Question about Kitchen Ranges
Inside the oven door there are some stains from liquid spill that went through the vent, how can I clean it.
    Genius:
  • 1,142 Answers
If your oven is self-cleaning, consult the owner's manual for instructions on how to use this feature. The self-cleaning feature works by heating the interior of the oven to a temperature so hot that it incinerates the residue inside the oven. Normally, it is not a good idea to clean the interior of a self-cleaning oven with a spray cleaner; however, refer to your owner's manual or contact the manufacturer of your oven for further information.
To clean a non-self-cleaning oven, use one of the many oven cleaners that are available at grocery and hardware stores.
Posted on May 04, 2008
I had a spill in the refrigerator compartment, removed all compartments and the liquid drained into the vent in the bottom of the refrigerator. How can I access this to clean out liquid?
Can you click this link=> HERE and look at the code below the model number and tell me that code? Then look at the drawings and tell me which vent the liquid went through? Appliance 911
Jan 02, 2016 | LG LFC24770ST Stainless Steel 23.6 Cu Ft...
How do I clean beko oven door inside panel?
Oven door glass is a "sealed" unit that accumulates stains over a period of use. It is not intended to be removed, unsealed, cleaned, resealed, and reinstalled.
Dec 28, 2013 | Ovens
Spills went through bottom oven vents messing up inside door glass front
Yes, you can clean it yourself but be sure to take note of the way you dismantle the door. I usually take pictures to be sure of the process.
Nov 27, 2012 | Kitchen Ranges
A kettle of soup boiled over on my new Kenimore Elite Electric Range. Some of the liquid that fell down the front went into the vents at the top of the door and dripped down onto the inside of the glass...
This question was asked almost 2 years ago, but thought I'd respond anyway. On the bottom of your oven door there are slots. Pull out the drawer beneath the oven door so you can work under it. Find something that will fit through the slots, a yard stick worked for me, or maybe a wire coathanger. Attach a paper towel or cloth securely to it and put it though the slots to reach the soiled area. It will take some manuvering. I would not recommend taking the door apart. When I did some research on this some time ago, I read that it can be difficult or impossible to get it back together again.
Oct 11, 2010 | Microwave Ovens
Spills have run down inside the oven door and stained the glass of the window (on the inside). Can I easily take the door apart to clean it? There are two screws on the inside of the door...can I unscrew...
experimenting is always easy if dont care about the repercussion ,it will be easy to remove it but not easy to assemble it back you can clean it by keep it open and you should use some catalytic solution for it
Feb 25, 2010 | Kitchen Ranges
When I use my self-cleaning on my oven it leaves a brown stain on the white plastic part outside my oven door. How do I clean the area that has browned?
Hello- The self-clean cycle heats the inside up to about 800deg. There is no existing plastic that can take the heat at the vent w/out discoloring. The stain is from the smoke produced when the stuff on the drip pan incinerates. Try some oxy-clean and a damp cloth. Try to predict or minimize spills with foil and drip pans. Techs call 'self-clean' the 'self-destruct' cycle. Using this function will reduce the life expectancy of any electric range. Let me know if this info helps-have more if needed- Thanks- ED
Jan 28, 2010 | GE 30" Self-Cleaning Freestanding Electric...
Frigidaire double oven - stove top oven had a spill. The spill went through the bottom oven's door vents and is now in between the glass and I cannot get to it to clean. How can I get this glass clean?
I had a similar problem with a spill running into the vent and between the glass. I had to take the door apart clean it and then put it back together. It sounds hard, but it was just a few screws and a little time.
Jun 27, 2009 | Kitchen Ranges
Cleaning Oven Door Glass inside face
First take the two inside screws out, (found at the top of the door) they will pop out when you have both sides off so make sure to take them all the way out so you dont lose a washer or one of the screws. The handle is actually secured by these 2 screws and will come off of the door when you remove them.. your metal door can bend slightly in this process, so be careful. as soon as the handle and screws are off you can clean inside of the 2 pieces of glass, also a good time to clean off the opposite side of the door behind the handle. only take the 2 screws off no need to remove the full door. I used a magic eraser to remove the grease and then I cleaned the glass with glass cleaner. I used a small vice to secure the door when putting the handle back on, but you could have someone to hold the piece togeather for you too. (I have a frigidaire stainless steel model)
Nov 09, 2008 | Dacor Epicure ERD36 Dual Fuel (Electric...
Kitchen Ranges Logo
508 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
