Question about Onkyo Audio Players & Recorders
Onkyo Integra Intergrated stereo amp. A-8087 no power when turned on power supply OK
tech48
  • 624 Answers
SOURCE: Pioneer 760W (Mosfet Power Supply) Amplier
If you are connecting the negative lead of the voltmeter to the chassis of the car, and then checking the voltage at the amp on the ground power input of the amplifier, then your amplifier is not grounded properly. The amp should also be grounded on the chassis of the car, so if you have 4 V DC on it, it can not possibly be grounded to the chassis. The chassis is the same potential at any point on the car.
Could it be that the 4 V DC is at the power terminals +B or positive voltage? That would not be an uncommon thing to have since the amplifier will hold some charge after it is turned off and that would be normal.
Since you have a voltage meter, you could check the current draw of the amplifier if your meter also have a setting for current or amps.
If so, connect the meter in series with the ground of the amplifier. That means to disconnect the ground wire at the amplifier, and use the meter to complete the ground connection by putting one lead of the meter on the ground wire that should be connected to the chassis of the car and the other lead to the ground terminal of the amplifier. It does not matter which lead you connect to the wire or the amplifier, that would only make your measurement i postive current or negative current, but the meter must be set up properly for current. Most of them have a diiferent jack to put the positive lead into for current. most have two different jacks. If yours does also, choose the lead with the larger amp rating. Most have 10A and 300mA, the lareger amp rating is 10A. That is 10 amps max and the 300mA means 300 milli-amps which is .3 amps max.
Do this with the amplifier turned off and the car off. If you measure any current at that point you do have a current draw with the amp off and the amp would need to be serviced by a professional. If you have no current draw there, the amp is not the source of your battery draining. This would find out for certain if the amplifier is really draining the battery.
If you have found this information help a rating of "FixYa" would be appreciated.
If you need more help just ask,
Dave
Posted on Jun 27, 2008
  • 152 Answers
SOURCE: stereo amp power supply
No I wouldn't share the amp feed. It should be stand alone, with its own fuse.
Yes it is wise to connect directly to the battery, hence through the firewall.
You should purchase an amp wiring kit, matched to the
watts of the amp. It has everything you need to correctly make all of the connections.
Good luck
Aduz
Posted on Mar 11, 2009
smarthome2
  • 1114 Answers
SOURCE: Mitsubishi M-VR900 remote
Harmony by Logitech; they have models ranging from 70-400 based on your needs. They are 100% programmable, meaning any function your unit has, it will duplicate. PC software is very user friendly. You can set this remote to control up to 14 different devices and one button control. They even pass the Wife/Mother, & in-Law tests.. They have a substantial Database of products on file so you don't have to have your original remote. If you have problems while programming, they will actually answer their phones 14 hours a day. Why do I like these so much? Price/Performance/User friendly & I program all remotes from Universal to Crestron. Hope this helps. If you have any questions, reply & I will answer for you & help any way I can.
Posted on May 25, 2009
  • 4234 Answers
SOURCE: amps ? stereo intergrated amps ?
Since the mixer has a line level output, yes you can use a home stereo for the "AMP". Use the AUX IN, TAPE IN or CD IN on the stereo and connect the speakers as you normally would.
Dan
Posted on Feb 26, 2010
Testimonial: "nice one cheers mate much appreciated"
boldenw68
SOURCE: Onkyo Integra 939
it wont worck
Posted on Dec 07, 2011
My Onkyo M501 Power Amp is putting out sound very low when volue is turned completely up
Make sure that the preamp you are feeding amp with is not at fault. If ok, then the issue must either be with the power supply or output stages of amp.
Jun 20, 2017 | Onkyo Audio Players & Recorders
How to hook up bose 901 active equalizer to onkyo grand integra pre amp?
You don't.
If you have a pre-amp/power-amp combination then the Bose equalizer connects between the two. If you're using the Bose speakers as front L&R, then the connection is between the front L & R pre-out and the power amp's front L & R pre-in.
Sep 01, 2014 | Audio Players & Recorders
Onkyo Amplifiers & Preamps
Hi ,try cleaning your volume control ,here is a video so you can DIY or contact your local service. :)
Dec 17, 2013 | Onkyo Audio Players & Recorders
The source selector of my onkyo A 807 runs away
HI try this video it worked for me. :)
http://www.youtube.com/watch?v=0Xfm-9jCmjE
Apr 09, 2013 | Onkyo Integra Intergrated Stereo Amplifier...
Amps ? stereo intergrated amps ?
Dan
Feb 26, 2010 | Behringer DJx700 5-Channel Pro DJ Mixer...
Garbled / feedback sounds from powered subwoofer
The surround processing portion of the unit has a problem. In either stereo or direct mode, the digital procesing is bypassed. This could be just the surround processing IC, but that IC may not be available as a separate part. I would suggest that you bring this unit to an authorized Onkyo service center for an estimate.
Dan
Mar 18, 2009 | Onkyo TX-DS595 Receiver
Integra DPS 8.5
The Integra DPC-8.5 changer (as opposed to the DPS-8.3 single-play unit -- not sure which you have, as you mention DPS-8.5, a non-existent model) and most of the integra line of players, will sometimes be thrown into brainlock by out-of-step shutoffs. They will usually respond to the Integra/Onkyo instruction manual's directions to turn it off (you're already done that), then unplug the power cord from the back of the machine, wait a few seconds (make it 30 to be safe), then plug it back in and turn it on via the standby switch. The screen should display its welcome message, cycle through startup, and being working again. It is very much like rebooting a PC. In fact there is little difference.
If this doesn't work then something has gone wrong inside and probably has nothing to do with your shutdown method on the way out the door. These things do happen. Hopefully by now you've already figured this out. If not, give it a try. It usually works.
Jul 04, 2008 | Integra DPS-8.3 DVD Player
P-301 onkyo pre-amp
Hi juicer, If you use the switched outlet, then everything will be turned on/off when you operate the preamp power switch. Use the unswitched, then you have to turn off each unit separately. You choose which one you want. It wont matter.
What connection do you intend to use to connect the LBT zx6 to the Onkyo preamp??
Mar 20, 2008 | Audio Players & Recorders
Receiver
I have the same problem.
Is there a solutions besides replacing it?
May 22, 2007 | Mitsubishi M-VR700
217 people viewed this question
Top Onkyo Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
