Repair will not help you to fix the issue..
What you need to do is.. Try getting into safe mode by tapping F12 when the system turns on... Try doing a system restore from there so that you dont loose any data.. If that is not possible,...
If
you have windows vista on the computer then tap F8 when the computer
turns on and then you will be able to see the advanced boot options..
Select repair my computer.. In the repair my computer screen select the
dell factory image restore..
Your computer will go through the installation and it will be up and running...
If
you have windows Xp then you have to turn on the computer and when the
dell logo appears you have to simultaneously press control and the
F11key.. You will be able to reinstall the OS in this way..
Dead Laptop.
Try firstly removing the laptop's
battery as it may be at a critical voltage and the system will not
start because of it. Plug in your ac adaptor and monitor what
happens. Does the power light illuminate? If it does it should then
boot up, if it doesn't, try a known good ac adaptor before going any
further.
If the adaptor is fine then you have a mother board fault
and should contact a dealer/repairer for further advice.
Hope this
helps.
