Question about Denon AVR-3300 Receiver
Hi I just bought a new denon 3211 after i installed it it worked fine the first day , today when i siched it on there is no audio from the received only video is coming, there is no sound from the spk, I have attached it to Jamo 606 Spk , sub 300, there is only audio when i sich it to tuner, that also direct, no other out. could you let me know what the problem is and how do i reselove it
SOURCE: Denon reciever avr-487
If your tv is putting out mono you will only get the center and sub speakers. This can be because the tv is only mono, or the output is set to mono in a menu of the tv. If you have cable or sat run the digital audio out to you receiver; it usually sound better that way anyhow. Set your receiver to Dolby mode for best sound.
Posted on Aug 27, 2007
marsrover
  • 682 Answers
SOURCE: Mac Mini and Denon 3801
http://www.retrevo.com/samples/Denon-Receiver-manuals.html
Posted on Aug 09, 2008
  • 18 Answers
SOURCE: connecting 2 sub woofers to denon 1506 receiver
Most receivers only handle one sub at a time. If you are deadset on connecting two, you might want to consider how much power your receiver will give to each if you split the signal then determine the power of each sub. If the subs aren't the same you can be sure they will sound strange.
If they are identical and your receiver has enough power to handle them both, examine the connection the subs use to connect to the receiver and split the connection by buying a splitter at a local radioshack.
You will probably be better off using the better of the two subs instead of having both connected. Your sound quality will be more balanced and clear when it comes to bass.
Posted on Mar 03, 2009
landsend
  • 1066 Answers
SOURCE: Subwoofer Connection Problem
why don't you both return these units and call Denon for replacements without these problems?  Sqeaky hinges get the oil.
Posted on Apr 01, 2009
SOURCE: No audio running TV through Denon AVR 1910
I had the same problem. You're not doing anything wrong. the thing is you can't (I don't know why but the owner manual says it) have sound going to your tv AND your HT speakers when you're using HDMI. You should try going to input setup, choose hdmi audio out to your TV instead of the speakers, and then run an optical cable from your satellite to your receiver, assigning it to the TV/Cable input.
Posted on Jan 20, 2010
No picture with cable to denon AVR-589
Long and painful answer!!! However, in the end, you need to bypass HDMI thru your receiver and go direct to the TV. Connect Digital Coaxial or Optical for audio to your receiver. Your version of HDMI in your receiver is not compatable with today's HDMI version. Yours is 1.1a and the current version is 1.3b going to 1.4. If you want detailed info as to "why", just google "HDMI 1.1 problems" you can read for hours! Sorry for the bad news! However, it is what it is. Hope this helps. If you need further help with setup, post a comment and I can give you further help.
Feb 28, 2010 | Denon AVR-589 Receiver
Power wont come on at all
May be the power supply check for power to the power supply and the output voltage from it as well !! May need to be replaced ! It cost $125.00 for part and $225.00 for a new one installed !!
Jul 21, 2009 | Denon AVR-1506 Receiver
Denon AVR-2309C1 will not play sound through
Turn off zone 2 then turn your receiver on the main zone on Radio, tune in a station and check for audio. Post a comment and let me know if audio works that way. If you don't have any audio, list your other equipment makes and models as well as how they are interconnected to your receiver (cable type) and I will help you troubleshoot
Jun 28, 2009 | Denon AVR588 Receiver
How do i connect my denon RC7000CI to denon amp. 2801
I cannot access the setup menu on the unit display or via the s-video monitor out -- everything was working fine a few days ago. I have reset micro, unplugged all night, reset again, and still cannot get to the menu in order to correct connections, esp for digital. My problem is on the avr5600 but seems like this happens on many of the denon units
Mar 03, 2009 | Denon AVR-2801 Receiver
Denon 1508- no sound but smoke.
perhaps u might consider going to a(n) (unauthorised) repair centre. just check with folks around u or maybe audio forums within your area. authorised agent doesn't always mean the best. i suspect they may have used reconditioned components.
Aug 31, 2008 | Denon AVR-1508 Receiver
Connecting DVD player to AV receiver
If you've done that already and still no response from your system, I would suggest to take back to the place where you bought it and ask them to check it for you. Tell them that you follow the user's manual to the "T" but still unable to make it work.
Good Luck.
Jun 20, 2008 | Denon AVR688
Connecting Denon receiver to DVD player
Normally the optical inputs are disabled unless specifically turned on. I dono't know your specific model. I'll research the model and update this with more specifics.
Dan
Jun 17, 2008 | Denon AVR588 Receiver
Denon AVR-1802
might hav eto buy new control modual parts store hi end parts store order one for u
Jan 25, 2008 | Denon AVR-1802 Receiver
Denon 2902 No Sound
REPLACE MUTING TRANSISTORS IN DSP PANEL
Sep 04, 2007 | Denon AVR-2802
USB DURABRAND UC-280 SPEAKERS DO NOT WORK
I just bought them today they work fine. You do have to have a high speed 2.0 USB port to plug them into.
Aug 15, 2007 | Denon AVR-2802
Denon AVR-3300 Receiver Logo
195 people viewed this question
Top Denon Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Denon Audio Player and Recorder Expert? Answer questions, earn points and help others
