Question about Hitachi ( 0A30229-20pk) 400 GB Hard Drive
Dell Dimension 5000
Replaced existing hard drive (SATA) with new Hitachi 400 SATA but system won't boot - Error msg - Drive not found
    Genius:
  • 1,142 Answers
Please reset the bios..on dell logo..press f2..press num lock, caps lock ,scroll lock so that all three are on. press alt e
press alt f
select the option that says
save changes and exit
your hdd should get detected.
please post back if it does not work so that i can check out fir further options
Posted on May 04, 2008
How can i fix error code 2000-01 42 Validation 51532 Msg: Hard Drive 0 - S/N WD-WXM1A61M4533
Dustin Larmore,
The error means that the hard drive is defective or broken You will need to have it replaced.
The Inspiron N4110 / N4120 / 14R system uses Serial-ATA II(SATA II) hard drives.
Thank You,
Dell-Jesse L
Dell Social Media and Communities
Jul 01, 2014 | Dell factory recertified inspiron...
Hard drive boot failure
what is the error message? If operating system could not find, try you original windows installation CD, during you boot from the CD there is a repair option, follow the wizard to complete.
Sep 03, 2012 | Dell Dimension 2400 PC Desktop
SATA Primary hard disk drive failure
Sounds like your hard drive has failed and will need to be replaced. You will need to make sure you have all the recovery cd/dvds Dell sent with the system; or you created when you got the system. The new hard drive will be completely blank, so you will have to install the OS, drivers, and other software from these CD/DVDs.
Hope this helps
Apr 25, 2012 | Dell Dimension XPS 400 PC Desktop
How i can install the new HITACHI HDS721010CLA har drive in to my dimension E510
Hi castanedajes !
Here is a link to the Hard Drive section of the user manual of the Dell Dimension E510. It detailes all of the procedure.
http://support.dell.com/support/edocs/systems/dim5150/en/sm/parts1.htm#wp1366406
Best of luck omerk.
Jan 28, 2011 | Hitachi 1TB HDS721010CLA332 SATA2 U300...
Hello, I have a Dell XPS 400 system that has a bad hard drive. So I went out and bought a new SATA drive, and it's not detecting it upon boot. When I go to the boot menu on F12, it says something about...
Was the original drive also a SATA? If not, then you would need to enter the bios setup and enable the onboard SATA channels. If the bios had gotten defaulted, as from a dead CMOS battery etc. it could have also caused your original SATA drive to be inaccessible.
Nov 24, 2009 | Dell Dimension XPS 400 PC Desktop
Dell Dimension 5000
you problem is most likely that your bios is out of date. download the latest bios updates for your motherboard and then when you install windows format you HDD with the ntfs system (using the long formatt system not the quick format). Then you should install the bios update. then your mboard shoud no longer have the problem of recognising your large capacity HDD. thanks
May 18, 2008 | Computers & Internet
Dell Dimension 5000 Desktop
You don't need drivers for a hard drive! Just plug it in and it will be recognised by the BIOS.
The only thing you will need to do is make sure you designate it as a primary or slave drive - whatever the old drive was set to. On the back there is what looks like an eight pin plug, with a jumper across two of the pins. Depending which pins are connected will change the drive designation. There is usually a sticker next to them telling you which to connect for primary and slave.
Matt
Mar 21, 2008 | Hitachi ( 0A30229-20pk) 400 GB Hard Drive
Dell Dimension 3000 reformat trouble
please re partition the hard disk and install the operating system. if the same error continues then change the ram and try
Jan 28, 2008 | Dell Dimension 3000 PC Desktop
Dell Dimension 5000 - Installing extra Hitachi 500GB SATA Hard Drive
you need to turn it on in the Bios so the computer sees the drive, then format it.
Jan 20, 2008 | Hitachi ( 0A30229-20pk) 400 GB Hard Drive
Hitachi ( 0A30229-20pk) 400 GB Hard Drive Logo
566 people viewed this question
Top Hitachi Computers & Internet Experts
Alun Cox
Are you a Hitachi Computer and Internet Expert? Answer questions, earn points and help others
