Question about Refrigerators
Maytag side by side fridge model MSD2651HEW. The fan runs studying, the compressor is getting hot and no cold air on both sides. The fridge is about 5 years old. Please advise what I can do to fix this.
Krazytech
  • 725 Answers
SOURCE: Maytag MZD2766GES side-by-side Refrigerator warm
is it frozen up? do you have any air flow thru the air tunnel from the freeze to the fridge? Check your air flow with the door switch pushed in. also check to see if the damper door opens... 1) if it is iced up you have a defrost problem. most likely a defrost timer. Turn off or unplug untill all the ice has melted off the evaporator back of the freezer..plug back in and it will work fine untill the ice builds up again. if this work you do have a defrost problem.. if not let me know and we can go deeper...
Posted on Aug 18, 2007
SOURCE: Sunbeam Model YLR2-5-90HZ3 hot/cold water dispenser w fridge
HOW CAN I REPLACE THE PART MINE IS DRIPPING WATER CONSTANTLY.
Posted on Nov 15, 2008
  • 113 Answers
SOURCE: Fridge/freezer not working
unplug it for 24 hours plug it and see if the compresor is running if its trying to click on and off your start relay may be bad
Posted on Apr 29, 2009
  • 14 Answers
SOURCE: Fridge not blowing cold, Buzzing inside black ball "compressor"
The black ball you are reffering to is the compressor.It is trying to start..that is the buzzing.The start,and overload relay is probably bad..hopefully.Because if it isn't the compressor may be bad.Where your wires plug into the compressor...this is the relay.it should come off fairly easy.It is much cheaper to replace this part..than buying a new fridge.For instance i buy them for g.e. refrigerators all the time from an appliance repair shop at cost,and they are less than 4 dollars for me.So I assume they aren't too expensive retail.
Posted on May 18, 2009
erpaalai
  • 999 Answers
SOURCE: Maytag Model MSD2651HEW - Changed Filter and
Was the pressure ok before you changed the filter? The water valve itself could be partially plugged or the supply line may be filling with minerals. Usually happens in the piercing tap used to attacc to the house line. Difficult to say for sure without seeing the way it is installed. If it was just the drinking water I would suggest the reservoir being froze up but since it affects both look at my initial comments...
Eric
Posted on Oct 12, 2009
The freezer stopped working (the fridge is working but not as cold as it should be), I cleaned all the vents and the freezer worked again fro a short time then I heard a noise like possibly the fan...
It does sound like a bad fan motor. With the compressor getting hot you may need to change the start relay, overload and run capacitor if it continues to run like this with a defective fan motor. What is the correct model number? Sea Breeze
The condenser fan motor for a model MZD2766GES is part number=> 61005323 Condenser Fan Motor or here=> 61005323 Condenser Fan Motor
Oct 18, 2013 | Maytag MZD2766GES Side by Side...
Maytag fridge wont get cold kicks on and off
If your model is the MZD2766GES it would be a good idea to examine the=> 12002794 Relay and Overload Kit
replacing the=> 65889-4 Run Capacitor
will also be recommended. Can yu feel the top of the compressor? Is it hot? I am here if you have questions, Sea Breeze
Jan 15, 2013 | Maytag MZD2766GES Side by Side...
Maytag MSD2651HEW refrigerator not cool, freezer works fine. If open both doors, feel cold air blowing in refrigerator side
try keeping the freezer door shut while felling for cold air blowing over to refrigerator side..if so problem lies in the thermostat...its not sensing the correct temp for the fridge side and closing the damper too early...also check to see if there is frost built up on the back wall of the freezer section if thats the case then you are at the begining stages of a defrost issue and soon no cold air will blow over to fridge side..let me know what you find
Mar 13, 2012 | Maytag MZD2766GES Side by Side...
Compressor runs and gets hot but fan will not kick on. Replaced the capacitor and that did not help. One side of coils gets hot, the other side gets cold, which seems normal. Just can't get the fan...
Don't run the compressor for any length of time without the fan operating. Is it possible that the fan must be replaced? Can you power the fan safely to test it?
Gary
Jul 26, 2011 | Maytag M7DH45B2A Dehumidifier
Fridge and freezer not getting cold although fan is on and it sounds like the compressor is on. But has now stopped running so I unplugged. Is the compressor gone? This fridge is only 8 years old.
Most times the compressor start relay and run/start capacitor may be defective. If the fans run yet compressor gets very hot on top it may be trying to start and cannot because those mentioned components need replaced. Pull away from the wall, unplug and lets remove the lower cover that hides the compressor. If compressor is hot it just may be short cycling because it need these components=> MTB1954ARW Compressor Components
Finding the correct model number for yours will be important in order to get the right parts. On side by sides and top mounts should be able to find the correct numbers here=>
Top Freezer Side-By-Side For user manuals and literature click logo=> sea_breeze_117.jpg Product made for outside the US=> HERE Find model number's HERE If you feel like you need to test compressor click here=> Appliance 911 Sea Breeze Scroll to near bottom of page and read how to test a compressor. In most cases a new start relay and sometimes a hard start will give you fridge a few more years, Have questions? Let me know, Thanks, Sea Breeze
Mar 18, 2011 | Maytag 18.9 Cu. Ft. Top-Mount Refrigerator...
Hi, freezer took a dump two days ago, fridge was still fine. Then 12 hours later the fridge dumped out too. The compressor is hot and the relay looking thing with part number nsk 85851 clicks on for 20 sec...
most likely the start device is bad,look at the left wall inside the fridge near the cieling,you should see a model number,call your parts store,give them the model number on the machine,there is other letters after the g and tell them you need a start device.unplug the machine,until you get the part so you don't damage the compressor,it's not cooling anyway and thhe freezer feeds cold air to the fridge side,a fan blows cold air from freezer to fridge so next time if the freezer has a problem the fridge side is gonna have a problem too,unclip the metal clip and slide the start device off,read the instructions and it will tell you how to install the new device
Feb 06, 2011 | Maytag PTB2153G Top Freezer Refrigerator
Maytag RSW24EO refrigerator not cooling
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp.
Sep 14, 2009 | Refrigerators
Door frame is always hot on freexer side
Is it hot all the way around, or just on the face of the divider between the freezer and fridge? If it's just the divider, then it's probably not a defrost problem. When that divider gets hot, it usually means there is inadequate air flow over the condenser coils outside the unit.
When the compressor is running, check for air blowing under the unit. If no air is moving, then you probably have a failed condenser fan. If the fan is running, then use your vacuum cleaner to clean the coils, and make sure there is space behind the fridge for air to flow.
Jul 21, 2009 | Maytag MSD2756G Side by Side Refrigerator
Aug 18, 2007 | Maytag MZD2766GES Side by Side...
Refrigerators Logo
60 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
