Question about Northern Industrial Tools - Northern Industrial Rotary Hammer - 3100 BPM, 800 RPM, 7.6 Amps
I bought this roto hammer at a pawn shop and did not get a user manual with it. I noticed there was some grease that came in the case. My question is what part needs the grease and is there a user manual available. Thank you
The grease is for the chuck as SDS chucks often seize up
Posted on Aug 22, 2010
Where can I find the instruction manual ?
You bought what from a pawn shop? You can type the make and model of your device into a search engine like google.com and add the word "manual" to it---like this:
Brand CD player XX-400 manual
May 05, 2014 | Office Equipment & Supplies
I bought a toshiba satellite C855D from a pawn shop how do i change the system name?
Go to control panel. choose User Accounts. Create a new Administer Name and Password. Delete the one you don't want and re boot.
Feb 28, 2014 | Computers & Internet
Takes a half hour to start rotary hammer function
All grease packed hammers require a certain period of time to warm up. Depending on the room temperature, this time may vary from approximately 15 seconds (90'F) to 2 minutes (32'F). A new hammer requires a break-in period before full performance is realized. This period may require up to 5 hours of operation.
- depending on the time the device has already been in use it is recommended it should be regreased with a special gear lubricant, - perhaps the grease inside has been used up already, then a proper function of the device is not possible anymore and it has to be serviced.
Dec 18, 2013 | Bosch 11236VS Rotary Hammer
Takes long time to start hammer function
If the hammer function works once it warms up, then it's not broken - it's probably just plugged up with contaminants. You may need to disassemble to clean it out, although first I would get some Electrical parts spray , unplug unit,and soak down the inner workings while MANUALLY moving the shaft in and out, alternating spraying and moving. Let it finish dripping, then use a heat gun on low setting or a hair dryer on high setting to dry out the internals, then try again. Repeat procedure until hammer function works, then lubricate. You need to get the junk out before you lube, or it will make a bigger problem.
Hope this helps!
Dec 17, 2013 | Bosch 11248EVS 1-9/16" Spline Drive...
Need User Manual & Remote Control
I set up this link that will take you to download your When you get scroll down and select there, select download
http://www.manualowl.com/m/Phillips/FW-C579/Manual/163091
Feb 05, 2012 | Audio Players & Recorders
I bought gps at pond shop and it's asking me for pin?? what should i do?
Return the unit to the pawn shop. This is a PIN put in by the original user just in case it gets stolen. If the original user sold this to the pawn shop they would of removed the PIN or provided it to the pawn broker. If it was stolen there is nothing you can do but throw the unit out if the pawn broker will not help.
Cheers
Jesse GPS City
Jul 13, 2010 | Garmin StreetPilot c550 GPS Receiver
Instruction Manual
Please click JVC Support to download user manual copy of GZ-MG330H in pdf format.
Mar 09, 2009 | JVC Everio Digital Camcorder
Northern Industrial Tools - Northern Industrial Rotary Hammer - 3100 BPM, 800 RPM, 7.6 Amps Logo
141 people viewed this question
Top Northern Industrial Tools Tools & Hardware - Others Experts
john h
Are you a Northern Industrial Tools Tool and Hardware - Other Expert? Answer questions, earn points and help others
