Question about Cycling
Mountain bike with front and rear breaks. rear break screaches when break lever applied--- the more force the louder the screach!
    Brigadier General:
  • 8,546 Answers
You don't say what type of brakes. Try this:
http://www.sheldonbrown.com/canti-direct.html
Posted on Aug 22, 2010
What is a decent replacement rear derailleur for a Mongoose 26" Ledge 2.1 Mountain Bike?
Get the kind that has a lever shift instead of the grip shifter. The plastic part that holds the spring breaks easily. The lever shifter has been going strong on my bike for 6 years without a problem
Aug 31, 2016 | Mongoose 26" Ledge 2.1 Mens Mountain Bike
Why is my dryer is making a high pitch screaching noise?
frigidaire dryers have a rear bearing that the drum rides on,usually when you hear metal on metal sounds it will be the rear bearing
Feb 22, 2012 | Frigidaire FER641FS Electric Dryer
Screaching noice on passanger side and drained battery
It sounds like the alternator has went out. They have bearings in them that eventually wear out. When this happens, they can make a screaching noise, or the bearing itself can lock up, causing the belt to slip and make a similar noise. Both of these scenarios will get louder as you accelerate. When the alternator is not charging your battery correctly, your vehicles electrical system will drain the battery.
Dec 18, 2011 | 1999 Saturn SC
Does this model brakes front and rear at the same time when we press just front break ?
no ...you have a rear brake pedal to control the rear brake and the front is controlled by a brake lever which supplies 3/4 of all stopping power. Dont ever slam down on the rear brake pedal just apply it gradually.
Mar 29, 2010 | 1993 Honda CBR 1000 F
When it is on the rinse cycle it makes a horrible sound
could be a clutch or drive tube problem, on the bottom of your basket drive tube is a thrust washer,it eventually wears off the boyyom of the tube and your clip that holds on your brake release arm falls off breaking your clutch arm and thus no spin will happen ,, sounds like yours is grinding off the bottom of the basket drive tube,, mine was always screaching on the rinse spin and finally gave out when it wore the bottom off my tube, went and bought a used tube installed it with a new clutch and works fine now no more screaching!
Feb 16, 2010 | Kenmore 24032\24036 Top Load Washer
New shifters for deore xt x7 delrailer
Shimano make an "EZ fire" which is an integrated shifter/brake lever combination and cheaper than buying seperate shifters and levers.
e.g.
http://www.tredz.co.uk/.Shimano-Acera-8-Speed-EZ-Fire-ShiftersBrake-Lever_24339.htm
Feb 07, 2010 | Shimano Deore Xt Thumb Shifters 7...
When i hit rear break i get a pulsating in the front break
How strange.Do you mean a pulsating in the front brake lever.If so you've got a warped front brake disc.As you apply pressure,the spinning disc is causing the pads>pistons>brake fluid to pulsate causing you to eventurly feel it through the brake lever.Put that beast on a centre stand with the front wheel off the ground ,HK.Look straight down the bike from head to tail,concerntating on the discs.Can ya see it now.????.Check your rear disc while your there and disc bolts for tightness. Best of luck HK.PS.Please leave feedback if i've helped. Tabby..OZ.
Oct 04, 2009 | 1994 Honda GL 1500 SE Gold Wing
When in spin made loud klunking and screaching noise. now will not work in spin cycle without making loud klunking noise
Pull off the bottom panel, (three 1/4" screws along bottom). Check for chunks of concrete hanging down, or in the bottom pan. I have seen the lower front counter-weights on the HE2 break off several times. If not, reach in and give the basket a hard spin by hand, if you hear clunking or grinding, or the basket feels loose, you have a bad basket brace (usually caused by slop in the rear bearing). You would need to replace the rear shell (comes with a pre-installed bearing) and the basket. Depending on age, these parts may be in warranty, check your manual.
Apr 20, 2009 | Kenmore HE2 Plus Front Load Washer
Brake lights
The taillight should be on at all times. The brakelight should come on when the front or rear brakes are applied. Start by disconnecting the front brake light switch then the rear to see which switch is broken. Also check the bulbs. I have seen them short out internally. The filament inside the bulb break and contacts the other circuit.
Nov 20, 2008 | 1977 Honda GL 1000 (K2)
Put new rear treads on and now rear break will not work?
your spring has no play or try to tighten your brakes wire. thanks
Nov 15, 2008 | kawasaki Full Suspension Mountain Bike Men
Cycling Logo
32 people viewed this question
Top Cycling Experts
John Egan
John Egan
Are you a Cycling Expert? Answer questions, earn points and help others
