the printer.
Network printer has problems printing - You do not have permission to use selected printer.
Quick Printing Trick Cool printing trick for Windows Vista and XP.
on Jan 18, 2010 | Office Equipment & Supplies
Printer takes forever to print
How is the printer connected to your computer(s)?
If it is USB or network. Try a different cables.
Does your computer run slow also? Low disk space can cause print jobs to print slowly.
Network issues can cause slow printing as well. If your printer is on network and there is a mismatch of 10/100 Mbps speed or Half/Full duplex, the printing can be slow.
If your OS is Windows, remove the printer from Printers and Faxes. Uninstall the driver package if installed separately. Download the latest drivers and install them and reinstall the printer.
Apr 15, 2013 | Lexmark MS310dn Monochrome Laser Printer...
HL-2170w won't print with Windows 7
Windows 7 will not work with earlier Windows versions of printers
Feb 28, 2017 | Brother HL-2170W Laser Printer
Networked laptop will not print to any network printer. Getting error message that there may be a memory problem or cable problem. Memory is fine and cable are fine. Others in the office are printing fine....
Do you still have access to the Internet from this laptop? If not your Laptop isn't connecting to the network you won't be able to print. Check and see if your laptop is set to DHCP which will automatically assign the correct IP Address to enable your laptop to connect to the local network. If all this is correct you may have to delete and re-install the print drivers for the printers you want to print to.
Aug 18, 2009 | Office Equipment & Supplies
Can't get psc 1610 to print on new macbook wirelessly
If you install the Hp wireless driver on your Mac, that should do it.
Aug 18, 2017 | HP PSC 1610 All-In-One InkJet Printer
Fs-3900 intermittently not printing
for FS-3900DN the latest firmware is the one what you have. BUT there is a separate update firmware for the Network Card !!
Check if you have installed the latest print driver in ALL computers and the OS updated with the latest patches.
Q1: The printing issue is consistent when you change computers ? IF yes THEN the issue is within the printer or the network.
Then:
Check if you have same issues when printing using the USB (not the network).
IF is printing OK when you use the USB but you got trouble using the network THEN something is wrong with the network printing so:
-> connect the printer straight to a PC/laptop using a crossover network cable that so you bypass the whole network (LAN) hardware.
--> IF is printing OK THEN the problem is within the network hardware(LAN) - you may try to pinpoint by replacing the network cable between the hub/router and the printer.
--> IF printing using the crossover cable is NOT OK then the problem is in the printer's network card. Check if the jack or the cable fit well into the printer or if the connector is not loose.
IF printing using USB is NOT OK then the problem may be into the printer. Reload the firmware engine and system + network card... it may help.
Q2: When you say: "fails to print unless it's powered OFF / ON" you mean the print job what you sent is waiting into the computer print spooler = the printer is being seen as NOT READY ? or the print job is just missing and you have to restart the printer and after that resend the print job ? ou can chack the printer stat by going to her IP address = open any internet browser and type the ip address. You should see a web page. Check the printer status before sending any print job.
Oct 27, 2008 | Kyocera FS-3900DN Laser Printer
Not supports bi-directional printing on win98 + winxp network
this is compatability problem. You should install your printer on Windows XP system. Then make it share for all. I think it will print from both 98 and XP. try this.......good luck.
Thanks
Iqbal
Mar 26, 2008 | Canon LASER SHOT LBP-2900 Printer
Printer doesnt print
Make sure the printer is a network printer. Then make sure the network cable is plugged into the printer and the switch box for all the network computers. If your printer is attached to a computer on the network, then that computer works like the server. The computer has to be on for anyone to access it. Make sure you can see the other computer on you network. Then you have to set the printer up on each of the computers. Make sure you you have your installation software.
If this helps you, please rate me. Thanks, Patty
Dec 28, 2007 | Office Equipment & Supplies
Hi alexredfern, Have you checked that the printer is set to be the default printer on the problem PC?
Nov 14, 2006 | Xerox Phaser 6100/BD Laser Printer
Lexmark X6150 All-In-One InkJet Printer Logo
56 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
