Question about Intex QUICK-FILL ELECTRIC PUMP, AC 110-120 VOLT
Model 58627 trying to get casing open to find out if fan blades are broken, how do we get it apart
How do i take the fan blade off the motor that its connected to for my gateway laptop model : M-1634u
No. replace the fan if it has been damaged otherwise clean with a dry paint brush and a vacuum cleaner.
Oct 01, 2016 | Gateway M-1634U (LX.W090X.001) PC Notebook
Model HSS25GFTA, replaced control board and unit is working, the fan in bottom right of unit has not come on. Blades are not free spinning but are not frozen. Have checked all electrical connections by...
some fans in ref are dc volts some are ac volts.
send whole model # for proper diagnostics.
either fan is bad or your not getting power to it.
main computer board or fan poss. broken wire
Mar 06, 2015 | Hotpoint Refrigerators
Need a 42" white ceiling fan blade
I would need to know what fan ( make/model) you have. Is the blade broken or the blade holder?
Apr 12, 2013 | Dryers
Cordless 18 volt lithium ion sawzall hums and clicks blade wont move
I don't know what model you have but Milwaukee sawzalls use a wobble shaft and wobble plate to turn the rotary motion of the armature into the reciprocating action of the blade. If you motor is working (hums?) but the blade won't move one or more of these parts are broken and hitting eacher (clicks?) inside the gear case. You or a repair center will have to take the gear case apart to find our what's broken and determine whether it's worth repairing.
Jan 27, 2012 | Milwaukee Tool Saws
I NEED INSTRUCTIONS TO TAKE APART FOR CLEANING
I have a similar model to this one. It's a little tricky. Everything snaps or twists together. Press a little on the front and back of the fan grills and twist lefty loosy to open. The blades are an easy detachment, just pull them out easily, and take off the back grill. The back grill may have two screws connecting it to the main case of the fan, but mine didn't.
Aug 17, 2011 | Lasko 2506 16" Table Fan
Sawdust does not collect in bag but remains on wood that is worked on. Have tried to locate problem (probably blockage but have not found cause or remedy)
Best way to clear the vacuum path: remove the sanding belt and collection bag. Use an airhose to blow compressed air through the opening where the bag attaches to blow out anything that may be in the airway. After blowing through the outlet, check around the rear of the drive pulley for any wood that may have to be picked out. Reattach everything and try it again. If it still doesn't work, the vacuum is driven by a fan on the end of the armature. You'll have to take the case apart and check that to see if the fan blades have broken off or the fan has come lose from the armature.
Oct 12, 2010 | Makita 9404 4'' x 24'' Belt Sander
My mom's Kenmore HE3 Elite electric dryer vibrates rapidly while operating. She was cleaning out the lint catcher area with a toothbrush and dropped it inside, then decided to run it after several failed...
yes u have to now replace the blower fan housing u may be able to take apart and remove broken piece byt may not run properly or circulate heat and air as it suppose to
Mar 22, 2017 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
Fan does not come on
This will take some work, and some elbow grease, but what happened is the motor bushings most likely seized. Try turning the blades with your hand. If they are stiff, the bushings are seized. What you will have to do is take the fan apart. First by removing the blades, then by taking the motor off of the frame. Then depending on the type of bolts/ screws that hold the motor together, remove them. Then split the motor apart by taking a flat blade screwdriver and sliping it between the two pieces of the motor and turning it so they slip apart. then once the motor is apart, shine up and clean the motor's shaft so it is clcan and shiny. then do the same for the bushing/ beringholes in the motor's casing. then drip some oil in the berings, and on the motor shaft, and put the motor back together. then put it back on the frame, and plug the fan in. turn it on. the shaft should just spin without any help. if this does spin, put the blades back on, and put the guard back on. Then you sucessfully rebuilt the motor and the fan!
Aug 12, 2010 | Lakewood High-Velocity Fan
How to open fan to clean blades honeywell model
first remove the two screws on the back top of fan... then remove little cover on third screw which is located on the bottom of the outer casing.. i used a fork to poke the hole for leverage then pull it out... take out the three screws on the bottom (that hold the stand part of the fan).. now you can start removing the casing.. start to pull apart.. carefully... once you have opened one part you can use a flathead or a butter knife to pry open where there are clips on the sides.. the final clip is under the handle poke that one and your fan should be opened....
Apr 15, 2010 | Honeywell Dryers
I want to take it apart to clean the fan blades ....how do I get to the blades.Cant figure out how to take off the protective grill?
remove all screws from the back and then slowly pry off from the back its click on there are latches that secures the backing, also remove the screws that holds the controls.
slowly pry open the case, i did mine in the middle and work my way around the unit, but it a bit tricky..
the best way to clean the device is to use a air compressor, strong air blowing inside while holding the blade with a screw driver. and even using a paint brush with long bristle, while blowing, this way you dont have to take the device apart.
good luck
Jun 28, 2008 | Lasko 2530 Elite WindTower Fan
Intex QUICK-FILL ELECTRIC PUMP, AC 110-120 VOLT Logo
295 people viewed this question
Top Intex Garden Experts
Charles T Nevin
Charles T Nevin
J.D. Browning
J.D. Browning
Tom Chichester
Are you an Intex Garden Expert? Answer questions, earn points and help others
