Question about Garden
Need fuel line diagram ryobi 410r tiller - Garden
  • 3074 Answers
SOURCE: Ryobi cultivator #RY60511A : Need
here is a manual,Tim:
http://lawnandgarden.manualsonline.com/mdownloads/38dcb043-331f-461b-a08c-072d67fc76c0.pdf
here is a diagram:
http://photos.hobbytalk.com/showphoto.php/photo/34693
in a nutshell:
1 connect top carburetor line to short nipple on primer bulb.
2 bottom carburetor line to fuel line with filter (inside tank).
3 connect remaining fuel line that comes out of fuel tank to the large nipple on primer bulb.
Hopes this helped Tim
Posted on May 29, 2011
  • 97 Answers
SOURCE: Ryobi Cultivator 410r
The linefrom the tank with the filter goes to the mixture inlet on carb. The fuel return goes to the suction side of bulb. The bulb outlet line goes to the tank. Hopes this helps
Posted on Mar 20, 2009
SOURCE: tiller doesn't run
There are two pictures of the position of the fuel lines at this site, http://www.hobbytalk.com/bbs1/showthread.php?t=147204. You will have to register in order to get the pictures. The registration is free. Hope this helps.
Don
Posted on Apr 13, 2009
kel1guy2002
  • 3740 Answers
SOURCE: What carburetor fits ryobi 410r tiller?
http://www.oscar-wilson.com/MANUALS/BOLENS/21B-121R765.PDF there ya go..
Posted on Jan 29, 2010
rycgl
  • 1545 Answers
SOURCE: replacing fuel lines on ryobi weed eater,need
This is an ongoing issue for users, and rightfully so. Small diameter line out of fuel tank (has filter in-tank on end) connects to the side of the carburetor that has the fuel pump....that is the cover without the hole in it. Other larger diameter fuel line out of tank connects to the longer nipple on the external purge/primer bulb. The bulb "pulls" fresh fuel from the fuel tank to the carb and then out of the carb to itself, where it then pushes any air/old fuel back into the fuel tank. The remaining larger diameter fuel line in this setup goes from the metering chamber (has cover with writing on it and a vent-hole) side of the carburetor to the smaller nipple on the purge/primer bulb. Years ago on 2-stroke trimmers, primers were not even used,...you choked the carb with a slide lever and gravity let fuel enter the carb from above...a few pulls, a "pop"...slide it off of choke and away you went.
If the purge/primer bulb is on top of the carb...small line from carb body to small hole in tank with filter. Larger diameter line goes from the bulb on the fuel pump side of the carb to the larger hole in the fuel tank where the line is held in place with a nylon nipple connector that keeps the line from pulling out of the tank.
Posted on Jul 10, 2010
Piston position?
Look closely at this exploded diagram.
It appears the piston 'relief' goes to the flywheel side.
Ryobi Tiller 410r Parts List
Jan 01, 2018 | Ryobi Cultivator
Hello, my Ryobi 410r tiller/cultivator needed new fuel line so I bought the fuel line, return and a new bulb primer. Unfortunately, I can't remember what hose goes where!!! Specifically, I've...
The primer pulls fuel through the carbruetor
So take your return line from the carb. and hook it to the inlet side of the primer and the other side
of the primer bulb transtions into the fuel tank.
You know when you have hooked it up right when you press the primer it fills with fuel and dumps back into the tank.
Jun 16, 2011 | Ryobi Garden
Fuel oil mixture ratio for ryobi 410r cultivator
I have a 410R still looks like new.
it has on it gas & oil = 40. to 1 for mixture.
mine never gets used so it is still new.
Jun 23, 2010 | Ryobi Cultivator
Needs new primer
You are searching for part number 181558. It is a snap in primer bulb with a piece of fuel line.
Oct 02, 2009 | Ryobi Cultivator
Ryobi 410r cultivator needs intital carb adjust ments,where do i start,how vmany turns on idle and high idle?
screw in lightly till seated then back out 1 turn each. low is for idling and turn in or out for best idle then run full throttle and do the same for it, get highest rpm then turn out 1/8 more on the high jet.
Jul 10, 2009 | Ryobi Cultivator
Gas tank leaks on a 410r how do we take it off.
remove the screws holding the recoil cover off I would think and go here for parts and use your model numbers to find your unit.
www.ereplacementparts.com/ryobi-tiller-parts-c-7931_15702.html
Jul 01, 2009 | Ryobi Cultivator
Unable to start Ryobi 410r cultivator
After starting close the choke , push the lever back in
Vitally
Jun 02, 2009 | Ryobi Cultivator
Need Replacement Gas Line for Ryobi 410r
They have the parts your looking for at www.lawnmowerpartstore.com
Apr 12, 2009 | Ryobi Cultivator
Tiller doesn't run
Don
Mar 18, 2009 | Garden
Garden Logo
407 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
