Question about Bosch Tassimo TAS4511UC Coffee Maker
I need to know how to dismantle the Bosch Tassimo so that I may find a leak inside the unit.
To get the side panels off you push them in at the middle then slide them back (toward the back of the machine). They are attached like a sliding chain door lock. You are sliding a "button" (molded into the panel) along a **** into a circle slightly larger than the "button". At that point it pops out. There are four such "buttons" on each panel.
Posted on Aug 24, 2010
I need to no how to work bosch tassimo
You need to add water to the reservoir. Turn on the unit with the on button. Open up the top to insert the Tassimo coffee discs. Then press the large lighted button. Coffee will dispense into your mug.
Mar 13, 2016 | Bosch Washing Machines
The lid won't open to get the used coffee pod out. It seems to be stuck.
Customer questions and answers for Bosch TASSIMO T10
answers.tassimodirect.com/answers/.../bosch-tassimo.../questions.htm?...
The TASSIMO T10 Single Cup Brewing System by Bosch brings the artistry ... the machine made some funny noises and now I cant open the lid to remove pod. ... When I went to remove the T-disc, the tassimo won't open so I cannot get it out.Missing: tas5542gb
Bosch Tassimo TAS4511UC Coffee Maker Open ... - Fixya
www.fixya.com > ... > Bosch Tassimo TAS4511UC Coffee Maker
Question about Bosch TASSIMO Coffee Makers & Espresso Machines ... colors, openthe lid, put disc with the cream in the machine and the green light won't come on, only the . ... Bosch Tassimo Tas5542gb Multi Hot Drinks Machine, Black.
Why has my Tassimo brewer stopped working?
www.coffeedetective.com/why-has-my-tassimo-brewer-stopped-working...
QUESTION: I have a problem with my Bosch Tassimo brewer. ... Now when I close the machine, I open it and remove that litte tin foil circle. ... Opened my new Tassimobrewer and won't brew and water dispenser leaking all over... an ... I have a problem with my tassimo coffee maker the lid wont lift up seems stuck any ideas ...Missing: tas5542gb
Jan 19, 2016 | Bosch Tassimo Tas5542gb Multi Hot Drinks...
Descale T20 Bosch Tassimo
you need to use the cleaner disk (tucked into the back of the machine) and run through some of the cleaner solution. Then run though just water. Don't forget to store the cleaner disk back in the machine.
Sep 09, 2014 | Bosch Tassimo T20 Single Serve Brewer,...
Water sat in the bottom tray of my tassimo t65 and now it has two red lights flashing can I fix it
Bosch Tassimo T65 Repair Questions,... - Fixya
www.fixya.com > ... > Coffee Makers & Espresso... > Bosch > TASSIMO
0 Answers. Water sat in the bottom tray of my tassimo t65 and now it has two red lights flashing can I fix it Ā· Bosch Tassimo... ' Posted on Aug 23, 2014 ' Be the ...
Bosch TASSIMO red light water full Unsolved Problems - Fixya
www.fixya.com/unsolved_problems/red_light_water.../tassimo
0 Answers. Water sat in the bottom tray of my tassimo t65 and now it has two red lights flashing can I fix it. Aug 23, 2014 ' Coffee Makers & Espresso Machines.
Bosch TASSIMO cleaning condensation tray Unsolved ...
www.fixya.com/unsolved_problems/...condensation_tray/.../tassimo
Aug 23, 2014 | Bosch Tassimo T65
Tassimo low water light will not reset
The problem is because Tassimo water tanks have a floating magnet in them which operates the water level switch inside the body. The magnet gets weak over time. Replacement tanks cost too much to be worth the cost. The simple answer is to stick a fridge magnet on the back of the unit (just above the power switch) using blue tack or similar (you can experiment to find the right position). Our unit has been working fine like this for a few years now. :-)
May 24, 2014 | Bosch Tassimo TAS4511UC Coffee Maker
How much bicarb of soda do i use to descale my bosch tassimo
Sodium bicarbonate is not a descaling product. It makes a nice minimally abrasive cleaning agent when mixed as a paste. Sodium ions will exchange with calcium in a water softener when the calcium is dissolved in water. Once the calcium salt (calcium carbonate) forms, it doesn't go back into solution in a neutral or basic environment. A bicarbonate solution will be basic.
Descaling requires an acid. The Tassimo products say "Do not use vinegar" (acetic acid). I suspect they use citric acid in their descaling product. You can try the lemon-flavored Kool-aid (the version packaged in the envelopes that needs a sweetener added when it's a drink). Mix 1 tablespoon of the powder in 1 pint of water. However, you'll need to make more than a pint of the solution since you need 500 ml of liquid per cleaning cycle. (1 pint is ~473 ml.)
I hope this helps.
Apr 24, 2012 | Bosch Tassimo TAS4011GB Coffee Maker
Tassimo coffee maker part replacement
If your machine is made by Bosch then go to www.bosch-eshop.com where you can order spare parts online. I think the part number is 616231:Jet and is called a Tassimo piercing unit.
Nov 20, 2009 | Braun Tassimo Espresso Machine/Coffee...
Tassimo machine leaking water underneath
I'm having the same problem with my machine. I rang the Tassimo careline and they told me to descale the machine but, so far, this has only made matters worse. I'm now going to take it back to where I got it from because it's still within its warranty.
Oct 06, 2009 | Bosch Coffee Makers & Espresso Machines
Bosch Tassimo machine leaking from inside! How do I dismatle it?
Before you attempt to dismantle the Bosch Tassimo, you need to determine how/where it is leaking. (1) Before making a drink with the unit remove the cup tray and ensure the bottom where it fits is dry. Replace the drink tray (2) Make a drink or use the cleaning disk, put a cup under as normal and start the cycle. (3) After the drink is made or a clean cycle remove the bottom cup tray and see if the bottom where it fits is wet.
If it's wet you have two (2) problems
(1) The pressure valve on the top of the heater is staying open, usually due to using water that has lots of calcium in it. (2) The pipe that leads from this pipe to the bottom tray is leaking (it's not a good fit in any of these machines, and causes water to drip from underneath.
Don't take it apart yet! Buy some de-scaler from AP-Wagner.com and run this a few times, it should clear it. If it doesn't you have no choice but to open the thing.
If you have the model with a filter use it and change it when it tells you. If you don't have a built in filter, don't use water directly from the tap, run water through a Brita filter or similar
If the bottom tray doesn't get wet, take it apart to see where it's leaking. 99.99999999999999% of the time it the valve.
So how to take the thing apart.
(1) The sides (silver or black) slide to the rear. However, you have to put something in the back between the side and the rear cover to pry them apart while pushing to the rear. It's very difficult. I use a 6" steel ruler. You have to bend the sides to overcome the catches that hold them in place. You'll see a small rectangular slot at the back of each side. They will come off eventually.
(2) Once off you'll have to remove the lid where you put the disc in. Remove the 4 screws under the lid deck. (3) Remove the water pipe screws (2) and the bar code scanner screws (2). Be careful of the barcode scanner the cable is very, very delicate (I always unplug it from the circuit board and remove it completely, lift the black tabs at either side of the cable). Lift of the lid assembly. (3a) Remove the screw from the underneath the unit at the back, this allows the front to move out. (4) At each corner of the top carefully pry the locking mechanisms until the top is free. Remove the pink (thick) pipe and the pink (thin) pipe and turn the top around out of the way of the heater unit. A coiled steel spring will drop out, it's easy to replace when the top is back on. (5) Where the thin pink pipe goes to is a back pressure release valve carefully pry the clips apart and remove. Take out the rubber O-ring and the valve. Carefully remove any calcified deposits from under the rubber (blue) valve. (6) Reassemble valve (7) Reassemble top, and lid taking care with the bar code reader. (8) Test before replacing the sides
The thick pink pipe that descends from the top, that you removed earlier goes to the bottom tray, you will notice it is very loose (they all are) and it leaks. Put a tie wrap around it to seal it.
Good luck, it's not an easy fix, they were never meant to be taken apart to be repaired - not very ECO friendly. Let your MP/Congressman know, these should end up in a landfill because of 50 cent valve, and they don't come apart.
Mar 28, 2009 | Bosch Coffee Makers & Espresso Machines
Bosch Tassimo TAS4511UC Coffee Maker Logo
1,257 people viewed this question
Top Bosch Coffee Makers & Espresso Machines Experts
Tre Elkins
graybeard32301
Kolbrun...
Are you a Bosch Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
