My Sony 5 disc dvd player stopped acknowledging that there were disks inside the player. It just says "NO DISC" and won't read the disc. I tried putting in a cd cleaning disc, but the machine won't run it. Everything else works fine, the radio, etc.
  • 10,594 Answers
I sent a premium offer to solve dvd player issue but got no response so far, not sure why.
I'm Sony tech and can be helpful to resolve this problem.
Posted on Aug 26, 2010
I have just the dvd player, the player keeps ejecting the disc and not playing it
Could be lots of things, but here are a few easy ideas:
1) Is the disc Blu-Ray? A regular DVD player can't read Blu-Rays.
2) I think all DVD players can read CDs, but if the disc you're putting in is a CD, maybe that's the problem.
3) Maybe the disc is dirty. Wet the disc, wash it with dish soap (or hand soap, then rinse it clean and dry it off. You can use a cloth or a paper towel for washing/drying. When washing and drying, make motions across the disc from the inside hole to the edge; don't swirl around the disc.
4) Maybe the disc is not the same region as the player. https://en.wikipedia.org/wiki/DVD_region_code
5) You've got a PAL (European) disc and an NTSC (American/Japanese) player.
Aug 02, 2015 | LG Televison & Video
Why does my sony DVP display "No Disc" for every disc; when they play fine in any other player?
Sony tend to have a notorious disc lasers... couple of things you might want to try..
1. clean the lens using a standard Lens cleaning CD.
2. Try playing a CD (music) instead of DVD (if this works...it is likely that the lens is not reading DVD)
N
Jun 02, 2014 | Sony Dvp-C660 Component Dvd Players
Sony GDP s301 won't play any discs
see the cause and remedies:
Does not play disc
  1. No disc. - Load a disc into the tray.
  2. Disc has been loaded upside down. Place the disc with the label side up.
  3. Disc region code does not match region code of the player.
  4. Disc type is not the correct type to play.
  5. Disc is damaged or dirty. Clean the disc or try another.
  6. Moisture may be condensed inside the unit. Remove the disc and the leave the power on for one or two hours.
Finally the OPU, optical pickup unit contain too the lasser beam, NOT are reading the TOC of disk,+Syscon can be defective. You must go to the repair shop TV for fix it. this a complex equipment.
see tje block diagram.
God bless you
Jul 15, 2012 | Sony BDP-S300 Blu-Ray Disc Player
My dvd player won't play dvd
likely if cannot read disc, or no disc or error, that unit has either dirty or bad optical pickup.
May 14, 2012 | Televison & Video
Sony DVD player reads NO DISC when there IS a disc
Buy a lens cleaner made by TDK or others. If you can see the picture from the lens cleaner disk The lens is clean but your semiconductor chipset can not read the dvd reflections because it overheated. Use it more often with the lens cleaner, the chipset damaged by humidity may dry up and work perfectly again.
Feb 08, 2012 | Televison & Video
Sony Blu Ray DVD won't open, but disc inside is playing
hold on to open boton but it might take a while to open or the rubber that open and close the door is little bit slack that why its giving that type of prob, try and change it .
May 30, 2010 | Sony Blu-ray/dvd player BDP-S1
DVD Player stops reading disc Error message :
usually this happens when lens cannot read the the disc. Due to few reason 1 Your disk is scratched 2 Your DVD lens is covered with dust 3 You need to replace DVD lens
Try another few CD/DVD to rectify whether there is any problem with dvd you are trying to play
if this error occurs on all the dvd you played then the most likely proble is with your DVD lens either its coverd with dust use Disk cleaner if not you got to replace a new DVD lense as per model
Feb 18, 2010 | Samsung DVD-V9800 DVD Player/VCR
Player shows '' No Disc'' even when inserted with a disk
When player says no disk, even if the disk inside, and you hear a whirring and clicking noise when you insert a disk, that means that the CD lens is dirty or defective, and the CD drive cannot read the initial CD track, and returns no disk.
Try first using a CD cleaner disk, if that does not work, then you will need to take the apart the unit to clean lens with isopropyil alcohol and cotton sticks.
See also the following websites on how to clean the lens, use a cleaner disk first:
Gizmo Highway DIY - Clean your CD player lens
Lens Cleaning CDR CD-RW (how?)
DVD Not Working
Mar 04, 2009 | Sony Televison & Video
Sony DVP-PQ2 problem
does it do this with every disk?
it could be one of several things, with some of these drives it uses a friction wheel at the center of the disk to "spin" the disk, this uses a circular rubber traction disk to grip the disk on both sides and then spins the disk using this traction, ( if the rubber there is not good it will not work well)
the other kind of spindle is a press on spindle which has a spring loaded grip mechanism where the disk is clipped onto the spindle,
the other issue is that you may have a driveband failure, this basically a rubber band which drives the main drivewheel from the drive motor, these can wear out or perish.
lastly, it could be a bad/burned out drive motor,
all of these issues can be fixed by the manufacturer and some of these can be fixed relatively easy by the user if the unit is out of warranty
Oct 13, 2008 | Sony DVP-PQ2 Portable DVD
Sony dvp-nc80v
If this happened after a power surge, it's possible that one or more capacitors in the power supply have been damaged, and that could cause the player to act up. Otherwise, the symptom you're experiencing is a classic one of the laser pickup not reading the tracks on the disc (assuming you meant to say it switches the disc after approx 5 Seconds). If it is within the warranty period, it would be worth getting looked into. You can get a good CD/DVD player to act up like this by placing the discs upside down on the platter.
Jan 13, 2007 | Sony DVP-NC80V DVD Player
 Grubhead
Grubhead
