Question about Garden
How to replace line on a bolens bl110 trimmer. I can't get the spool off.
Help
Posted on Apr 26, 2011
  • SanDeeS679 Apr 26, 2011
    I need help to
The head on my Bolens BL110 weed eater is slipping
Check the drive shaft. Within the drive tube there is a tightly sprung drive shaft, check where this connects to the head of the cutting attachment, it could have a worn drive.
http://www.ereplacementparts.com/mtd-bl110-41ad110g965-trimmer-parts-c-20039_20040_143532.html
Apr 10, 2016 | Garden
The line that I'm looking for came as stock supplied when I bought the trimmer.I can't believe that Bolens doesn't have a scource for replacement line. Help. Gene
Genuine MTD 791 181460B Reel Line Assy McCulloch Ryobi Troy Bilt Bolens OEM
Reel and Line Assembly
Bolens String Trimmer Spool 791 153577B
the spools come with line already installed,they are all for bolens,line is generic,you buy your own line,there are 2 different sizes,and a bunch of types,like round or star,you buy generic line because bolens wont make any money if they sold "BOLENS" line.
Jul 11, 2015 | Garden
Bolens bl110 weedeater runs until I try to cut
Adjust carb. Initial adjustment is 1 full turn out on both low and high side. If it still fall on it's face, turn the low side out and additional 1/4 turn.
Sep 24, 2014 | Garden
I have a Bolens BL110 starts fine but dose'nt rev at all
Bolens trimmer sputters and stalls and only runs on half choke? Here's how to fix it.
Look on the top of the carburetor and you will see 2 black screws that are mostly round with a flat side recessed in the aluminum housing. They are flat on top and have no notches to insert a screwdriver. The trick is to turn these two screws 1/4 turn counterclockwise. I have a set of precision pliers and used the fine tipped needle nose to turn them.
The other option is to try and notch the top of them enough so you can use a flat blade screwdriver. You can grind down the surrounding aluminum with a Dremel tool so you can access them better.
You can see in the picture that I scratched across the top of the screws as a reference to see how far I was turning them.
Mar 17, 2013 | Garden
What could be causing this?
to much dirt got up in clutch housing and shoes are not making full contact unit needs to be dissembled and cleaned.
Sep 06, 2012 | Garden
I have a Bolens BL110 Trimmer - it starts just fine, but won't rev up completely. Suggesstions?
Could be blocked spark arrestor or carboned up in the exhaust port.
May 06, 2012 | Garden
My pull string came out and will not retract on my Bolens BL110 2 cycle gas trimmer. How do I fix this?
the coiled rewind spring ends are bent back in a hook. the hook usually breaks so springdoes not wind up. some times you can re bend but steel is very brittle and keeks breaking and must be replaced
Jul 17, 2010 | Mtd Garden
Replacing the rope
If you are looking at the spool itself, turn it counterclock wise, without wineing string.
May 19, 2009 | Troy Bilt Tb70ss Gas Trimmer
Garden Logo
1,520 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
