Question about Line 6 Variax 700 6 String Modeling Guitar with Tremolo 99 280 0105
Output of low E went dead (not 100%) but low in volume output and very dull sounding.
    President:
  • 1,137 Answers
Here is a link that might help:http://line6.com/community/community/support/instruments/variax?view=documents&markAsQuestion=1
Posted on Aug 22, 2010
Beringer PMH 660M has very low power output to speakers and when the volume in increased the output pops in the speakers and goes completely dead, everything else works ok and the lights stay on
could possibly be the volume switch, try changing the switch with one that you hardly use to eliminate the problem. any further probs just let me know. hope this helps
Feb 16, 2012 | Behringer Music
Low volume on my marshall
I am very new here and don't know how to answer a question to a specific problem so I will write about the most common problems that I have had over the decades doing guitar amp repairs. If you find that your amp is extremely low in volume and then suddenly comes back to normal- check out the effects return [or power amp in] jack. Especially in Marshall amps-these corrode and your signal dies. If there is loud noise such as hissing and crackling with no guitar patch cord in the input jack- the input jack is likely at fault. They normally have switching contacts that ground part of the input circuit when the 1/4 inch male plug is disconnected. When this in is corroded or too weak to make normal contact, you can get these symptoms. If your amp is a solid state Marshall or Fender and there is a random buzzing sound with no guitar signal connected- hit the side of the amp and listen for the buzz to go away or become louder-if it does, this usually means that the connections are loose at the two large filter capacitors. In one or more Marshall amps, they use a filter circuit in the low voltage power supple for the preamp tubes. If you encounter a dead Marshall[the model escapes me now] remove the circuit board and resolder the four connections at the bottom of the bridge rectifier. If you have any other amplifier repair questions you can email me direct at computerlen@hotmail.com.
Nov 14, 2011 | Marshall Mg100dfx 100-Watt Combo Guitar...
I run a pod HD 500 into the amp and It breaks up, like there is a blown speaker sometimes.
The Marshall is a super clean acoustic amp.
The POD is overloading the amp.
Try the electric guitar input and keep the gain on the amp down, keep the EQ level and use the POD and the end volume to adjust the final volume.
The normal inputs is for a low output acoustic pickup - the POD is a high output electronic source.
Start with the Marshall gains low and get the clean sound good, then work on the gritty sound.
The amp is voiced for a sweet clean sound - if you want grit'n'ball change to a 50w Marshall valve head and a 4 X 12 cabinet.
Horses for courses
Mar 07, 2011 | Marshall Amplification Marshall AS100D 2x8...
My Epi valve jr v3 burns up jj el84 tubes, but the solvteks work fine...is it the amp or the tubes?
Check the bias on the tubes! Some brands can run with bias set wrong. Also some amps have 4 output tubes and people don't know that MATCHED pairs have to be seperated to each side of center of the group of four tubes.
You probably only have a single EL84 tube in your unit.
I could not find the schematic for this unit... IF the plates of the EL84 are coloring, the bias is set wrong. The plates should remain BLACK and not coloring to dull red or orange. Telling if the tubes are "burned up" can only be done with a tube checker or electronic test equipment or by seeing a bright purple glow between the elements.
Now this is supposedly only a 5 Watt unit so that means it is for LOW volume practice only... If you overdrive this small amp you can PROBABLY burn almost any tubes you put in it. The sound you can expect out of this will not be louder than most of the consumer boom boxes at full volume.
If you overdrive and "flattop" the unit the power tube will overheat and fail... this amp runs the tube in "Class A" which makes failure under overdrive more likely than in Class AB or B. I can't go into the engineering details other than to say at volumes above the design the output transformer will saturate and the tube will have to dissipate way above its ratings.
Feb 12, 2011 | Epiphone Valve Junior Tube Amplifier Head
My fender hot rod deluxe is distorting in clean channel when I push the volume past 2
Realize that the number on the volume control is only relative... it means nothing regarding what the amp can produce. With a high level output guitar you can easily drive the amp into distortion at very low volume control level settings... what counts is the actual output sound volume and specifically the voltage output going to the speaker. Once the amp reaches saturation, any further input just pushes it into distortion or "flat topping".
An oscilloscope on the output will quickly show when amp starts to flat top.
Jan 17, 2011 | Fender Hot Rod Deluxe Guitar Combo...
A new DM7 drum set line out has very low output. It is connected with drum combo Stagg EDA40 and if combo drum inputs are used there is practically nothing to hear . With combo maximum volume there is...
The sound on all the stock kits I found to be too low. What I did was create a custom kit and altered the dynamics of all the pads and cymbals - once you're in the dynamics settings, just hit the pads/cymbals the hardest you normally would and save that setting!
Dec 29, 2010 | Alesis DM7 USB Electronic Drum Kit
Fender m80 ...hey before im sorry bout my poor english.
output caps, replace them.
also the speaker could be getting tired.
Dec 07, 2009 | Fender Fm25dsp 1x10' Guitar Combo...
Low Volume using Kaoss Pad Mini while DJing
I'm having the problem too...I'm thinking that maybe getting the DC adapter MAY fix it though as stated in the Manual: "...The output level of the mini-KP will be smaller than its input level. This is because the attenuator circuit is connected at the input section, considering that the mini-KP is used on battery power." so maybe the dc connector will increase output volume?
Aug 22, 2009 | Korg Mini Kp Kaoss Pad
Korg mini kp only some effects working. Low sound output
I have the same Kaoss Pad mini and have exactly the same problem. I have asked for a solution as well!
The only way I have been able to use live is to turn up master on mixer to compensate, but this is incredibly hard to do if you're not always going through the KP as you have to adjust master volume each time up or down.
I haven't heard any volume problems with the full size Kaoss Pads, think it might just be a KP mini problem.
johnclark
May 28, 2009 | Korg Mini Kp Kaoss Pad
Line 6 Variax 700 6 String Modeling Guitar with Tremolo 99 280 0105 Logo
150 people viewed this question
Top Line 6 Music Experts
Vito Vacirca Jr.
Larry Stiles
Larry Stiles
Lawrence Nentwig
Lawrence Nentwig
Level 1 Expert
Are you a Line 6 Music Expert? Answer questions, earn points and help others
