Question about Nvidia GeForce 7300 LE 256MB PCI Express Graphic Card
I am trying to set up an HP zr30w monitor (2560 x 1600) in an HP M7790y PC with a GeForce 7300LE. The monitor shows the start up screens, but remains blank following the Microsoft progress bar that precedes Windows. HP sales claims that my current hardware & card are compatible with the zr30w. A CD driver update was included and does not seem to allow me to increase the resolution, which I believe is the problem. Any suggestions?
Computer will not boot to normal and verticle lines on monitor, dell XPS410, windows vista 32 bit
Unplug the monitor video cable from the computer. Power on the monitor and see if you get the same results. If so then your monitor is defective.
Oct 11, 2012 | Dell Computers & Internet
My hp monitor blinks agreen light but no light displayed on the screen please whats the solution
Either a issue in the power supply of the unit or something related to the display panel itself.
Says here a 30 inch?
Jun 16, 2012 | HP Commercial Specialty Performance ZR30w...
How do i upgrade inbuilt graphics?
You probably need to go into the Bois settings and disable the on board graphics. To do this you will need to start by being plugged into the on board graphics and have the GeForce card plugged in. Turn the computer on and during the HP splash screen, you sill see some options. I believe the setup option is F10. You will need to press this key to enter the setup. You will now need to locate the video options and set the source to the PCI-E. This will disable the onboard and enable the GeForce card. Once you save this setting and reboot you will need to move your monitor cable from the onboard card to the new card and finish the installation in windows.
Hope this helps
Feb 20, 2012 | HP Pavilion a1210n (ED895AA) PC Desktop
Need a driver for a NX7300LE-TD128EH
This is Nvidia's link for downloads:
http://www.nvidia.com/Download/index.aspx?lang=en-us
Product type- GeForce
Product Series- GeForce 7 Series
Product-GeForce 7300LE
choose your operating system and click search
Jun 24, 2011 | MSI NX7300LE-TD128EH GeForceĀ® 7300LE, PCI...
Yesterday I was on the computer and the screen just went jagged with colors, best way to describe that. I pulled the plug since was was getting no response from ctrl alt+ delete. Or my big brother keyboard...
you might pressed a key on the monitor repress it and enable the monitor or else just remove ram from the cpu and clean it and replug it might it solve your problem
the last solution is to just format your pc
Jun 03, 2017 | HP Pavilion s3000e (GC387AV) PC Desktop
I'm trying to set up BenQ FP71G+ as a second monitor connecting to Nvidia GeForce 8800 GT. I cannot get the BenQ to display even if it is the only monitor connected. However, I can see the BenQ in...
I have had problems occasionally with connecting a second monitor, too. Hook up both monitors. In the Windows control panel, look up display (or right click on your desktop and select display). Is the second monitor shown? If not, click "detect" and see if it shows up. I have had a couple times where I clicked on the monitor icon in "display" and then clicked "enable this monitor" and it started working. If not, then try switching the cords so your working monitor is the second one. try again and see if it show up. If not, the problem is probably with the video card or video card driver. Try and update the driver for your card.https://www.geforce.com/hardware/desktop-gpus/geforce-8800-gt
If this does not work, the issue is probably the card.
Feb 09, 2018 | BenQ FP71G 17" LCD Monitor
Computer wont turn on after power surge
You can try to change the sockets to which it was connected, try to plug the power cord of PC to different socket on surge protector or try connecting it directly to wall jack..
Jun 19, 2010 | HP Pavilion a1440n PC Desktop
My video card stopped working. i changed the video
maybe it is your motherboard, reset bios ... because you can see anything do as it follows , unlupg power coard-open case - pull out little silver battery- wait 10 sec-put it back in- switch power cord and start your computer.. that will reset your bios. cmos more exactlly... if you see the boot menu it is ok.. but if you can go to os.. then you must set you bios video output to pci... try and write back
Feb 20, 2010 | Gateway GM5260 PC Desktop
Getting my display on my nvidia geforce mx420 to show on my tv???
Make sure you have the new drivers from nVidia and then go to windows and get the latest DirectX 9.0 or above drivers.
Mastersage...........
Feb 17, 2009 | Dell Dimension 4550 PC Desktop
Nvidia GeForce 7300 LE 256MB PCI Express Graphic Card Logo
284 people viewed this question
Top Nvidia Computers & Internet Experts
Terry
David
David
Are you a Nvidia Computer and Internet Expert? Answer questions, earn points and help others
