Question about Garden
I have a poulan pro 42 inch with the 18.5 horse briggs and stratton intek the motor runs good for about 15 minutes and then just quits???? I checked the oil, cleaned the air filter, replaced the inline fuel filter, pulled apart the carb. and cleaned it,dumped all of the fuel and cleaned the tank and still the problem persists. I am fresh out of ideas if someone could help that would be great. Thanks Scott
  • 33 Answers
When it quits remove the fuel line from the fuel pump to the carburetor and check if the pump is pumping gas while you turn the key to the start position with the brake locked. You could have a bad ignition coil.
Posted on Jul 30, 2017
  • 1847 Answers
SOURCE: Briggs and Stratton 17HP Intek Governer Overspeeds
Can you Regulate the Engine Speed Using the Governor Arm? If Yes, then Reset the Governor. **To Reset the Governor; Loosen the Governor Arm Bolt and Turn the Governor Shaft Clockwise Until it Stops. Using the Governor Arm Hold the Carburetor to Full Throttle. Now with the Shaft Full Clockwise and the Governor Arm and Carburetor Held at Full Throttle, Tighten the Governor Arm Bolt. If the Engine Still Runs Full Throttle, then Reverse the Rotation of the Governor Shaft, but Still Hold the Carburetor at Full Throttle with the Governor Arm. If it Still Runs at Full Throttle, then Check the Internal Governor.** If you Can Not Regulate the Engine Speed Using the Governor Control Arm, then Check the Carburetor Throttle Valve. If the Throttle Control Valve (sometimes called a Flap or Plate) Mounting Screws Came Out of the Control Valve, then you will have No Control Over the Engine Speed. Send me the Model and Type or Spec Numbers Off the Engine, Please. With these I can Locate the Proper Manual and Better Assist you. **The Throttle Cable Attaches to the Throttle Control Bracket. The Cable Moves a Slide that Moves a Pivot. The Pivot has the Spring Attached to it and to the Governor Arm. The Solid Link Connects to the Governor Arm and goes to the Throttle Shaft on the Carburetor. When the Throttle Cable is Moved it Moves the Pivot and the Pivot Pulls the Spring. The Spring Pulls the Governor Arm and the Governor Arm Moves the Throttle Shaft. Usually the Spring is in the Lower Hole in the Governor Arm and the Solid Link is in the Top Hole of the Governor Arm.** If you Hit a Snag or this Does Not Correct the Problem, I am Here if You Require More Assistance. Hope this Helps. Let me Know What Happens
Posted on Sep 24, 2008
  • 1124 Answers
SOURCE: Poulan Pro 18.5 HP Intek engine trouble
Might be fludding..
If there is a bowl on the carb, pop it off and check the float.. Check for fluid inside the float. If the float is holding any fluid - its bad..
Srpay carb cleaner in there..
Clean the bowl..
Posted on Jul 09, 2009
  • 10865 Answers
SOURCE: need head bolt torque for Brigges Stratton 18 Hp
210 to 230 inch pounds. Torque in a crisscross pattern upper left lower right upper right or left or right.
Posted on Jul 10, 2009
SOURCE: craftsman lt 1000 wont stay running
Take a paperclip and clean out the small hole on your gas cap. And yes I am being serious.
Posted on Aug 25, 2009
SOURCE: Craftsman 16.5hp 42 in. Mower runs for about
I am having a problem with my lawn tractor similar to what you describe. Mine runs fine for 15 to 20 minutes and then stalls. It will start back up and run for a few minutes and then stall again. When it stalls it is like when you get off of the seat with the blades engaged. I have replaced the gas and fuel filter and have cleaned the carb and air cleaner with no effect on this problem. I am now thinking that the problem is the fuel stoper located at the bottom of the carb. There is a plunger screwed into the bottom of the carb bowl that is held down when the key is turned on. If you get off of the seat when the engine is running and the brake is not on or the blades are engaged the stoper is pushed up into the main jet fuel path causing the engine to stall. I am going to fabricate a heat shield around this plunger to see if this corrects the problem.
Posted on Jun 25, 2010
Poulan 17.5 ran good for about 15 minutes then slowly lost power then stop
Let's hope that it did not run low on oil. Check oil level and condition of oil. If oil looks good, then I would check and see if fuel filter is not clogged. A restricted fuel filter will slowly starve an engine from fuel causing it to slowly lose power and eventually stall out. Make sure your gas tank is free of contaminants as well. Hope This Helps.
Aug 26, 2013 | Poulan 42-Inch Steel Deck 17.5 HP Briggs &...
22 hp b/s won't stay running
check spark make sure its bright blue but sounds like a dirty carb needle valve isnt opening enough not letting enough fuel in
Jun 25, 2012 | Briggs & Stratton Briggs Stratton Intek V...
Won't stay running
I took the carb apart and found that it needed rebuilt, I installed the new carb and fuel pump kit and it runs great again.
Apr 05, 2010 | Briggs & Stratton Briggs Stratton Intek V...
Need head bolt torque for Brigges Stratton 18 Hp
Jul 10, 2009 | Garden
Runs for 25 minutes then shuts down like its out of fuel
try taking the plunger off the fuel shutoff solenoid on the bottom of the carb
Jul 01, 2009 | Poulan 42-Inch Steel Deck 17.5 HP Briggs &...
Same problem: tapping carbureator with golf putter gets me more..
The model number should be 31C707-0005-G1. This should help you get a carb. Probley just as cheap as a kit.
Jun 03, 2009 | Poulan 42-Inch Steel Deck 17.5 HP Briggs &...
Garden Logo
54 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
