Question about Dewalt DC988ka 18 - volt XRP 1/2'' hammerdrill/drill/driver kit
Remove the chuck from the drill too install new one
  • 2,176 Answers
Go to the tip section and there are detailed instructions on how to do this or under my profile they are there also.
Posted on Aug 26, 2010
My new bosch cordless drill chuck doesn,t have a screw in it how do i remove the chuck ?
Dear Fred,
Please go to Replacement Parts in the link provided below. Too replace and remove your drill chuck on a cordless drill.
How to Remove Drill Chuck
Fare Well
Feb 07, 2015 | Bosch 13618 - 2G 18V Brute Tough Cordless...
113.24520 chuck replacement
most drill press chucks are installed and locked on by a male / female taper fit. Tap chuck assy. downward with a soft hammer to remove. install new chuck tapping it upward.
Oct 28, 2013 | Craftsman sears 15" 1/2 Heavy Duty Drill...
How to change the chuck on 18 volt cordless drills
Set the drill to reverse. Hold the chuck, press the trigger and open the drills chuck to it wide open position. Now,, take the correct size allen wrench and insert it into the back of the chuck to remove the screw. Turn the screw clockwise to remove it. Notice I said clockwise, just the opposite of what you might think. Hold the chuck with your hand or a pair of large vise grips and press the trigger to unscrew the chuck from the drill. Rotate it counterclockwise to remove it from the drill. Reverse the procedure to install the new chuck.
Mar 10, 2011 | Dewalt 18 Volt Compact Drill Kit
How do I change the chuck on my milwaukee right angle 1/2" drill? It has snapped off behind the chuck
Take digital photos when taking the front metal gear box off the drill. Next carefully remove the two plastic halves of the drill if needed to gain access to the shaft that holds the chuck.
Replace the broken threaded metal part that the chuck screws onto.
Normally chuck replacement involves unscrewing the small screw deep inside the chuck on a metal shaft has a left hand thread. Next use a large allen wrench tightened in the chuck with a mallet to loosen the bad chuck. Reverse to install new chuck.
Feb 01, 2011 | Drills
I have a dc 759 it has a plastic cover over the keyless chuck ....it is stripped out.....can i just replace the plastic cover? .... if so how and where can i get one
If the drill is not too old, I would take it to your nearest factory dewalt repair shop. they have a good warranty on their items. If it is older you probably need to replace the chuck itself. You need to remove the plastic to get the chuck open and then there is a screw down inside the chuck that needs removed. The chuck should come right off and just reverse the process to install the new one.
Nov 12, 2010 | Dewalt DC988kar XRP 3 - speed 1/2" 18v...
Need to change chuck
When you buy a replacement chuck it will have detailed instructions- at least Jacob's brand chucks do. Basically there is a retaining screw inside the chuck that needs to come out first- it may be left-hand threads . Then you put the short end of a 1/4" or larger allen wrench in the chuck and close it tightly. Set the drill on a bench with the chuck off of the bench and strike the allen wrench with a mallet in a counterclockwise direction. Do this several times, then you'll be able to spin the chuck off by hand. Reverse the process to install the new chuck.
Apr 13, 2010 | Bosch 1199VSR 8.5 Amp 1/2 Inch Hammer...
Describe how to remove drill bit and install a
Most cordless drills use keyless chucks these days. Shift the drill into reverse and hold the main body of the chuck. Pull the trigger and the bit should come out. Put it into forward and run it to tighten onto a new bit.
Dec 02, 2009 | Drills
Removing the dewalt DC925 'rohm' chuck
I simply placed the chuck into a large vise and turned the drill counter clockwise and the chuck spun right off no problem without damaging anything!! It does have some thread lock on the chuck but just use your man strength and its as simple as turning the lid off the pickle jar! Do not waste your time or money with the removal tool...YOU DONT NEED IT!
Nov 24, 2008 | Dewalt 18 Volt Compact Drill Kit
I think its a bad chuck unsure though
yeah you have a bad chuck. there is a screw inside the receiver of the chuck if you remove this screw the chuck will come off. Reverse this procedure to re install the new chuck.
Jun 12, 2008 | Dewalt DC920KA Heavy Duty Xrp 18V Cordless...
Dewalt DC988ka 18 - volt XRP 1/2'' hammerdrill/drill/driver kit Logo
54 people viewed this question
Top Dewalt Drills Experts
Jim Thurston
Are you a Dewalt Drill Expert? Answer questions, earn points and help others
