Question about Garden
My weedeater lawn edger wont start. I get no gas in the primer bulb, but has fuel in both the main line and the return line. I blew out the fuel fliter and both lines but still no fuel in the primer bulb. I also put in new fuel and a spark plug. Do i need a new carb? What should I do or check next?
    President:
  • 1,545 Answers
There may be a malfunction in the check valves in the primer base assembly. Before attempting to get a new assembly, take the retaining screws at the bulb off, remove the bulb and spray the assembly liberally with WD-40 or an equivalent light lubricant. Sometimes this will free the check valves as they only let fuel flow one way and there are 2 of them in the primer base.
Do not use strong solvents, do not ever soak, and never use high PSI compressed air on these carbs. Sometimes, when the check valves in the primer base go bad, the carb floods and the reason is unclear. Zama doesn't list this as a reason for their carbs flooding, but they can. You may wish to view a parts breakdown list for your specific carb. You will need to know the type (stamped in side of carb body) and the model (stenciled in side of carb body). It will be something like a C1U type and a W-18A mode...thus its a C1U-W18A Zama carb. Here is a link to get you started.
http://www.zamacarb.com/pdfs/APPL_CR2010.pdf
Yours will be listed under Poulan/Weedeater
Posted on Aug 22, 2010
Why my weedeater idle to high and why air bubble in the primer bulb?
Its not un common to have air in the primer bulb, Check for a possible air leak in the system. This will make the saw idle higher than normal if its sucking air from elsewhere.
May 19, 2016 | Garden
I replaced my primer bulb on my craftsman weedeater an am not sure what line goes where on the primer bulb can you help also not the gas leaks out of carb hole where
In regards to which pipe goes where, it's simple. If you pump your primer bulb with the pipes off, one side will suck and the other side will blow. The suction side will link to the outlet on the carb. The blow side will link to the return to tank. The fuel line with the filter on it will link to the inlet pipe on the carb.
May 12, 2016 | Craftsman Garden
How to get gas on primer bulb
Make sure your fuel lines are tight and not leaking. I would also change the fuel filter that is in the gas tank.
May 03, 2016 | Garden
Poulan P2500 weedeater want start
change over the fuel lines on the carby
Mar 24, 2016 | Poulan P2500 17" Gas Trimmer
Primer bulb not filling
Bulb or fuel line could have a crack or a clog in fuel line/filter or carburetor. Here's a video on how to change the bulb and fuel lines and another video on how to clean/rebuild the carburetor.
Homelite Tune Up
Homelite weed eater gas trimmer will not run how to rebuild weedeater...
May 02, 2014 | Homelite Mighty Lite Lawn Trimmer
Primer does not work
Homelite Tune Up
Apr 22, 2014 | Homelite Mighty Lite Lawn Trimmer
Gas line routing weedeater
What particular model, i can send you the IPL
Jul 30, 2012 | Husqvarna 530069599 Weedeater Fuel Line...
Fuel line replacement location. lines were old broken off. i don't know the replacement location. Weedeater Model # BC2400
one line goes from tank to primer bulb one from primer bulb to carb and usually a return line from carb to tank
Jun 28, 2010 | Garden
I re-tubed my trimmer and now the bulb won't prime
I had exactly the same problem. On my weedeater, there is a screen in the carb under the primer bulb that was dirty from the fuel line falling apart. After replacing the fuel line AND cleaning the screen, the primer bulb will move fuel and it runs great.
Jul 06, 2009 | Craftsman 25cc Gas Line Trimmer
Featherweight weedeater primer bulb repair?
featherweight weedeater - runs rough and has no power
Jul 03, 2009 | Garden
Garden Logo
737 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
