Question about Moen T2529 Monticello Single Handle Standard Tub/Shower Trim Chrome
Please tell me how to tighten the off/on handle. It is loose and I can't figure out how to take it off or tighten it. This unit was installed about 3 1/2 years ago. Thank you very much. George
    Problem Solver:
  • 6 Answers
There is an Allen "screw" which is threaded in from the underside of the handle.
Simply tightening this screw 'should' tighten things up.
If that doesn't work, perhaps the Allen screw needs to be replaced.
If you have the Allen wrench to fit, you don't even have to turn off the water supply, just turn the handle up and let the water flow for the time it takes to snug it up.
Posted on Aug 24, 2010
The cold water handle is flopping around and seems to be in need of tightening but I can't figure out how to tighten it
There is a little allen screw under the handle. It is loose get a little allen wrench that fits use long end and tighten
Hope this helps Mike
Jan 30, 2016 | Plumbing
Moen loose faucet handle model ca87011srs. Cant figure out how to tighten handle.
The logo spoken of is a little piece of plastic stuck in the hole that the setscrew is hiding in. Pop it out and check the set screw.
Nov 30, 2013 | Plumbing
HAVE MOEN MODEL INS792A WIDESPREAD 2 HANDLE BATHROOM FAUCET - LOOSE HANDLE ON LEFT SIDE - KEPT INSTRUCTIONS (PICS ONLY) - CAN'T FIGURE OUT HOW TO TIGHTEN LOOSE HANDLE - HELP??? THNX!
There is a cap on the top of the handle which can be removed by popping it out with a knife or a small flat tip screw driver. Inside you will see a screw which holds the handle to the faucet. Tighten this and replace handle cap.
Sep 01, 2010 | Moen & Villeta Two Handle Lavatory Faucet
DOOR HANDLE LOOSE MODEL#gs5shaxnq00 Whirlpool sxs Ref side
Ther is nothong wrong with the ice Dispensing unit the screws in the door handle are loose and we can not figure how to tighten them.
the model# is GS5SHAXNQ00
Aug 29, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Loose handle on door
The door handles mount on hex bolts sticking out of the door, the door handles have key hole inserts that match with the bolts. The door handles are then slid in one direction to lock the handles in place. Removal is the reverse. To tighten the door handle screw the bolt out enough that you can still put the handle over the bolt heads and slide the handle to lock the handle in place.
Apr 12, 2009 | GE Profile Stainless Bottom-Freezer...
Mini wide spread vanity tap handles ( mostly left ) are loose.
if there is a cap on top, remove with a sharp object(razor knife) and tighten phillips head screw Just guessing but this is a common setup
Jan 14, 2009 | Moen T4945/9300 Castelby Two Handle Mini...
Door handles loose
i have a whirlpool conquest side by side and had loose handles,couldn't figure out.but then i grabbed handle and push in and up,handles slide off you can then tighten bolts then slide it back on.hope this helps.n
Oct 14, 2008 | Whirlpool Gold White-on-White 21.9 cu. ft....
grab hold and pull straight up!! itll be tight but just pressured on, theres an mounting screw under there, then just pull back down and on
Feb 25, 2008 | LG LRFD22850 Bottom Freezer Refrigerator...
Door Handle repair
The fastner must be loose. Remove both set screws remove your handel. Then tighten the fastner. reinstall the handel and tighten your set screws. let me kniow if this helps
Aug 18, 2007 | GE GSH25JSTSS Stainless Steel Side by Side...
Moen T2529 Monticello Single Handle Standard Tub/Shower Trim Chrome Logo
141 people viewed this question
Top Moen Home Experts
Mike
john h
Andrew Bugbee
Are you a Moen Home Expert? Answer questions, earn points and help others
