Question about Samsung 1000W 5.1-Ch. Home Theater System with Upconvert DVD Player
Samsung HT-Z320 WON'T PLAY DVD, THE UNIT WON'T PLAY SOME OF THE DISNEY DVDS LIKE TARZAN 2 AND OTHERS. WILL PLAY DIZX AND OTHER DVDS. I CAN TAKE SAME DVD AND INSTALL IN OTHER SAMSUNG DVD PLAYER AND IT WILL PLAY. ONLY SOME DVDS WON'T PLAY. DOSN'T MATTER IF DVD IS NEW WITH NO OR LITTLE SCRATCHES.
SOURCE: Connecting LG 42PG20 TV to Samsung HT-Z320
output on TV cable digital reciever to home theater digital reciever in via an optical cable.lower the volume on the TV cable digital reciever to get the most out of the surround sound system.
Posted on Oct 20, 2009
dunnbiker
  • 8546 Answers
SOURCE: Just bought a Samsung ht-z320. I used the hdmi
How is the cable box audio connected to the Samsung? That is where the sound comes FROM. HDMI carries signal TO the TV.
The single optical digital input is a limitation if you get HDTV through cable. You probably use it for the DVD.
I found this quote from the manufacturer's propoganda, "deliver the greatest impact from all your digital media". Yeah, all ONE hardware source of it.
You could manually attach the optical output (if it exists) of the Cable Box to optical input on the Samsung for multichannel-audio TV viewing (listening). OR, you could run the RCA L&R analog audio outputs out of the Cable Box into one of the Aux Inputs, but no actual surround will be produced.
Posted on Dec 27, 2009
SOURCE: My Samsung HT-Z110 does not play any DVD's anymore...
check if the cds works if they work you need to replace the motor disc spindle
Posted on Jan 11, 2010
  • 5 Answers
SOURCE: why won't the samsung blu ray players play all blu
Software on blu-ray players need to be updated occasionally. You may need to visit Samsung's website for instructions on updating the software on your player. This may be as simple as downloading a file or requesting an update disc.
Posted on Feb 13, 2010
SOURCE: HT-Z320 displays PROT code and then shuts down
i had the same problem a prot display then it would shut down. turns out i had the sub disconnected(noise complaint from the shaking at my apartment complex) but the speaker wires for the sub connected to the amp or central unit. when i disconnected the sub i left the wires on the floor behind the sub separating the pos. and neg. somehow the wires got moved around and the pos was touching the neg. as soon as i noticed and fixed this problem the system was working fine. my samsung hometheater model is HT-BD1250
Posted on Apr 08, 2010
What does FanChck mean on my samsung HT-Z320? How to I fix it?
I had the same problem with my Samsung HT-BD1250. In my case the fan did not run at any time! As a safety precaution, to prevent overheating, when the fan is malfunctioning the receiver powers off. I simply opened up the receiver and discovered that the fan was not even connected! I just plugged it in and.....Voila! Works like a charm. Be warned though that if your unit is still under warranty, opening it up will likely void the warranty.
Feb 07, 2010 | Samsung HT-Z310T Theater System
Dec 29, 2009 | Samsung HT-DB120 System
I have a Samsung HT BD2 region 4, I go many region 1, they wont play, how can I make it play?
To unlock the DVD code its defends upon what region you belongs or from were you bought the DVD unit. Just click this site to hack the region code ; http://www.videohelp.com/dvdhacks
To keep it simple, this means that DVD players and DVDs are labeled for operation on within a specific geographical region in the world. For example, the U.S. is in region 1. This means that all DVD players sold in the U.S. are made to region 1 specifications. As a result, region 1 players can only play region 1 discs. That's right, the DVDs themselves are encoded for a specific region. On the back of each DVD package, you will a find a region number (1 thru 6).
The geographical regions are as follows:
REGION 1 -- USA, Canada
REGION 2 -- Japan, Europe, South Africa, Middle East, Greenland
REGION 3 -- S.Korea, Taiwan, Hong Kong, Parts of South East Asia
REGION 4 -- Australia, New Zealand, Latin America (including Mexico)
REGION 5 -- Eastern Europe, Russia, India, Africa
REGION 6 -- China
REGION 7 -- Reserved for Unspecified Special Use
REGION 8 -- Reserved for Cruise Ships, Airlines, etc...
REGION 0 or REGION ALL -- Discs are uncoded and can be played Worldwide, however, PAL discs must be played in a PAL-compatible unit and NTSC discs must be played in an NTSC-compatible unit.
The end result is that DVDs encoded for regions other than Region 1 cannot be played on a region 1 DVD player, also, players marketed for other regions cannot play region 1-stamped DVDs
Hope it may help you;
Regards;
VOTIT
Jun 08, 2009 | Samsung HT-BD2R 7.1 Channel Blu-ray Home...
My samsung ht-dt200p won't play newer dvds
Please provide the full details of which type of dvd it is not playing? and the dvd is having any region restriction?
So please provide the full details to get the solution.
Mar 29, 2009 | Audio Players & Recorders
Truflat tv/dvd will not play disney dvd
Check the rca guide too see supported formats and check to make sure the disney dvd matches that format.
Feb 02, 2009 | RCA 27F530T 27" TV
Samsung home cinema system HT-THX25 Multiregion hacks
Turn on the HT with no DVD. Press the following buttons on the remote: ENTER 8, 4, 2, 6, 9 ENTER
It will turn off. When turned again on it is a region free HT.
Feb 02, 2008 | Samsung HT-X20 Home Cinema 600W Theater...
Samsung HT-P38 won't play DVDs but plays CDs just fine
I called Samsung. They told me how to do a software reset and solve the problem
1. Take out all CDS.
2. Turn off and then on.
3. HOld down stop for 5 - seconds.
Problem Solved!
Apr 11, 2007 | Samsung HT-P38 System
Samsung 1000W 5.1-Ch. Home Theater System with Upconvert DVD Player Logo
311 people viewed this question
Top Samsung Audio Players & Recorders Experts
Electro Med Services...
Electric Dime
Electric Dime
Are you a Samsung Audio Player and Recorder Expert? Answer questions, earn points and help others
