Question about Nintendo Wii Console
Having trouble connecting to wireless internet.
  • 864 Answers
Try this trouble shooting guide and if it doesnt work let me know and will assist you from there. This error code usually indicates a problem relating to wireless security. Please try the following troubleshooting: Are you using WEP or WPA security on your router? Log into the router using the default IP (consult your router's manual for assistance) Locate the "wireless security" section of your router settings and find the WEP or WPA key. If you are using 64-bit encryption, the WEP Key must be a 10-character key consisting of numbers or letters A through F. If you are using 128-bit encryption, the WEP Key must be a 26-character key consisting of numbers or letters A through F. The WEP Key must be a Hexadecimal (0-9, A-F, no other special characters or letters). If your router has multiple slots for a WEP Key, make sure the active key is the one in the #1 slot. If you are using WPA, the Wii console is compatible with the following types: WPA - PSK (TKIP) WPA - PSK (AES) WPA2 - PSK (AES)
If your WEP or WPA key is correct, then the problem might be related to MAC address filtering: From the router settings, locate the "MAC address filter" settings (also known as "access control", "access list", or "network filter" depending on your router model). If the Mac address filter is set to "enabled", then you must add the Wii's MAC address to the "allowed" list. You can locate the Wii's MAC address from the "console information" page (located under "Internet" in the Wii Settings). If the Mac address filter was disabled, then continue troubleshooting.
Check Nintendo's router info for special notes, if available, for your router. Click here to go to our Wireless Router lookup page. Use the drop-down box to select, if available, your router manufacturer. Click on your router's model number, if available. Read any "special notes" at the top of the router's page. Many issues can be solved by changing settings described in the "special notes."
Try a "Manual Setup" with the Wii console (how to), using your network's IP configuration settings. To access these settings: On your PC, click "Start" and then "Run." Type "CMD" into the field that appears to open a new window. Type "IPCONFIG/ALL" and press "Enter" to display a list of internet settings. Locate the settings asked for by the Wii console during the Manual Setup process and enter them.
Power cycle your router and modem by unplugging them both from the wall. Wait a few minutes, and plug the modem back in. Wait a couple of minutes for the modem to initialize, then turn on the router. Try to connect the Wii console online and test for proper response. if you require further assistance please let me know and i will be glad to assist you. -Midwest-tek
Posted on Aug 27, 2010
Having trouble connecting my wii to the internet so i can use netflix
Here are step by step instructions on connecting your Nintendo Wii to the internet. Please note you must have a wireless internet connection available to you, the Nintendo Wii only connects to the internet via wireless signal.
http://www.nintendo.com/consumer/systems/wii/en_na/getOnline/index.jsp
Sep 04, 2011 | Nintendo Wii Console
My router works fine with a cable pluged into the computer, but when i unplug the cable to access the wireless internet it will not pick up any wireless connection. sometimes it will have the connection...
You should reset your router by sticking a pin in the pin hole on the back.
Once reset, reconnect a LAN cable and then reconfigure the wireless network.
If you keep having trouble connecting, try changing the channel your wireless network is being broadcast on.
Mar 26, 2010 | NetGear WGR614 Wireless Router
Im having trouble i cant get on the internet unless im pluged in
IT seems that the wireless connection might not be connected.
if you facing trouble connecting to the wireless network using the wireless adapter utility then you can switch over to windows utility .
Sounds difficult !
It is very simple Click Here for more info about wireless connection problem
Oct 17, 2009 | Linksys WUSB54GC 802.11g/b Wireless...
Setting up Netgear Wireless-N router
try this plug up a line to laptop to modem to check to see if you can get connected if so then make sure you are on the same network and if so then call comcast to help you setup the laptop wireless settings in sound like the settings online doesn't have the laptop enable to accept the laptop
Dec 01, 2008 | NetGear WNDR3300 - RangeMax Dual Band...
Internet problem
It could be several problems:
1. Your wireless router misconfiguration.
2. Your wireless router is bad
3. Your wireless card misconfiguration on your laptop
4. Your wireless card is bad.
If you never had problems with your wireless connection before and you haven't change configuration on your router or your laptop. I have seen and repaired this problem by replaceing wireless router.
Good luck!!!
Jul 04, 2008 | Computers & Internet
Computer cannot access the internet
Try to disable wireless card on your desktop. With both the wireless and cat-5 socket enabled, "WITHOUT" the proper bridge settings, they will conflict and not be able to read.
Apr 07, 2008 | Computers & Internet
Internet connection
1. Change channel used by Access Point
2. Try to set up router to different security, this problems may happens for WPA authentication.
Mar 25, 2008 | D-Link Wireless
Internet connection
are other wireless devices able to connect? or is it just the laptop that is wireless?
Dec 13, 2007 | NetGear Super G WGT624SC Router...
Nintendo Wii Console Logo
22 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Bee Santiago
Raj Patel
Martin Murray
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
