Question about Vacuums
Hi My hoover will work for about 1 minute (suction seems fine ) and is then cutting out-clearly over-heating.I cannot find the manual -can you suggest possible solutions.Thanks
  • 694 Answers
Check the hoses and hose ports for clogs. Detach the hose and drop a marble in one end, allowing it to run out the other.
If this is a bagless model, check inlet behind filter for clogs. If it has a bag, try changing the bag.
Posted on Aug 22, 2010
The make of our hoover is solec ci 1600w it has lossed suction, has got noisey, and cuts out when it gets hot
Here is a link to the hoover site where the manuals are. My guess is that either your filter is dirty or you have an obstruction in your hose or head and it needs cleared which the manual should guide you to resolve. I was unable to find the model you have by your description but you should be able to as the search function will guide you to enter the necessary information to get you where you need to be. Best of luck
Product Manual Search
Aug 28, 2016 | Hoover Vacuums
Suction not working on vaccuum.
Check for a blockage in the hose, or a tear / hole in the hose between the "pleats"
Jun 13, 2010 | Hoover U5753-900 WindTunnel Bagless...
The suction is not working. we have tried all the
check RECOVERY TANK LID and DUCT
May be the duct is off the hook
Nov 23, 2009 | Hoover SteamVac F5914-900 SpinScrub...
Hoover windtinnel suction problem
the intake hos at the bottom might be clogged.first take all the filters out and disconnect the hos completely from the vacuum,then check and see if you have suction.the intake hose is the clear looking one at the bottom that wrapps itself up from the base to the backside of the upright.you can use a coat hanger to push out the clog if there is one just bend the tip till its rounded.work it down into the intake hose from the back.after removing the hose and the filters you should have suction.just make sure all the filters get cleaned .you can blow out the hose with a garden hose
Apr 02, 2009 | Hoover U6437-900 / U6439-900 Windtunnel...
Why does the hose have no suction?
Sounds like your machine has a blockage in the vacuum system, and is cutting out from overheating. If you no longer have a manual, which will tell you about clearing blockages, you can download from the Hoover website.
Mar 08, 2009 | Hoover U5721-900 WindTunnel Upright Vacuum
Hoover Savvy has limited suction when cleaning the floor and carpet
With the unit standing upright, double check the clear plastic air passages on the sides of the vacumn to see if they are clogged.
Jan 03, 2009 | Hoover U8171-900 / U8172-900 / U8173-900 /...
Flair motor shorting out?
There's a thermal cut-off when the unit has overheated. Mine does this quite often and I remedy it by emptying the canister and making sure the filter is clean, especially of lint and things that prevent good air flow.
Jul 07, 2008 | Hoover S2220 Flair Bagless Upright Vacuum
Hoover savvy no suction on carpet setting
Check to make sure you hear the vac. motor is running when in that position. The switch in the handle could be bad if it is not.
Apr 29, 2008 | Hoover U8145-900 Savvy Bagless Upright...
Help
as the hose fits into the base (if i am correct) the power at the base should be fine, make sure the base is clean and free from blockage, you say the brush doesn't spin, has the belt broken, if so replace it, (very cheap) and only a couple of screws to undo, the roller not rotating will effect the power of suction dramatically, start from there and see how you go if i have helped please rate me
Sep 15, 2007 | Hoover U8171-900 / U8172-900 / U8173-900 /...
Hoover Windtunnel
Mine does the same thing. There is no suction. I found that there is a door that opens when you tilt the handle in the down possition. I think there should be a spring in place so it can open. Until I find a replacement spring I have to open the door manually throught the opening under the light.
Oct 15, 2006 | Hoover U6630-900 WindTunnel Bagless...
Vacuums Logo
32 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
