Question about Sport & Outdoor - Others
I have a coleman pocket 2 single burner stove model 505. It is leaking fuel from the black leaver. Are parts available?
SOURCE: Coleman stove, model 412-5621, will
disassemble the pump by removing the c-shaped ring aroudn the metal cap. a flathead screwdriver will work to pry off the ring.
pull out the pump assembly. The end is probably a old dried out leather ring. It needs oil (car motor oil shoudl be fine) and it needs to make a tight seal.
if it is too loose, it might be possible to press it out to make it wider. If not, it needs to be replaced. The pump assembly is about 8 dollars at many stores.
Posted on May 02, 2008
mikedem7
  • 25 Answers
SOURCE: why is my stove causing a thick coat of soot to buildup on my pots?
you have to adjust the air intake holes at the valves. this will give you a blue flame.
Posted on Aug 19, 2008
jaballou
  • 63 Answers
SOURCE: need to fix regulator for coleman stove 5410708
Just where the regulator attaches to the burner there is a small nut that may be loose. If you look closely at this and turn the regulator (stove off and hose detached!) you may see the nut hat turns easily. Tighten it and make sure the regulator does not rotate too freely, but still turns to adjust when attached to the hose or the smaller gas cartridge, if using that. Test carefully after this.
Posted on Feb 10, 2009
SOURCE: Replacement Parts For Vintage Magic Chef stove
You probably have a 1940's model of Magic Chef. Check for the model number under the lid of the cook top on the upper right hand side of the stove. It should have the model number and the serial number, too. You will need both. The Old Applicance Club run by Jack Santoro is the place to go along with a site called "Antique gas stoves"in Georgia. Good luck with the world of vintage stoves.
Posted on Apr 06, 2009
SOURCE: Coleman Peak 1 Model 400
My Peak 1 is 30 years old, and the only time it ever happened was the first time I used it, and I overfilled the tank. It needs some air space to comporess ans the fuuel is incompressible. The ley to this is to keep the whole stove level when you fill it. If you hold it so that the fuel filler is level, it will over fill the stove -- that is why the fuel filler is on an angle. Granted it is hard to fill that way, but Coleman makes (or used to make) a special aluminium funnel that fits into the filler pipe that makes it easier. Actually this is true for any white gas Coleman appliance -- note that abolustely all of them have the filler on an angle.
Posted on May 15, 2009
How do i light 533
can you tell me more about your model?
Mar 14, 2014 | Coleman Camping, Backpacking & Hiking
Coleman 5423b701
Try Coleman directly.
The Coleman Company, Inc.
3600 North Hydraulic
Wichita, KS 67219
1-800-835-3278
Sep 01, 2013 | Coleman Camping Stove 2 Burner Propane W/...
How do you remove the burner part of a coleman grill/stove? I trying to give it a good clean. I got the 4 screws off and grill fuel bar, but for the of me, how do you remove the burner part. Kelly
The Coleman website has a pretty excellent list of owners manuals. (Here's the link for the 9921A700)
I believe that you unscrew the burner assembly on the right, which will then let you remove the cooktop to clean inside and re-assemble.
This procedure is not listed on the Coleman website or in the owners manual, however it appears to be fairly straightforward. I'd recommend using some teflon tape on the threads when screwing the burner assembly back on.
Aug 18, 2010 | Coleman Propane Grill Stove 9921-700
Coleman single burner 502 camp stove. About 20 years old. Not used for almost 20 years, Questions: 1.) what type of gasoline fuel? white, leaded or unleaded regular? 2.) what "tune-up"...
Hi William, your cooker is one of the best models. If unused for many years the seals will need checking as they harden over time.
Here is a great site for people who this cooker:
http://www.spiritburner.com/fusion/showtopic.php?tid/15306/
Jun 12, 2010 | Coleman 10' X 10' Sundome Tent 9160K101
VALVE WHEEL LEAKS
Here is Coleman's repar part website.
You may want to replace the valve if it is leaking.
http://www.coleman.com/coleman/parts/product_category2.asp?category_id=210
Jul 21, 2009 | Coleman 2 Burner Dual Fuel 424-700G Grill
Coleman 424 Dual Fuel -- High, yellow flame
Are you pumping the tank up all the way? I have the same problem if I have too little pressure in the tank. The instructions say pump 35 times. Try pumping 50 or 60 times- that seems to help.
Also, you can't light this one like an old 425. My old stove you could turn the gas on and then take a match neat the burner. For this stove, hold the match near the burner with the gas off and quickly turn it on.
These are two things that seemed to help me with the same problem.
Jul 11, 2009 | Coleman 2 Burner Dual Fuel 424-700G Grill
Coleman 425 2-burner white gas stove pops out flame on low heat
There is water in your fuel. Drain the tank and flush it out with denatured alcohol. Refill with fresh fuel.
Jun 21, 2009 | Coleman Sport & Outdoor - Others
Need to fix regulator for coleman stove 5410708
Feb 06, 2009 | Coleman 2 Burner Propane Stove 5430E700
Why is my stove causing a thick coat of soot to buildup on my pots?
Aug 16, 2008 | Coleman Propane Grill Stove 9921-700
Sport & Outdoor - Others Logo
441 people viewed this question
Top Sport & Outdoor - Others Experts
Are you a Sport and Outdoor - Other Expert? Answer questions, earn points and help others
