Question about Saeco VIA Venezia
THINK I LEFT MACINE AND STEAMER ON ALL DAY NOW NOTHING WORKS DOES NOT HEAT UP
Hi i have experienced the same thing and stumbled accross the solution if you take the main cover off and look at tha tank there are 3 heat sensors the centre one has a tiny reset button in the centre of it just push it down and you should hear a click
let me know if it fixes it
michaelp@ralphdsilvaholden.com.au
Posted on Jun 07, 2008
The machine heats up and the steamer works, but nothing comes out of the spout. No noises, or anything. Just heat and steam out of the steamer. I don't think it's even pumping water.
and that is probably why it was in the garage sale
it doesn't work
you could take it to an appliance repair shop for a diagnosis of the problem
Nov 06, 2016 | Coffee Makers & Espresso Machines
Shark Super Steamer
The steam generator is defective.
Aug 28, 2016 | Euro-Pro Shark Super Steamer
Delonghi stiromeglio master steamer iron , why no steam to the iron?
If you have been using tap water it may be plugged up with minerals.
Sep 13, 2014 | Coffee Makers & Espresso Machines
Home touch garment steamer model ps-280 wont turn on
If it were left on its possible that the element that heats the water has burned out think blown light bulb have your Mr Test it with a ohm meter to see if the circuit is open
May 02, 2014 | Garment Steamers & Presses
Gets super hot but steam won't come out.
i have a simular steamer made by a different company. it used to work when i had first gotten it, but i think one time that i had plugged it in for a long period of time without using it has caused the plastic parts under the trigger that releases the steam flow to melt. so now the steamer that i have still heats up really hot but when i try to push the button it does nothing, no steam will come out of it at all... so i think my mistake was plugging it in without using it for too long, making it now inoperable basically garbage. sorry to say
Apr 17, 2014 | Scunci 52067 Handheld Steam Vacuum
I have a Nesco electric 6 qt pressure cooker PC6=25 / Digital Pressure cooker, I went to use it, it worked for a while, then all at once everything turns off...nothing....I think it may have blew a fuse,...
A THERMAL FUSE IS LOCATED INSIDE THE COOKE BETWEEN TERMINAL AND ELEMENT(HEATING) IF YOUR HAVE ELECTRICAL KNOWLEDGE YOU CAN RECTIFY OR ELSE CONSULT PROPER TECHITIAN .
Oct 19, 2013 | Nesco PC6-25P 6 Liter 3-in-1 Digital Pres....
I have a Krups coffee/espresso maker, with a milk steamer. It makes great coffee and espresso; however, the steamer is not working. It is not clogged; I cleaned the handle with a fine needle, and water...
There must be a blockage in that steam pipe, I think you need to dismantle the machine and remove all of the steamer parts off the boiler and look for the cause of the problem. Oftentimes it will be old hard milk that has been drawn up the pipe and gone hard from the heat. Once cleaned out prevention by blowing a large amount of extra steam through it after each use is the solution.
Apr 22, 2017 | Krups Gusto 880-42 Espresso Machine
I have a shark steamer, light is on but no steam. ...
Nope...no cleaning to it...
Here is a tip that I wrote about the Euro-Pro Shark Steam Mop and why it maynot be getting steam to the head...
Euro-Pro Shark Steam Mop Problem
Here also is a link to get any of the Shark Manuals that you need.
heatman101
May 20, 2010 | Euro-Pro Shark Steam Mop - Gray/ Purple...
Starbucks sirena won't heat up; blue light flashing-brand new
johnshami had this solution on another post, and it worked for us:
  1. make sure the water in the tank is stone cold -- which is a no brainer since it will not heat h2o unless it's primed.
  2. take off steamer wand cover, turn the steamer knob clockwise till pump starts.
  3. then s*ck (as you would on a straw, with your lips sealed around the end of the steamer wand) the tip of the end of the metal tip hard until pump stops
  4. may need to do it a couple of times. yes this seems crazy, but it works! you are flushing out the vapor lock in the pump.
Sep 27, 2009 | Saeco Starbucks Sirena Espresso Machine
Saeco VIA Venezia Logo
119 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
espressofixr
Level 1 Expert
just-ice
83bj60
Level 1 Expert
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
