Question about Goldstar DH504EL Dehumidifier
Placement options in the room. Where are the best places to put it. Can it be put on a shelve.
  • Goldstar Master
  • 43,501 Answers
Yes, a unit can be placed on a shelf and often they will work better because the iar is a bit wrmer higher...
heatman101
Posted on Aug 29, 2010
I have a 2002 danby dehumidifier can not find model number i need a manual or tell me how to just run the fan
They don't have a way to run just the fan. Dehumidifiers don't normally have a fan only option. That would be kind of like having a DVD player not hooked up to a TV, you put a disk in and it might start-up (spinning) in autoplay mode put you can't see it so there is no benefit. If you are just trying to circulate the air in the room a small fan would work much better.
Sep 25, 2016 | Danby Ddr4010e 40 Pint Room Dehumidifier...
Best to add humidistat to AC or purchase stand alone dehumidifier. For Florida summers, house unoccupied
That would depend upon the size of the dwelling. If it is a smaller, open-concept type of place, a stand-alone will work fine. If it to operate unattended, you would need to have a drain available to collect the moisture collected so the unit would not fill up and shut off. If the place is larger or has many rooms where air flow is restricted, then the humistat is the better option, since it will use the homes HVAC system to recycle the air and remove the excess humidity. Also, since the A/C coil in the air handler is already connected to a drain, moisture removal becomes a non-issue.
Dec 10, 2015 | Dehumidifiers
NOT SURE IF MY DEHUMIDIFIER SHUTS OFF AUTOMATICALLY AT A CERTAIN DEGREE
Dehumidifier's control By percent room Realative Humidity Or better known as rH% , if your not sure your unit is working or even cycling properly , purchase a seperate rH meter(there not expensive) and place it in same room someplace , Normal %rH for a homes room is 70%rH set your units setting for a target of that number and use the seperate meter to verify thats what it is (takes 24 hrs) , if Meter is consistent Higher or lower a reading that whats set on unit then yes you might have a problem with your unit
Jan 13, 2015 | Dehumidifiers
How to measure humidity in a room
Good Afternoon Friend,
I understand that you want to know how to measure the humidity in a room with your Frigidaire dehumidifier, model# FDL50R1. Typically, your appliance will not measure the humidity and tell you exactly what the level is. I suggest placing your dehumidifier in the room you want it in, and turning it on to the continuous mode. The display will show "CO". Leave it at this setting for the first 3-4 days. Once the 3-4 days has passed, I suggest setting it to the 50%, 60%, or 70% setting and change it to your liking. If it is more humid in the room than you would like, put the setting lower. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your washer status has changed successfully. Hope this is helpful.
-Best Regards-
WP
May 23, 2014 | Frigidaire FDL50R1 Dehumidifier
Just purchased this product and we are having difficulty figuring out the best setting so that the unit will shut off and on. It seems to only run continious. The model no. is VK0025000CURNPF735A0794 ...
When a humidifier is first placed into service depending on the environment you placed it in, it can take up to a week to actually shut off.
Think about this...
Q? Why did you buy the unit in the first place?
Ans. Area you want to use it in is damp.
So the NEW humidifier has to really work hard to remove moisture from everything in the space.
Furiniture, structure to include cement floors and walls. This can take a very very long time initially. If there is a sump pump in the basement the humidifier needs to be placed quite a distance from the sump area. If the structure foundation and walls are allowing water seepage into the basement it may NEVER shut off.
If it does not shut off after several days. Move the unit to a small room upstairs that you can place it in and close the door just to test to see if the unit will cycle on and off. If it cycles on and off in a small room you may want to inspect your basement foundation and check for plumbing problems.
Thanks for choosing FixYa,
Kelly
May 22, 2011 | Whirlpool 25-Pint Dehumidifier
We bought a ADEH 50 LNL1 Serial 106143 this summer. It does a great job at removing water from our basement,needing emptied every 24-36 hrs. However it is always so hot in whatever room we set it that...
Unfortunately not....you see a dehumidifier puts the heat back into the room... it does not remove any heat...but... the heat from the fan motor and the compressor is added to the room... thus the heating that you are noticing...
Sorry I cannot give better news... :-(
heatman101
Aug 29, 2010 | GE Dehumidifiers
What does an E2 code mean? I have a Haier Dehumidifier that is about a year old, I emtied the bucket and put the bucket back into place and hit the start button and nothing happen I unplugged the unit and...
I have a Haier Dehumidifier that is about a year old, I emtied the bucket and put the bucket back into place and hit the start button and nothing happen I unplugged the unit and error code E2 keeps comming on
Jun 30, 2010 | Haier HD451E Dehumidifier
Ice keeps forming on top of my lg dehumidifer
MOst likely the room the dehumidifier is operating is is too cold for proper dehumidification to take place. Try warming up the room and I believe then your dehumidifier will work fine.
Jul 07, 2009 | LG Dehumidifiers
Dehumidifier automatic on and off function not working
Unless you live in a dry environment or place the unit in a hermetically sealed room, it probably will not turn off. As the air dries within the room, more moisture comes in with the air. As long as the air outside of the room is more humid than the room this will be true.
Mar 10, 2017 | Whirlpool Gold AD70USS 70 Pint Per Day...
Goldstar DH504EL Dehumidifier Logo
29 people viewed this question
Top Goldstar Dehumidifiers Experts
Gil Shultz
Michael Youngman
Michael Youngman
Jerry Greenberg
Jerry Greenberg
Are you a Goldstar Dehumidifier Expert? Answer questions, earn points and help others
