Question about Chaney Accurite Wireless Atomix ClockThermometer with Sensor
ACU-RITE MODEL 13131. HOW DO I KNOW IF AND WHEN IT IS RECEIVING THE TIME SIGNAL.
ACU RITE Wireless Thermometer Model L5C0668TX cant set the date
I have misplaced the user manual for the
Acurite L5C0668TXACU RITE Wireless Thermometer Model L5C0668TX. Where can I get another?
Jul 19, 2012 | Acu-Rite Acurite Wireless Indooroutdoor...
How to set time on model 13003
Hello
Get into this link. You can get all the details for your clock radio from there.
lib.store.yahoo.net/lib/partshelf/Acu-Rite-00592W-Manual.
Nov 17, 2011 | Acu-Rite Adagio Clock Radio
How do I reset the time on my acu-rite model # 604rx
Hold the Time button until the hour blinks. When it does, use + or - to adjust. When correct, press Time again. This will cause the minute to blink - use the same buttons to adjust. When finished, press Time again.
Sep 01, 2011 | Acu-Rite Acurite Wireless Weather...
My acu-rite wireless thermometer model #00604RX isn't capturing the wireless sensor signal..both have new batteries and worked before changing old battery..reset the buttons too...help
Double check the batteries and the direction in which they are installed. If there is one backwards in the sending unit that is outside, it will not send a signal. Also, there is typically one battery in the indoor unit that is responsible for receiving the signal from the outdoor unit. If all of the batteries are in correctly except that battery, you will see the display, but will not get the data transmitted from the outside sending unit.
Sep 18, 2010 | Acu-Rite Acurite Wireless Weather...
Acu-Rite indoor outdoor thermometer won't stop periodic beeping
There is no way to turn off beeping. From this site: http://www.chaneyinstruments.com/FAQ.aspx
found solution - search for - Q: My wireless weather station periodically beeps, why?
A: .. unit's ability to detect a foreign radio frequency of another wireless unit when that unit transmits a signal. .. any wireless devices transmitting on a radio frequency have the potential to interfere with each other. Limit the amount of wireless devices to lesson the chance of interference. When beeping occurs, one device will need to be deactivated.
There is no way to turn off beeping, d/s designers forgot. I had the same problem, another external temp gauge showed up on the other channel, so my neighbor or someone is using the similar unit. MY SOLUTION: opened back of case and cut black wire to piezo speaker (at base if rear cover opposite side of stand-up prop) that creates beep. Don't use any sound features, ALL good now.
Nov 24, 2009 | Acu-Rite Audio Players & Recorders
How to set the time on Acu-Rite model 13100 clock?
How do reset time on model 13003 ?? It reads 12:15 and the Time is 11:27 Clark page plaza@cox.net
Mar 08, 2009 | Acu-Rite Magnum-80181 Clock Radio
Setting clock
I think I solved the problem, take out the batteries and reinstall and then reset, seems to be doing ok now.
Oct 27, 2008 | Acu-Rite Audio Players & Recorders
Chaney Accurite Wireless Atomix ClockThermometer with Sensor Logo
108 people viewed this question
Top Chaney Measuring Tools & Sensors Experts
Vuk B
Tom Chichester
Are you a Chaney Measuring Tool and Sensor Expert? Answer questions, earn points and help others
