I keep getting error message for my scanner it worked in Windows XP and now it will not run in Windows 7 I can't afford a new printer It is a Hp Photosmart all in one C4400 series the software is Q8383-10002
  • 37 Answers
There are 9 different HP Photosmart C4400 All-In-One devices. The Windows 7 driver is available on HP website [www.hp.com]. Select "Software & Driver Downloads". If you are running Windows 7 you will need to select either the 32bit or 64bit driver. If you are still having problems, write back. -- SWT
Posted on Aug 22, 2010
Printer won't work with HP WIndows 7
I regret to inform you that the Lexmark X75 does not support Windows 7. It works on Windows XP and previous versions.
You may contact Lexmark Technical Support Center to check for other options.
Feb 20, 2012 | Lexmark X75 All-In-One InkJet Printer
I just upgraded from an old dell (windows XP) to a new machine running windows 7. I have an hp scanjet 4570c scanner that I want to use. It ran fine on XP, including the HP director software and the HP...
if you still have the installation disc for the printer use it when adding a printer to the win 7 os
or go to hp download site and download the drivers for the printer
or may be go to the printer properties tab , click on compatibility and tick the box and high light win7 os and apply
Apr 15, 2017 | HP Scanjet 4570 Flatbed Scanner
I have a Canon 4200F scanner and recently purchased a new computer with Windows 7 that is 64 Bit. When I try to use the scanner get a message that I need a WIA driver to use this device. Can you please...
Hi bjgestel !
This means there is no more support from HP for your unit under Windows 7 but Windows has a compatible driver included in it's system ( WIA ) .
The scanner should run smooth but with some restrictive functions . Normaly , it should run without having installed the HP XP driver/ sofware . If this not your case , there is a workaround after you installed the XP driver and made sure installation was successfull . The scanner will need to run with a third party application . Download FreeKapture from
http://download.cnet.com/FreeKapture/3000-2094_4-10673689.html
Launch Freekapture , clic on Scan , select WIA-Hewlett-Packard . Your scanner will run . If you choose HP's software, program will hang .
Note : no slides or negatives scans possible in WIA mode but the rest works .
Good luck !
fanaudi .
Feb 22, 2011 | Office Equipment & Supplies
Scanjet 5470c with WIndows 7?
better download the latest driver for your scanner from the hp's website and while selecting the new driver you have to specify that you are using windows 7 and also specify if it is 32 bit or 64 bit you will get the driver , install it and connect the scanner it will work ..... thats all....
Feb 04, 2010 | HP Scanjet 5470c Flatbed Scanner
HP scanner will not scan, but will print
reinstall drivers and restart the whole system
May 07, 2009 | HP PSC 2110 Color Printer
HP PSC2355p all in one, cannot use scanner, error messages, cant
Try going to windows update, use administrator options, and download and install windows installer 3.1, and then try re-installing your printer.
Feb 10, 2009 | HP OfficeJet 7410 All-In-One InkJet...
Won't scan nor fax
HP multi units are notorious for scanner failures. It is just a weak component in their machines. I have seen this time and time again. The only solution is to change the scanner out or purchase a different machine. Just keep in mind the notoriety HP has which failed scanners. If you want to venture into the replacement of the scanner the following website might have the product you are looking for. Otherwise, search around the net for a scanner assembly unit for the OJ7310. But, be prepared scanner units are not cheap.
Check here first...PrinterFixer.net
Nov 13, 2008 | HP OfficeJet 7310 All-In-One InkJet...
Error message : You need to install or run device software for this feature
Make sure you are logged in as Administrator when installing drivers, in order to write files in the system area.
RDO
Nov 07, 2008 | HP OfficeJet 6210 All-In-One InkJet...
162 people viewed this question
k24674
jasbo
jasbo
