Question about Zenith Televison & Video
Have compact VHS movie camera model VM6200 Ser # 70101528.\Have cassettte installed and am unable to operate eject button to access cassette.??? Nothing happens when I actuate eject button.
SOURCE: Message reads eject. won't eject
My camera did the exact same thing. I called Canon tech support and they advised to unplug power cord, remove large main battery, and remove smallbackup battery. The small back up battery is under a small door under the main backup battery. With everything disconnected, turn camera to "camera" and then to "vcr" and then to off. Wait a few seconds. Put everything back together and try to eject again. The tech said that resets all the mechanical parts. However, it did not work for me. They now want me to send it to them for a paid repair. I have done some research on the internet and this is a VERY commom problem and it usually costs about $150 to correct via Cannon. Many times the problem occurs again. I am very very frustrated. I pulled my camera out last night to get it ready as my wife is 9months into her pregnancy. Now, I have to send my camera away for 5-9 days. Really really upset.
Posted on May 29, 2007
  • 6 Answers
SOURCE: cassette loading - keeps on ejecting cassette
The "remove cassette" problem on Canon DV cameras is a general fault error that can be induced by many varied problems from faulty dew sensors to jammed mechanisms. These mechanisms are small and delicate and it does not take much to stop them working. If the head drum is starting the next thing that should happen is the capstan spins which in turn drives the take-up spools when the cassette loads. Tape tension problems (other than a broken tape) would not be detected until after the capstan is running. With the battery removed and the cassette door open, CAREFULLY attempt to rotate the capstan spindle. I use a small rubber insulating sleeve stretched over a small screwdriver. If this does not solve the problem then other possibilities are that the printed ribbon cable from the cassette mechanism to the camera needs re-seating or perhaps the capstan drive motor is faulty. However, try and look for the obvious first. To investigate further by dismantling is extremely difficult and I would not recommend it unless you want to risk writing-off your camera completely. I have done this operation (successfully) as a last resort and found that re-seating the printed cable in its socket solved the problem, however, I would not recommend or suggest this decision be entered into lightly. Its a good feeling when you get it working again but sickening when you have to allocate it to the re-cycle bin. As I say, this fault indication has many causes. Getting it serviced by Canon is not an option as the cost would exceed its value so unless you can find a local repairer that's prepared to look at it, then you have very few options.
Posted on Dec 18, 2007
SOURCE: camcorder cassette holder stuck/won't eject
Try taking the battery out...
Posted on Jun 30, 2008
SOURCE: canon md101 manula eject
yup there is sort of... you take a jewelers flathead screwdriver and push the spring back on the lens side of the cassette holder. and then on the other side there is a little hook that latches over a bump that locks it in place, you push that down and it will unlock... from there you might have to take the extremely small screw out at the top and remove the whole cassette tray...
Posted on Aug 19, 2008
Bubbabear64
  • 2794 Answers
SOURCE: Have to reassemble VHS-C cassette
Tried searching for a diagram but didn't find one. Usually the spring goes to the plastic door protecting the tape. If the door isn't retacting, you should remove the door altogether and the tape should work as long as it is moving properly when you turn the take up roller on the tape by hand.
Posted on Dec 10, 2008
I have this vidio camera, Zenith VM6200 we don't have the manaul to find out how to get the tape out. I don't want to buy a 30.00 book for 1986 camera. Can you help anyone?
on the back there is a eject button, but you need to turn the camera on first, with the battery or power supply. Hope this helped
May 05, 2014 | Zenith Video Cameras
How can I eject a cassette from deck A it has taken the cassette and is not ejecting it nor is it playing it
The loading is not completing and so the mechanism will not release the forward eject of the cassettte to work. So please check on the belt and if this is worn then the loading will not work as it will slip and so will not complete the loading back to rest mode.
Jul 22, 2011 | Technics RS-TR575 Single Dual Cassette...
Need to know what Cassette for this model jvc gr-sxm245
You can use VHS-C (C for compact) or S-VHS-C cassettes. The S-VHS-C is Super-VHS, for better quality recordings, but there isn't that much in it compared to digital. I'm assuming your camera has the S-VHS capability, as the title, otherwise stick to VHS-C.
Dec 06, 2010 | JVC GR-SXM245 S-VHS-C Analog Camcorder
Panasonic VHS Won't eject Tape
unplug then remove the top cover press down on the cassette release and remove the tape then rewind the part of the tape still sticking out by hand push in the button on the side of the cassette to open the cassette cover
May 21, 2009 | Panasonic PV-7400 VHS VCR
Zenith xbv713 won't record on vhs tape
is the tab on the cassette in place? if it has been removed the cassette will eject automatically when pressing the record button.
Jan 05, 2009 | Zenith XBV713
Canon ZR900 cassette won't eject
you could hit like the method for if a canon won't let you put in a cassette but i don't know if that will work. just hit it on the non screen side a few times and in theory it should work.
if nothing it will get rid of stress
Dec 12, 2008 | Canon ZR900 Mini DV Camcorder
Akai VS-J716EA
Please manually unload the cassette, and refix the cassette mechanism
Nov 06, 2007 | Akai VS-J716EA VHS VCR
Can't get disc to eject
open the unit. locate the motor which performs the task of ejecting tray. now spin this motor by hand. wait...5 discs (disc-or did you mean tape?) in unit at once? Are you sure? Well Hello Dolly!
Aug 13, 2007 | JVC HR-S3911 S-VHS VCR
Televison & Video Logo
56 people viewed this question
Top Zenith Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a Zenith Televison and Video Expert? Answer questions, earn points and help others
