Question about Waring Pro WC1000 Coffee Maker
My Waring Pro Coffee maker leaks water out of the bottom. In the morning when I get in I have to clean up the leak. Is this repairable?
When you pour water into the screen area it travels toward the back of the unit and drops through a rubber gasket/cup to be heated/processed. I have the same problem and while I bought another WC1000 I took my old one apart. By turning it over and removing 4 recessed screws you can carefully lift the top off (carefully because wiring is attached). However, you can now access the rubber gasket/cup. Doing this I found that mine was torn which I must assume is the cause of the leaking problem. Now if anyone knows where I can get a replacement rubber gasket/cup or a part number I would appreciate it.
Posted on Aug 24, 2010
Water leaks from bottom of unit when making a pot of coffee
There are many possible points that the leak can be.
All points of the water supply from water tank to the pressure pump then to boiler and finally to coffee group. All this are connected together with plastic or Teflon pipes with easy fit unions secure with clips
You need to disassemble the machine and work it without the side panels of course with extra care since power electrical cables are exposed.
In this way with a very good visual check while the machine is in operation you can identify the leaking point and fix it.
May 06, 2010 | Waring Pro® WC1000
Coffee maker leaks when running; possibly the vent tube is plugged.
I wonder if also your coffee filter holder isn't aligned flush to the housing?
Nov 28, 2009 | Waring Pro WC1000 Coffee Maker
Water leaking out the bottom of the coffee maker
If it leaks DURING brewing, you may have to decalcify it (aka, run through a cycle of 4 cups vinegar, fill to the top with water, 2-3 times and see if it helps).
If it leaks before you even start brewing a pot of coffee, something is broken on the inside of the coffee maker, and I would recommend contacting Waring--they may be able to get you a replacement coffee maker (and if you're under warranty, usually a replacement would be free!).
Their phone number (according to their website, www.waringproducts.com ) is 1-800-4WARING (1-800-492-7464)
Good luck! :)
Aug 27, 2009 | Waring Pro WC1000 Coffee Maker
MACHINE LEAKS WATER
Turn on machine w/o water or google the company
Jun 02, 2017 | Waring Pro WC1000 Coffee Maker
The coffee maker leaks out of the bottom when in use
I found the issue after about one hour taking the unit apart. Anyhow, in my unit there was a crack in the plastic spout portion. This spout partially goes into the hot water tank. After a bit of time the heat causes the spout to develop a crack, which leaks. I repaired the crack with some epoxy I had on hand and also added some aluminum tape to the area surrounding the spout. I hope the aluminum tape helps keep some of the heat away from the spout and prevent further cracks from developing. Its just a poor design, material wise, it should have been stainless steel from day one.
Sep 25, 2008 | Waring Pro WC1000 Coffee Maker
Leaking coffee maker
Unfortunately there are many reviews for your coffee maker that are negative as far as leaking is concerned.
Most have had leaking problems about 6 months after purchasing this machine.
I don't know what to say, but you may have to bring or send it back and get another one. Maybe a different brand?
May 08, 2008 | Waring Pro WC1000 Coffee Maker
A short condition has severed a conductor wire inside the coffee maker. Seems to be a common problem with coffee makers as the wires are in close proximity to heating devices.
Mar 16, 2008 | Waring Pro WC1000 Coffee Maker
WC1000 GFI
You're not alone.  Same problem here.  Breakaway power cord on my Waring deep frier burnt to a crisp.  Don't known about you, but I'll never buy Waring products again.
Oct 03, 2007 | Waring Pro WC1000 Coffee Maker
LEAKING WATER
I had the same with a Saeco it was caused by a leaky boiler, after replacement, it was fine...
Aug 08, 2006 | Waring Pro WC1000 Coffee Maker
Waring Pro WC1000 Coffee Maker Logo
1,035 people viewed this question
Top Waring Coffee Makers & Espresso Machines Experts
Hjalmer Lamminen
Hjalmer Lamminen
Douglas Dinnebeil
Douglas Dinnebeil
Are you a Waring Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
