Question about Nikon Coolpix 5700 Digital Camera
Speedlight in closed position.
Hi when i click to take a photo the flash doesnt open/work and these words come up on screen saying 'speedlight is in closed position'. how do i fix it? thanks
    Master:
  • 619 Answers
Hi , press beside the two small button the plash bulb will open and then click for taking picture.
Posted on May 18, 2008
I was doing a photo session with my Speedlight SB-16 and the flash suddenly stops working. I put in brand new batteries and nothing. The flash button says its charged and I hear it charged up, but all I...
The Flash filament inside is probably burnt out and needs to be replaced.
It will still sound like its charging but there wont be any light because the filament is burnt out.
thanks,
G.
Aug 03, 2011 | Nikon Speedlight SB-16B TTL Flash
Coolpix 5700 pop up flash is saying "Speedlight in closed position" when it's not. Therefore, it will not flash. I attached an external speedlight, SB-22s and got the pop up to at one point...
Yo have an internal switch or control unit issue.A switch which is either a solid state controller or a mechanical which has failed which is why you are getting the error message.To DIY this will require a lot of patience and self control for the parts are really delicate or fragile to work with.It will need a camera technician and tools to get work right.And not to mention electric shock when you get near the flash unit area.
Jan 30, 2011 | Nikon Speedlight SB-22S TTL Flash
I just purchased a Rebel T2i and a 580EX II Speedlight. After approximately 50 flash photos, the speedlight shifts slightly to the rear and it appears the contact between the speedlight and camera...
It would appear to me that the flash was not locked in position and has move back on its mount which would cause the flash to go into complete manual mode or loose complete communications between camera and flash.
I would suggest shutting the camera and flash off remove the flash first unlock the little locking leaver on the bottom. The 580EX and the 580EX II differ in that the 580EX II has a leaver rather then the huge locking screw. Once apart reinsert the flash unit back into the camera hot shoe making sure that the forward edge of the flash mount is seated as deep into the Hot Shoe as possible and lock it into position. It should click into lock position. Biggest thing I have with my "crew" is when there is a flash installed on the camera they pick the camera/flash unit up by the flash that's a real bad thing cause the flash mount is light plastic and it'll ether break, twist or even unlock the flash enough that the camera falls off of the flash. Pick the assembly up with both hands lens and body. I'm not saying you are doing this but when my crew/working associate's do this I'm not happy.
Although that new switch idea is great it also can be unlocked without noticing.
Diagram
Jan 06, 2011 | Canon Speedlite 580EX II TTL Flash
How I can reset factory set from Nikon Speedlight SB-600?
To reset your Nikon Speedlight SB-600 you need to press Mode + ON/OFF, both buttons simultaneously for approximately 2 seconds to reset all settings, including the custom settings (except the distance unit selected in m/ft) to their default values.
If this doesn't work for you, please comment and let me know, and I will be more than happy to assist you to further resolve your issue.
I will appreciate your feedback and positive rating for this free solution.
Oct 01, 2010 | Nikon Speedlight SB-600 TTL Flash
Flash not working, but every thing an the flash is working
Have you perhaps set the flash to remote mode by error. Have a look at the back screen when its turned on, if it says remote you must hold the sel button for a few seconds, press it again briefly then scroll up to the off position, your turning off the remote activation, not the flash when yo do that.
Jan 22, 2010 | Nikon Speedlight SB-600 TTL Flash
I changed the batteries and continued to take photos when i noticed that the screen was flashing on and off and then going to standby mode. tried resetting back to default but screen still flashes. flash...
Hi Bill,
You are not using this flash like a sub-machine gun, right?
Is your reachargeable batteries older than 15 months?
Try this:
Set to low power on flash, set flash to manual.
Remove flash from hotshoe.
Fire the flash by pushing the flash button for 3 mins, same problem(s)?
atdlee@netzero.com
Jan 17, 2010 | Nikon Speedlight SB-600 TTL Flash
My flash is firing, but my photo is not recording the flash output. The photo is dark as though there was no flash.
  1. Make sure the contact on the flash and the top of the camera are clean.
  2. Check the exposure compensation (+-/-) on the camera and flash. It should be set to 0.0
  3. Make sure the camera is set on P, A or S or manually set to the correct synch.
  4. Make sure the camera is compatible with the flash.
  5. Check camera lens function to make sure the aperture is opening and closing correctly. Some older lenses (AIS, AF or non-G lenses) will need to have the aperture locked on the largest f number.
  6. Make sure the lens is compatible with the camera.
  7. Take lens cap off camera
If none of this works take everything to a local camera shopp for them to diagnose the problem and send off for repair.
Nov 15, 2009 | Nikon Speedlight SB-600 TTL Flash
Random pictures
Check in the user guid for your camera about their recomended shutter speed setting for the flash.
Try using the camera and the flash in "A" (automatic) to start with.
Jerry G.
Feb 15, 2008 | Nikon Speedlight SB-600 TTL Flash
No Flash & "Speed light is in the close position"
I had the same problem and found a solution at http://photo.net/bboard/q-and-a-fetch-msg?msg_id=0089WF
It worked for me.
There are 3 simple solutions which will not cost you anything. I used the first method for 1+ years till I discovered the 2nd and 3rd method just now, which should solve your problem easily for good (hopefully).
1. After the speedlight pops up, use your hand to touch (depress softly and let go softly) the button that normally locks the speedlight. To find this button/protrusion, look carefully in the region from which the light pops up. You will see a tiny black piece protruding out. This piece matches the cavity on the back of the speedlight. So it should be easy to find. Try pressing the button and then letting it go. If the error message doesn't go away, try pressing it once again and then check the monitor again. This method may take several tries.
2. A simpler solution is to use your hand to slow down the speedlight as it pops up. The goal is to prevent a violent shake when the speedlight unit pops open. So use your hand to let the unit slowly come to open.
3. A more permanent fix is to put something in the camera to cushion the shake as the speedlight pops open. If you look carefully how the speedlight opens, you will see that there is a plastic rod, one end of which is attached to the speedlight and the other end glides along a track/groove as the unit opens. Just put some sticky soft substance at the end of groove where the rod will come to rest when the unit opens. Put such substance there so it will "permanently" cushion the opening. One such substance you can find easily is the type of glue many magazines use to stick ads/CDs,etc. to the pages. As far as I know, you CANNOT get such glue easily in stores, but those used sticky glues in magazines are good enough and you just need a tiny bit. I happened to have bought some such glues recently from http://www.gluefast.com/catalog/product_info.php?cPath=21_27&products_id=28
for no other reason than that I have always been fascinated by such glues. You really don't need to buy these because they come in large quantities and you can just use the magazine glues I mentioned. (some call these "peel and stick glue" and some call it "fugitive glue".) Yet another possibility that should work but might not provide as much buffering/cushioning power is to cut a tiny piece of eraser that fits tightly into the end of the groove.
Hope these belated tips help you somehow.
Jan 31, 2008 | Nikon Coolpix 4500 Digital Camera
are the contacts corroded or bent?
Oct 01, 2007 | Nikon Speedlight SB-600 TTL Flash
Nikon Coolpix 5700 Digital Camera Logo
480 people viewed this question
Top Nikon Cameras Experts
Steve
Are you a Nikon Camera Expert? Answer questions, earn points and help others
