Question about Power Health Scooter Wheelchair Programmer Ds100 Dynamic Rhino Power
Rascal 325 won't move. Lights and horn work. When first tried to move chair motion eratic. Now won't respond at all. Batterys charged. Power to DS100 Ok. Yellow flashing light. No voltage at output of DS100 while manipulating throtle. Unit had set for some months...
2 Suggested Answers
gewiz
  • 1271 Answers
SOURCE: my mobility scooter ('rascal' i
hi, the six flashes indicate a speed pot issue, the pot is not in centre position when you turn the scooter on, it a case of looking at the cross thread on the bottom of the stem and making sure that it is centre to you when sitting on the scooter or use a multimeter to get a 2.5 to 2.7K ohms centre reading.
Regards GewizRepairs
Posted on Jul 26, 2011
Testimonial: "the speed pot had got a little moisture in there i suspect and the vibration from the corrugations hadn't helped either. I pulled it apart and cleaned"
Chair won't move..lights flash continuously
You may have locked it by holding the power button . try turning it on then hit thee horn 2 times . That should unlock it.
Jul 16, 2014 | Jet 3 Ultra Power Chair
When I turn it on the indicator lights flash but the chair will not move
The number of lights lit and/or the number of times they flash help determine what the problem is, and there is a chart for that in the manual. If you have lost yours, you can find one online.
Mar 20, 2014 | Pride Jazzy 1103 Ultra Standard Power...
All lights flashing, won't stop, won't respond (although the horn beeps).
joystick is locked,press the horn twice in ten seconds and hope this helps u
Dec 20, 2013 | Pride Jazzy 1103 Ultra Standard Power...
Rascal 600
Neil wood, the Rascal 600 DOES use an on board charger. What signal is the white wire looking for to make the scooter move is the question. 28v?
Apr 20, 2012 | Electric Mobility Power Electric Scooter...
The power indication display is flashing with all colors visible.
The flashing will come on if the chair is in neutral or if the charger is still plugged in when you turn it on. Place the chair in neutral (freewheel) by shifting the levers out, then place firmly back into drive.
Unplug from the charger and it should fire up. Sometimes, the chair will also go into "sleep mode".
Check your owners manual for this. Note, some have sleep mode potential but it's not in the manual, and if someone inadvertantly hits the right series of motions with the joystick, you can inadvertantly put it to sleep. Try turning the chair off, wait three seconds and power back up, then immediately press the "horn" button. This wakes up most of them. Others you need to power off, turn back on and then move the joystick forward, backward then forward again.
Good luck
Jun 23, 2009 | Electric Mobility Power Electric Scooter...
My Jazzy won't move.
If your batteries are truly charge they should read around 24.5 VDC. And if the freewheel lever is engaged and you still have no movement your probably need to get into a service tech. Also check the circuit breaker on the chair.
Mar 31, 2009 | Pride Jazzy 1113 ATS Indoor Power...
Power Health Scooter Wheelchair Programmer Ds100 Dynamic Rhino Power Logo
250 people viewed this question
Top Power Health Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Power Health Health and Beauty Expert? Answer questions, earn points and help others
