Question about Intel DP55KG Motherboard
The front panel audio pins on my mother board read port1L--> (1)(2) <--Ground port1R--> (3)(4) <-presence# port2R--> (5)(6) <-Sense1_Ret Sense_Send(7)( ) <-key (no pin) port2l--> (9)(10)<-sense2_Ret the numbers represent pins and there labels my problem is the wires comming off my case read ground, spkout R, return R, spkout L, return L, mic in, mic bias Not only dose it seem to be missing 2 wires i have no idea what wire gos where, can i make it work? Do i need to get a new one? If i do where can i get one?
  • isaac_4211 Aug 22, 2010
    i have the manual i that was not my question i want to know where i can get a new front panel audio jack for my hd audio or if i can make the one i decribed work
  • 3,153 Answers
Some cases have individual pins marked for the audio on a motherboard but many have a single block connector that usually has one pin blocked. That pin is to ensure it is only plugged in one way (the correct way)
It is not uncommon to have unused pins
Quite often there may be more than one GROUND and only one is needed so the others are quite often redundant or on some plugs just have a loop into that ground.
Yours uses PLUG E near the shorter PCI-E connector
Pin 8 is the BLANK pin I refer to above so if your front panel has that blanked or empty then that is the orientation
Not all pins are always used so you should still be able to connect just fine so long as only the one pin is missing as that is deliberate.
It is mentioned in the manual available here on page 50
http://downloadmirror.intel.com/18129/eng/DP55KG_ProductGuide03_English.pdf
Posted on Aug 23, 2010
    Brigadier General:
  • 5,158 Answers
You can look and download the manual here http://downloadmirror.intel.com/18129/eng/DP55KG_ProductGuide03_English.pdf
it will give you a diagram of the pin outs
Posted on Aug 22, 2010
How to connect power switch to mother board
http://www.intel.com/support/motherboards/desktop/dg41rq/sb/CS-029925.htm
Click on -
Intel Desktop Board DG41RQ Product Guide - English (PDF)
Bookmarks menu to the left -
1) Click on the + sign to the left of -
1 Desktop Board Features
Click right on - Desktop Board Components
Or go to Page 11. (Adobe Reader page number box at top)
Front Panel header location marked by P, in the figure.
2) Click on the + sign to the left of -
Connecting to the Internal Headers and Connectors,
in the Bookmarks menu.
Click on - Front Panel header
Motherboard mounted in computer case, the Front Panel header is in the bottom/right corner, above the top black SATA connector.
Two rows of contact pins.
The Top row is numbered EVEN.
Starting at the Left side going across to the Right, Top row;
Pins 2, 4, 6, and 8. There is NO pin 10.
The Bottom row is numbered ODD.
Starting at the Left side going across to the Right, Bottom row;
Pins 1, 3, 5, 7, and 9.
A) Pins 1 and 3 are for the HarDDrive activity LED. (Light)
Pin 1 is for the Positive wire.
If the HDD LED is dim when the harddrive is active, switch the wires around.
B) Pins 5 and 7 are for a Reset switch, IF a Reset switch is used.
C) Pin 9 is N/C. Not Connected. Probably 5 Volts DC for factory testing.
D) Pins 2 and 4 are for the Power On LED. (Light)
This IS for a -> 2 wire LED. (Light)
Pin 2 is for the Positive wire.
If the PWR LED is dim when the computer is on, switch the wires around.
E) Pins 6 and 8 are for the Power On switch.
To the left of the Front Panel header is a 3-pin header.
This is the Alternate Front Panel LED header.
If you have a -> 3-wire LED, it connects here.
Also wanted you to have the motherboard manual.
Regards,
joecoolvette
Nov 04, 2012 | Intel DG41RQ Motherboard & Core 2 Duo...
I have an Asus P5QL PRO Motherboard and I'm trying to connect the FP audio and I need some help on how to connect it up properly. On the heaphones lead I have 4 connectors: EAR R EAR L RETURN...
Hi
Pin arrangement for Front panel Audio is usually:
Pin 1 Left MIC-IN Pin 1 right GROUND
Pin 2 Left MIC VVC (or MIC Power, or MIC BIAS) Pin 2 Right empty
Pin 3 Left R EAR (or R OUT) Pin 3 Right R RETURN
Pin 4 Ground or Empty Pin 4 Right empty
Pin 5 Left L EAR (or L OUT) Pin 5 Right L RETURN
This arrangement should apply to both the HD AA/FP or the Standard AC'97 Headers.
I hope this helps
Aug 28, 2011 | ASUS P5QL PRO Motherboard
I HAVE A NEW CASE, & NEED TO CONNECT THE FRONT UBB & AUDIO LEADS. CAN YOU HELP, CHEERS
Hi there, first check the image below. You've got USB 3 and 4, and AUDIO section. For the USB, pins 1 and 2 represent front panel USB power on both 3 and 4. As for AUDIO connection, pin 1 is Front Panel Microphone input signal, pin 3 is Microphone Power, pins 5 and 6 are for Right Channel audio signal to Front Panel and pins 9 and 10 are for Left Channel audio signal to Front Panel.
You can find more details in the motherboard's manual, page 23 and 24.
Jan 23, 2011 | EliteGroup P4M800PRO-M478 Motherboard
Hi! i am using Intel DG33FB motherboard, i need the information about the connectivity of front pannel audio. for this it is Realtek HD audio port. i am having 5 cables set for the front pannel...
The L&R-Ret2&3 are common so only one needs fitting so for the speakers you only need to connect 3 cables. R-Out, L-Out and one return (either L of R). I'll comment back shortly on the mic pins for you.
Dec 23, 2010 | Computers & Internet
I have a dell xps 400 with front and rear
REMOVE FRONT SPEAKER CONNECTION ON MOTHER BOARD. CLOSE THE PINS WITH JUMPERS IN ALTERNATIVE POSITION. CLOSE 1-2 AND 5-6
9-10 WITH JUMPERS U WILL GET REAR OUTPUT
Mar 21, 2010 | Dell Dimension XPS PC Desktop
What is the firing order for the spark plugs on my 2000 chevy express van?
I sincerely apologize for the late response...Due to the bad economic situation this site has had a substantial (+50%) increase in the number of questions being asked in the last four months.
I am not sure if you have the 1/2, 3/4 or 1-Ton model.
Also Not sure if you have the 4.3L, 5.0L, 5.7L or 7.0L Engine. However I have included all below.
For the 4.3L (6cylinders):
Firing Order:
1-6-5-4-3-2
Cylinders:
6------------5
4------------3
2------------1
(front of vehicle)
Distributor:
coil wire-->
-----6------->............<--------5-------
-----4------->............<--------1-------
-----2------->............<--------3-------
............(front of vehicle)
For the 5.0L AND 5.7L AND 7.0L (8-cylinders):
Firing Order:
1-8-4-3-6-5-7-2
Cylinders:
8-----------7
6-----------5
4-----------3
2-----------1
(front of vehicle)
Distributor:
coil wire-->
-----4------->............<--------3-------
-----2------->............<--------7-------
-----8------->............<--------1-------
Let me know if this helped, or if you have additional information or questions. Feel free to contact me at FixYa.com!
Jan 24, 2010 | 2000 Chevrolet Express Cargo
Emachine t1840 wiring diagram power switch wire to mother board ?
Because there are so many different case and motherboard combinations sometimes it can be difficult following the instructions for connecting the front panel, USB header and audio header.
Below is a few generic guide that should stop some of the confusion with the labels on the wires.
Front Panel Audio
***Please note this is a generic wiring guide and we can not guarantee it will work with every motherboard. Please check your motherboard manual first. Wiring the headers wrong can cause damage to the motherboard and case, this damage is not covered by the warranty***
another handy USB wiring guide can be found here http://www.directron.com/installusb.html
this maybe easier to follow
FRONT PANEL AUDIO
2________10
__
1________9
Pin Wire
1) Mic In
2) GND (ground) or if 2xGND available, it’s the GND for the headphones, NOT the Mic
3) Mic BIAS
4) n/c
5) Speaker Right Out
6) Speaker Right Return
7) n/c
8) no pin (n/c)
9) Speaker Left Out
10) Speaker Left Return
n/c = not connected
USB (F_USB1 and also F_USB2)
2________10
 x
1________9
Top row of pins
2 = USB port 2 : VCC/Power/+5V
4 = USB port 2 : Data -/D-
6 = USB port 2 : Data +/D+
8 = USB port 2 : Ground/GND
10 = USB port 2 : pin present, but not connected to anything.
Bottom row of pins
1 = USB port 1 : VCC/Power/+5V
3 = USB port 1 : Data -/D-
5 = USB port 1 : Data +/D+
7 = USB port 1 : Ground/GND
9 = USB port 1 : no pin present
Front Panel Connector (FP1)
1 2
x 
9 10
1 = no pin present
3 & 5 = Power Switch
7 & 9 = Power LED (light)
2 = pin present, but not connected to anything.
4 & 6 = Reset Switch
8 = 10 = Hard Drive LED (light)
Jul 30, 2009 | Computers & Internet
Where is the audio output to front napel?
The ECS page is here;
http://www.ecs.com.tw/
Enter your model number in the search box and you'll be able to download the manual, which has the info you want.
Oct 15, 2007 | EliteGroup PT800CE-A Motherboard
Intel DP55KG Motherboard Logo
120 people viewed this question
Top Intel Computers & Internet Experts
Tony
David
David
vsri9
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
