Question about Garmin Nuvi 760 Handheld GPS Receiver
I have A garmin 760 gps. It was working great for about 1 1/2 years, then the end unscrewed, it lost the fuse and the end. I called garmin tech they sent me a repair kit. I installed it and the unit will not go on when plugged into the vehicle, I have to turn it on. Also only one light goes on on the end part and it does not keep a charge.
    Sergeant:
  • 252 Answers
Did they send you a new Battey with the repair kit if not this is what your problem is. Get on the internet and go to You Tube after you are on the website type in How to replace your Garmin Nuvi 760 battery and it will show exactly hoe to do this.
Posted on Aug 22, 2010
My car charger will not charge battery in garmin Nuvi 760
The fuse may be gone in the charger. There's a ring, near the silver tip, of the plug that goes into the cigarette lighter. If you unscrew the ring the plug will come apart. Take care not to lose the silver tip as it may fall out. Replace the fuse and it may solve the problem.
Feb 28, 2011 | Garmin Nuvi 760 Handheld GPS Receiver
My Nuvi 760 doesn't hold a charge and keeps shutting off when charging in car outlet. Thanks for any help you can give me.
Check the car charger cigarette lighter adapter plug first, at the silver tip end of plug it has a fuse, Unscrew the silver tip CAREFULLY its spring loaded and check fuse...
Nov 06, 2010 | Garmin nuvi 750 GPS Receiver
The in car charger has a poor conection to the unit holder and does not work
Are you sure its the connection? The adapter plug has a fuse in it at the silver tip end, Unscrew it CAREFULLY its spring loaded check fuse, replace with a 3A fuse
Oct 30, 2010 | Garmin (010-00583-00) for nuvi 750/760/770
Nuvi 760 will not take charge
I don't know which of the three ways you're trying to charge - car cradle, via USB cable to a computer or via accessory AC adapter. An 18 month old 760 should still have a good battery.
If you are using your car cradle to charge consistently, use one of the other methods and allow the 760 to charge for 8 hours. Use of the car cradle can cause the 760 to stop taking a charge after a while, and switching to one of the other methods should "refresh" the internal battery. Since the AC adapter wasn't included in the box, the USB cable method is likely your only other choice. While connected to your computer, you should download & update the 760's firmware. It's fast and free - and could solve other potential issues. Get the WebUpdater software direct from Garmin.
It is also possible that the fuse in the cigar lighter plug has opened. Disassemble the the plug to check for and replace a blown fuse.
If unable to get the 760 to accept a charge, you might need to replace the battery. There are several sources for batteries - but a free call to Garmin Support should be your first move.
Please rate this reply and good luck!
Jun 10, 2010 | Garmin Nuvi 760 Car GPS Receiver
How do you replace the fuse in the 12 volt adapter? Harley
Unscrew the nut on the end of the plug. The tip, fuse and spring should all just slide out. Replace in the opposite order.
Aug 17, 2009 | Garmin Nuvi 760 Car GPS Receiver
I cannot register online; tells me that my serial number is invalid
Call Garmin
My 760 had an error in the serial number. The garmin tech solved this in seconds with the corrected number.
Harvey
Apr 28, 2009 | Garmin Nuvi 760 Handheld GPS Receiver
Garmin 760 will not disconect from phone call on bluetooth
i think this is a fimware fault.. do a firmware update this will get solved..
Mar 30, 2009 | Garmin Nuvi 760 Handheld GPS Receiver
I have a Garmin Nuvi 760. The end cap which screws in and holds the fuse in for the traffic receiver power cord is broken. Anyone knows where I can get a replacement part without buying another power...
This is a known problem with the 760 traffic receiver power cords. Call Garmin Customer Service (you may stay on hold for 20 minutes or so). When someone answers, explain the problem and they will most likely send you a replacement screw cap and fuse assembly for free.
Jun 12, 2008 | Garmin GPS
Garmin Nuvi 760 Handheld GPS Receiver Logo
54 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
