Question about Black & Decker String Trimmer Cordless 12" 18V
Need to rewire the strimmer but the wire keeps unravelling
What is the wiring sequence for the ignition switch on a John Deere CR125 ride on mower
Go on BING images, put in John Deere Ignition switch diagram and all sorts pop up. See if that helps. Most are the basic switch setup. Keep a copy for the future.
Nov 15, 2014 | Garden
Why does my strimmer line keep fouling the drive shaft
It may be too long. Cut the excess length and keep it no more than 1 inch from the hole.
Sep 20, 2014 | Garden
Once i cut strimmer wire to correct length, i then turn on power on strimmer, and without the wire touching anything it pops out long again.?
Ian your'e either not winding it the right way or your not getting the head to click in properly. Try winding the cord the opposite direction first.
Sep 05, 2013 | Garden
Rethreading a garden strimmer
Hi Deborah,
You need to start from the beginning of the trimmer string. Remove the entire spool. Insert the start of the line through and wedge it into the little groove to keep it from coming loose. Now wind the line tightly and neatly in the direction shown on the spool. (it should provide an arrow stating to "wind this way". As you near the end of the line, keep it snug and push the end through the hole where it leads out to the cutting zone. As you re-insert the spool into the housing, make sure it stays tightly wound as you lock it into place. This should help. Usually when your string is too short, you tap the **** of the spool on the ground to advance the line. It should feed a bit at a time, and when you hear it getting cut off, you should stop advancing the line.
Hope this helps.
Apr 13, 2010 | Black & Decker Garden
I am rewiring the dash and I had to remove the connector that plugs into the back of the dash and I hard wired instead, the wires aren't matching up and I need a schematic to see where the wires go.
I AM WIREING PROBLEMS ALSO HAVING I KEEP BLOWING FUSE NUMBER 10 IS THIS WHY YOU ARE REWIRING THE DASH FROM SHORTING PROBLEMS AND BLOWING FUSES .I WAS WONDERING IF THE ELECTRICAL IS A PROBLEM IN THESE CARS
Oct 11, 2009 | 1998 Buick Century
Strimmer cord keeps breaking
the eyelets on the trimmer head may be worn and cutting the line ..look for groves in the eyeleys may need to replace the spool
Sep 01, 2009 | Garden
Got a Black & Decker GL301 strimmer but have lost instruction manual. dont know how to fit new cutting wire
Go to Homebase, B&Q, Ebay or your local hardware shop and buy a new spool, ALM part number BD032.
Jun 01, 2009 | Black & Decker Garden
Black & Decker String Trimmer Cordless 12" 18V Logo
239 people viewed this question
Top Black & Decker Garden Experts
Nick Olsen
Roland W VanLue
Roland W VanLue
Tim Whalen
Are you a Black & Decker Garden Expert? Answer questions, earn points and help others
