I have a infocus n24+ w240 projector. I was watching tv when it dimmed and went out. I thought the bulb went so i had a old one that still worked. But it wont recognize it. So i researched online and saw the support page for Infocus on how to reset the lamp hours. But i cant see anything to do so and all the button reset combination's wont work. Can someone help me and give me a step by step or the right button combo to rest to factory setting or lamp hours. Thank you!
  • 26 Answers
SOURCE: INFOCUS Lamp replacement
If the counter had expired, the projector would not even attempt a power up. You have other issues. How many blinks on the light?
Posted on Feb 28, 2008
shawninsari
  • 11 Answers
SOURCE: RESET LAMP INFOCUS LP 70+
factory reset. master reset. shawn with avalontc.com
Posted on Aug 06, 2008
projdoc
  • 2237 Answers
SOURCE: infocus lp70+ projector turns itself off automatically
replace the power supply. it has enough power to start the colorwheel, fans, and to charge the ballast for the light, but as soon as the dmd chip turns on, it's just enough to overbear the ps.
Posted on Jul 15, 2009
SOURCE: Infocus 4805 Lamp will not ignite after new bulb and reset.
Hi my name is walter I have a infocus 4805
It was working with just a colostream , component out from my dvd- Player but I wanted to play my blue ray movies so I got me a Cable HDMI to M1D and decited to plug it in I click on menu on remote
And try to set it to the correct source no picture, and I guess on my remote I press Button( presets ) then menu image was still on but remote comand Did not respod I traid all the buttons on the remote none responded Untill I decited to unplug the infocus 4805 and I turn it back on the lamp light did not come on , but there is no blinkin red light on my 4805
If some one can help I will be greatfull THAK YOU in advance
? also I have Question if I decited to open my infocus is there any way To reset the internal computer from my infocus 4805 ?
Posted on Feb 23, 2010
projdoc
  • 2237 Answers
SOURCE: Cannot Reset Infocus LP 350 Projector after replacing a bad lamp
that model has a history of bad ballasts. you'll need to replace it.
Posted on Mar 09, 2010
Testimonial: "Of all the comments on lamps failing to power up, only this answer fits my circumstances. I eliminated other "solutions" posted on FixYa. Thanks!"
I have a InFocus IN35 w360, I have no idea how old it is, do you? The bulb had dimmed the other day and now it will not power up, is replacing the bulb the only thing I need to be aware of with this type...
More than 5 years old. After replacing bulb you have to reset the lamp hours as follows. To reset the lamp timer, navigate to the Settings>Service menu and select "Reset Lamp Hours"
Aug 15, 2011 | InFocus IN35 Projector
I have an infocus x3 projector and while watching a movie i heard a loud pop and the video went out. It sounds like glass moving around inside the projector. its fairly new and in a well vented room. Is it...
yes try to check the bulb if broken but when you replace the bulb be sure not to touch the glass surrounding because if accidentally touch the glass their will be a mark appearing on the screen.
Jun 29, 2011 | Televison & Video
InFocus LP 540 is extremely dim
Dim image is normally due to a defective lamp assembly. I'd recommend removing the lamp and inspect its condition. You'll notice a black corrosion build up around the filament of the bulb.
May 02, 2011 | InFocus LP540 LCD Projector
InFocus 4805 - right 1/3 is fine, middle 1/3 dim, left very dim.
the light tunnel is collapsing and needs replacement. the part itself is relatively inexpensive, but you have to be careful if you want to replace it yourself. it's under the colorwheel, which is delicate. when you remove the top, front, and rear panels, remove the colorwheel (which is between the lens and the lamp) and carefully set it aside. there are 2 screws holding the light tunnel bracket in place. remove them and the bracket. pull out the pieces of the tunnel (little rectangles of mirror) and replace with a new one. reverse the steps to put it back together. by the way, you can get the part from any infocus authorized service center (check the infocus website for the one closest to you). part # 306-0095-01
Oct 14, 2009 | InFocus ScreenPlay 4805 Multimedia...
IN76 Pojector Just Turned Off, Will Not Turn Back On
same thing on my in76. a color wheel had to be replaced. projector is less than a year old an all parts and labour was covered.
Dec 30, 2007 | InFocus Play Big IN76 Multimedia Projector
Televison & Video Logo
238 people viewed this question
Top Televison & Video Experts
