When scanning or photocopying I get two thick black lines down the edge and the middle of the page.
  • 86 Answers
If you are using a fax machine, open top cover and clean roller with cotton cloth with some alcohol in it or take it to technician shop and have rollers replaced.
on scanners or all-in-one printers, this is a scanner head problem, take it for repair or buy new one (the cheapest).
Posted on May 04, 2008
I have a big black line down the middle of my scans
If dirt sticks to the scan module, it will be scanned continuously and appear as a line in the output. Clean the glass with Isopropyl Alcohol. Dont use any other solvent.
S. Mohan, India
Mar 12, 2013 | Canon DR-5010C Scanner
Line down middle of scan
A line could be continuous scanning of dirt stuck to the glass or an error in the Sensor module. Please clean the glass thoroughly with Iso-propyl Alcohol. If the line has rough edges (varying thickness) it is definitely dirt on the glass.
S. Mohan, Chennai, India
Mar 05, 2012 | Canon DR-9080C Path-Through Scanner
When I am photocopying and scanning documents I am noticing vertical lines on the print in the middle of the page which is ruining the copy, any ideas? Alos message intermittently coming up waste toner...
Most probably you are using the automating document feeder for the photocopy or scanning. If you can lift up the document feeder , there should be the mirror where you can put the original document for manual photocopy or scan. Clean the edges of the mirror with a printer cleaning liquid. There may be some foreign particle stuck there or it is just dirty from long use. Hope this helps.
Sep 02, 2011 | Office Equipment & Supplies
I am getting a thick black lline on my scanned immages
You need to adjust the position center of the scan materials.. The scanner pulls sheets fronm the center of the feeder. Using a single sample page to scan.. You need to move the feed guides the same distance as your black line - either to left or right as appropiate.. (Which side is the mark?) to find the center w/out leaving black line edges. Keep adjusting it till you eliminate the black line. Foxed me good first time I saw it..
Nov 15, 2010 | Canon DR-3080CII Path-Through Flatbed...
Black lines on scan
Dear all
I have the same problem Please Help
Mark
Jun 04, 2010 | HP ScanJet 2300C Flatbed Scanner
Black line through the middle of the document
The thick line is either because of dust sticking to the glass or a module problem. Try different brightness settings and scan white paper. If the thickness varies and also the sides of the black strip are jaggered (step like) then it is dust on Glass. use isopropyl alcohol to clean, dont use solvents. If the teickness is same for all levels of brightness and has a sharp edge always, it could be scan module problem.
S. Mohan
Oct 05, 2009 | Canon DR 3080C Path-Through Scanner
Thick Black Line in Middle of Printed Document!
Your question might best be answered at the website below
http://www.canon.co.uk/Support/index.asp
They have technical support plus drivers and other odds and ends concerning your equipment
Feb 22, 2008 | Computers & Internet
Thick Black Line on my copies and faxes
Can't image it being anything but scan glass, if prints are fine, are you sure you cleaning scan glass(inside of where originals are fed)?
If so then scanner lamp faulty, but I've never come across it myself on this model.
Oct 26, 2007 | Brother MFC 8500 All-In-One Laser Printer
392 people viewed this question
jasbo
jasbo
