Question about Daewoo DVG-3000N DVD Player
When I insert a DVD it goes to Smart Navi menu and I can't get off it. I can't even use my DVD player now because I can;t get rid of the smart navi menu.
Free download the software of eclipse dvd/cd/av/navi system ucnv884
navi system ucnv884 downloads Google Search
Has 9,800 results... hope at least one works for you!
I did a GOOGLE Search for: navi system ucnv884 downloads
Anthony
Jun 11, 2012 | Eclipse (AVN7000) Car DVD Player
How do i connect my nokia 6230 to gprs
Hiiiiiiiiiii....................
Nokia 6230 GPRS and WAP Internet Settings
You'll need to complete all steps for this to work.
The phone has a 4 way directional 'Navi' key and 2 soft keys either side of this.
To insert the required symbol (e.g. : / . @) into your settings, simply press the * key, highlight the appropriate symbol and press the Use key to select.
1. Press Menu button (Navi key).
2. Scroll to 'Settings' and press 'Select' (Navi key).
3. Highlight 'Configuration' and press 'Select' (Navi key).
4. Highlight 'Personal Configuration Settings' and press 'Select' (Navi key).
5. Press 'Add' [If there are profiles in the hand set already Press 'Options' then select 'Add new']
6. Highlight 'Web' and press 'Select' (Navi key).
7. Highlight 'Account name' and press 'Select' (Navi key).
8. Enter 'giffgaff GPRS WAP' and then press 'OK' (Navi key).
9. Highlight 'Homepage' and press 'Select' (Navi key).
10. Enter 'http://giffgaff.com/mobile' then press 'OK' (Navi key).
11. Ignore 'User name': Leave blank.
12. Ignore 'Password': Leave blank.
13. Highlight 'Use preferred access point' press 'Select' (Navi key).
14. Highlight 'No' and press 'Select' (Navi key).
15. If asked to 'Define access point settings' then press 'OK' (Navi key).
16. Highlight 'Access point settings' and press 'Select' (Navi key).
17. Highlight 'Proxy' and press 'Select' (Navi key).
18. Highlight 'Enable' and press 'Select' (Navi key).
19. Highlight 'Proxy address' and press 'Select' (Navi key).
20. Enter '193.113.200.195' and press OK' (Navi key).
21. Highlight 'Proxy port' and press 'Select' (Navi key).
22. Enter '8080' and press 'OK' (Navi key).
23. Highlight 'Data bearer' and press 'Select' (Navi key).
24. Highlight 'GPRS' and press 'Select' (Navi key).
25. Highlight 'Bearer settings' and press 'Select' (Navi key).
26. Highlight 'GPRS access point' and press 'Select' (Navi key).
27. Enter 'giffgaff.com' and press 'OK' (Navi key).
28. Highlight 'Authentication type' and press 'Select' (Navi key).
29. Highlight 'Normal' and press 'Select' (Navi key).
30. Highlight 'User name' and press 'Select' (Navi key).
31. Enter 'giffgaff' and press 'OK' (Navi key).
32. Highlight 'Password' and press 'Select' (Navi key).
33. Enter 'password' and press 'OK' (Navi key)
34. When asked to 'Verify new password' enter 'password' and press 'OK' (Navi key).
35. Press 'Back' (right soft key) 3 times.
36. Highlight 'giffgaff GPRS WAP' and press 'Options' (left soft key).
37. Highlight 'Activate' and press 'Select' (Navi key).
38. Press 'Back' (right soft key) 4 times to return back to the standby screen.
Switch your handset off and then back on to complete your settings.
The GPRS WAP settings are now complete.
Nokia 6230 MMS Settings
4. Highlight 'Personal configuration settings' and press 'Select' (Navi key).
5. Press 'Add ' [If there are profiles in the hand set already Press 'Options' then select 'Add new']
6. Highlight 'Multimedia msg.' and press 'Select' (Navi key).
8. Enter 'giffgaff MMS' and then press 'OK' (Navi key).
9. Highlight 'Server Address' and press 'Select' (Navi key).
10. Enter 'http://mmsc.mediamessaging.co.uk:8002' and then press 'OK' (Navi key).
11. Highlight 'Use preferred access point' and press 'Select' (Navi key).
12. Highlight 'No' and press 'Select' (Navi key).
13. If asked to 'Define access point settings' then press 'OK' (Navi key).
14. Highlight 'Access point settings' and press 'Select' (Navi key).
15. Highlight 'Proxy' and press 'Select' (Navi key).
16. Highlight 'Enable' and press 'Select' (Navi key).
17. Highlight 'Proxy address' and press 'Select' (Navi key).
18. Enter '193.113.200.195' and press OK' (Navi key).
19. Highlight 'Proxy port' and press 'Select' (Navi key).
20. Enter '8080' and press 'OK' (Navi key).
21. Highlight 'Bearer settings' and press 'Select' (Navi key).
22. Highlight 'GPRS access point' and press 'Select' (Navi key).
23. Enter 'giffgaff.com' and press 'OK' (Navi key).
24. Highlight 'Authentication type' and press 'Select' (Navi key).
25. Highlight 'Normal' and press 'Select' (Navi key).
26. Highlight 'User name' and press 'Select' (Navi key).
27. Enter 'giffgaff' and press 'OK' (Navi key).
28. Highlight 'Password' and press 'Select' (Navi key).
29. Enter 'password' and press 'OK' (Navi key).
30. When asked to 'Verify new password' enter 'password' and press 'OK' (Navi key).
31. Press 'Back' (right soft key) 3 times.
32. Highlight 'giffgaff MMS' and press 'Options' (left soft key).
33. Highlight 'Activate' and press 'Select' (Navi key).
34 Press 'Back' (right soft key) 4 times to return to the standby screen.
35. Press Menu button (Navi key).
36. Scroll to 'Messages' and press 'Select' (Navi key).
37. Highlight 'Message Settings' and press 'Select' (Navi key).
38. Highlight 'Multimedia Msgs.' and press 'Select' (Navi key).
39. Highlight 'Configuration Settings' and press 'Select' (Navi key).
40. Highlight 'Configuration' and press 'Select' (Navi key).
41. Highlight 'Personal Config' and press 'Select' (Navi key).
42. Highlight 'Account' and press 'Select' (Navi key).
43. Highlight 'giffgaff MMS' and press 'Select' (Navi key).
44. Press 'Back' (right soft key) 5 times to return to the standby screen.
The MMS settings are now complete.
Enjoy............
Sep 21, 2011 | Computers & Internet
When i press direct navigator on my remote to get to the options it displays "NAVI". What does this mean?
NAVI on the front panel display simply means on-screen menu navigation - ideal for unfinalised DVDs so you can check the recorded contents - such as the football or a music program. It is generally a normal user function whenever a readable (DVD-RAM/DVD-R/DVD-RW) disc is inserted. Pressing [OPTION] button brings a popup menu offering you options such as PLAYBACK DELETE etc. for the appropriate discs. Once you press [DIRECT NAVIGATOR] or [RETURN] on remote, NAVI should disappear from the front display.
This image is an example for a Panasonic DMR-EZ47V VCR/DVD combo (which I own), but the basic principle is the same. It should not cause you any real concern, unless it doesn't allow you to access the contents of a DVD you recorded in it. I hope this helps somewhat.
Apr 16, 2011 | Panasonic DMR-ES10 DVD Recorder
Navigation not working get disk reading error message upon starting car and every few minutes afterward
Check for a scratched or dirty Navi DVD disc. Clean or have the scratches polish out at your local game store. Video game stores usually have a disc repair machine that polishes out scratches.
Note: In some cases the Navi unit can cause rotational scratches on the DVD. If this is the case than the Navi unit will have to be replaced.
Oct 05, 2010 | 2003 Honda Accord
When i put a dvd +rw diusc into my bush dvr 3004 it wont accept
Regarding the Bush DVR3004 and the 'Smartnavi' screen, a workaround is to repeatedly press the record button on the remote while the "DISC LOADING" screen is displayed.
Apr 10, 2009 | Televison & Video
Dvd Gps Navi not exist
This took me weeks to solve because they dont give you a decent manual. It is necessary to have a good map on your sd card. You have to go into your map setup software and tell it which serial port and baud rate to use. otherwise it will display as you state.
Jan 21, 2009 | GPS
Place in ql for dvd/navi
place for dvd/navi for q7 is in the trunk under spear tire cover
Dec 30, 2008 | 2007 Audi Q7 4.2 FSI
Time settings
Press the reset button. It the small flush button on the faceplate. Insert the navi disc, at start up it would ask you to enter daylight saving mode or not(+/-). The graphics are in the navi manu, or you can import pictures from cd or dvd that have picture files. Goodluck.
Sep 22, 2008 | Pioneer AVIC-N1 Car DVD Player
Avic n2 says route calculation not possible.
Lots of burned disc are low quality and files are corrupted. The map is OK because it encoded on the outter layer. But when you try to access navi menu which is encoded on the second layer then it won't work. Buy older original discs, even severely scratch they still retains the file and works fine. Let me know if you need help to down grade to older version. Because new oem version can be expensive. Goodluck.
Sep 16, 2008 | Pioneer AVIC-N2 Car DVD Player
Daewoo DVG-3000N DVD Player Logo
Top Daewoo Televison & Video Experts
 Grubhead
Grubhead
Are you a Daewoo Televison and Video Expert? Answer questions, earn points and help others
