Question about Health & Beauty
How can I change the age on my Tanita B-534 scales
SOURCE: I have a tanita tbf-612
Press the Set and Up Arrow buttons at the same time. Release the buttons, the display will flash. Press the Arrow button to cycle through each weight mode until just the mode that you require is displayed. Then press Set. The display screen will flash to confirm your selection and store in memory.
Note: If weight mode is set to pounds or stone-pounds, the height programming mode will be automatically set to feet and inches. Similarly, if kilograms is selected, height will be automatically set to centimeters.
Posted on Mar 14, 2009
SOURCE: Tanita, the Ultimate Scale
The scale may have instructions on the bottom of the scale. (Example for the Tanita: The Ultimate Scale w/ the body fat analysis). The instructions on the back state the following steps: Step 1: press both the "Set" and the triangle buttons. Step 2: press the "triangle" button until you select the appropriate weight measurement (a) kilogram, (b) stone lbs or (c) lbs. Step 3: press the set button.
Posted on Nov 20, 2008
SOURCE: How do I set Tanita digital scale with 2 memory
Go to www.Tanista.com/ProductManual/PDFs/2001_manual.pdf
This should provide the answers you are looking for.
law4644
Posted on Jan 21, 2009
SOURCE: Scales show weight in kg. How to get them to show lbs.
Body Fat Monitor/Scales: TBF-611, TBF-612, TBF-621, TBF-622, BF-541, TBF-560, TBF-572. UltimateScales: 2000, 2001, 2001T. BF-662, BF-555, BF-556, BF-558, BF-559, BF-625, BF-626.
SOURCE: Tanita Ultimate Scale 2001 - no user manual -how to set it?
does your scale have an orange SET button and a button with a triangle (or arrow) below the display?
Try this... make sure the scale is turned off. (and you are not standing on it)
Now press the SET button.
2 arrows should appear on the display. use the arrow/triangle key below the display to make changes and the SET key to choose.
If you have the same scale as me, you are prompted to chose Adult/Child followed by Male/Female, and finally input your height in feet/inches by pushing the arrow/triangle key until the display shows the desired height.
Press SET to finish and step on the scale like you usually do. It will now show your weight followed by your body fat %.
Hope this helps you!
Jacob
Posted on Jul 14, 2009
Delete User Info -
Look for your manual online and it might give you the answer
Jul 10, 2012 | Tanita BC-534 InnerScan Body Comp Scale
Need the instruction manual for the Tanita BC 534
how do you remove the glass on the printout section to clean it
Sep 22, 2011 | Tanita BC-534 InnerScan Body Comp Scale
Tanita BC 543. I need to clear the memory held under buttons 1-4 to allow new people to use machine and update age etc
leave the scale off, and only press "set".
the scale will flash "1234"
choose your number with the ^ v arrows and press set.
all options will then be open to be set.
Jul 09, 2011 | Tanita BC-533 InnerScan Body Comp Scale
On my Tanita BC-534, I just changed the batteries but now continually get "Lo" in the display. So tested batteries and even tried other batteries, but still get the same message. Please let me...
Hi BJ,
Welcome to fixya!
According to the manual, "Lo" indicates weak batteries. Since you changed batteries, my next question would be... Did you buy fresh batteries at the store or use ones you had at the house? Check the freshness date on the battery package. Sometimes even some of the ones you get in stores aren't fresh enough.
Since you get enough power to get "Lo" reading, but not enough for anything else, this sounds like a battery problem.
Did you check the contacts in the battery compartment? Sometimes cleaning them with a pencil eraser will help make better contact. Also, be sure the springs are tight enough. If they are the tab kind, you can bend them out a little for a tighter fit.
If all else fails, here is the contact page for Tanita: http://www.tanita.com/en/contact-customer-service/
They should stand behind their products.
Hope this helps. If it does, I'd appreciate your vote. Thanks,
Handie Andie
Jun 26, 2011 | Tanita BC-534 InnerScan Body Comp Scale
Change settings. model #2202/UM-016 I have lost the directions and can't figure out how to change my persona settings. In an attempt to change my age I changed my *** and can't change it back.
I searched into this site with the same problem, how to update/reprogram the UM 016.
I figured out how to do it, shame there\'s no mention of updating memory data in the Tanita literature.
Assuming scale has batteries and old settings.
Press \'set\' button instead of memory or guest. The \'1\' memory should appear and blink. If you want to reset the \'2\' memory, press up key until the \'2\' appears and blinks, then press \'set\' again.\'
When you press \'set\' while the memory location is blinking, you should be able to page through and change the age/height/sex settings for the scale memories. When you are done, the scale will eventually shut down, saving your new settings, which you access with the \'up\' button when you want to use the scale.
Oct 19, 2010 | Tanita Digital Body Fat Scale with 2...
Need to reset scale bf-681 tanita scale
I have a tanita body composition scale BC-534. It suddenly stopped working. I have new batteries. Is there a way to reset the digital disolay?
Jan 12, 2010 | Tanita Bf681 Body Fat Monitor Scale...
CALIBRATING A TANITA KD-200-110 DIGITAL SCALE.
According to Tanita, you must send the scale back to the factory to adjust the calibration. As of September 2011 the cost is $125.00
This is more the scale costs.
Moral of the story. Don't buy Tanita.
Aug 24, 2009 | Tanita 1479V - Digital Pocket Scale /...
Need to reprogram my age and activity level
www.tanita.com/manuals/BC-534(1)_manua.pdf
go to that address and download the manual for free. it will tell you how to reprogram the scale.
Jan 03, 2009 | Tanita BC-534 InnerScan Body Comp Scale
Health & Beauty Logo
118 people viewed this question
Top Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Health and Beauty Expert? Answer questions, earn points and help others
